Old 05-13-2022, 07:27 AM   #1
Stephen717
Stephen717's Avatar
Re: Roostre's 1967 C20
Even if it isn't much progress it's still progress friend, keep up the good work on it.
Stephen717 is offline   Reply With Quote
Old 05-13-2022, 12:09 PM   #2
Roostre
Roostre's Avatar
Thanks! I'm certainly getting an education on rust repair, and fixing bad patch jobs. Not that I'm necessarily doing it completely right, but it is better than it was.
Roostre is online now   Reply With Quote
Old 05-13-2022, 10:01 PM   #3
Roostre
Roostre's Avatar
Since I'm still debating the order that I'm going to tackle cab repairs, I decided to freshen up the paint on the radiator support after I patched it under the battery tray. I didn't do any prep other than clean it a little and prime the raw steel I patched in. Looks good enough for this truck. After the back dries, I'll flip it and do the front. Once again, I used Rust-Oleum Painters Touch 2X, this time in satin canyon black. I like it. On to pictures; one is overall, a couple of the patched area, and of course the paint can.
Old 05-13-2022, 10:06 PM   #4
Roostre
Roostre's Avatar
I forgot, someone oversprayed red on one bucket in this trucks previous life. I suppose I'll pull them off and try to clean them. Or maybe I have a can of silver around here.
Old 05-13-2022, 10:17 PM   #5
Roostre
Roostre's Avatar
And the front side is all freshened up. New paint is a good feeling, even if it's just rattle can on a radiator support!
Old 05-13-2022, 10:26 PM   #6
Roostre
Roostre's Avatar
Here's the buckets in metallic aluminum. It's a little brighter than I would have liked, but at least they look the same now and are not covered in red overspray.
Old 05-15-2022, 11:28 AM   #7
Roostre
Roostre's Avatar
My radiator support is ready for whenever I'm ready to put my front clip back together.
Old 05-17-2022, 10:08 AM   #8
May70
May70's Avatar
If you check out my YouTube channel in the signature below I have a bunch of metal repair vids on our cabs.
Should help if you haven’t seen them.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 05-17-2022, 12:04 PM   #9
Roostre
Roostre's Avatar
I'll check them out. Thanks!
Old 06-29-2022, 10:34 AM   #10
KyleSeal
KyleSeal's Avatar
Looks like you're moving along really well. I plan to do a roof skin to repair the inner roof and get a fresh start to painting my cab from the paint divider up. Ill be following along!
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 06-30-2022, 05:08 PM   #11
Roostre
Roostre's Avatar
Thanks! Life's a little busy right now, so the truck hasn't been getting the love it should. Hopefully I'll be able to get back to it soon. I ended up ordering the B-pillar patch panels that you recommended after I asked in your build thread (the Keyparts ones). When they show up, it may be the catalyst I need to get back out there!
I recommend gluing the outer roof skin down rather than welding. Mine turned out really well. On the other hand, if you're doing the inner roof too, you may have no problems reaching the outer rear pinch weld.
Old 09-01-2022, 11:55 AM   #12
Roostre
Roostre's Avatar
The humidity around here finally dropped a little bit, and my laundry list of other projects dried up some, so I managed to get back onto my cab.
Previously, I mentioned that my new seam sealer in the drip rail was peeling out. I decided to tackle that last night. My thought is that this was user error. I forgot to scuff the e-coat on the new roof skin before I put the seam sealer in. The sealer peeled right off of the new skin, but stuck to the old drip rail and down the sides of the cab. I ended up wire wheeling out the rest of the sealer that I put in there. So, I decided to really get after it this time by scuffing the whole roof and laying down a coat of primer. Hopefully tonight I will be able to get the new seam sealer in and also put another coat of body filler in my rear roof gap.
Old 09-04-2022, 10:04 PM   #13
Roostre
Roostre's Avatar
I squeezed seam sealer into my drip rail for a second time tonight. Hopefully I did good prep work and it will stick this time.
Old 09-05-2022, 07:00 PM   #14
Roostre
Roostre's Avatar
After yard work this afternoon, I went out to check on my seam sealer. It turned out really well and seems to be holding great. I also sanded down the body filler in my rear roof seam. It also turned out really well. I think some high build primer and a little more sanding, and I should be able to get back to the bottom part of the cab.
Old 03-24-2023, 10:38 PM   #15
Roostre
Roostre's Avatar
Finally, what feels like a long winter has started to let up. Much of our snow has melted, and the temps are climbing to the point that the nipco doesn't run constantly in the shop. I got out and was able to spend a few hours on my cab corner tonight. It is tacked in. I need to do some cutting and adjusting around the door frame. I also got a little carried away cutting the old corner out and will need to make myself a small filler strip for the back of the cab, but it is mostly fit in place. I needed some headway to get re-enthused to tackle the rest of the cab. Only one picture for tonight, but it feels good.
Old 03-25-2023, 12:56 AM   #16
LockDoc
The Older Generation
LockDoc's Avatar
Glad to see you back on it. Keep up the momentum....
LockDoc
Leon
Old 03-25-2023, 01:10 PM   #17
Roostre
Roostre's Avatar
LockDoc
Thank you! I was reviewing this thread and realized that the cab corner I tacked in last night was cut out almost exactly 11 months ago. I also think I have a solid order planned for fixing the rust in the floor and lower cab area. I will lay that out in another post when I get to a computer.
I also realized that I didn't record that I covered the rear roof seam with high build primer. I haven't sanded it yet and don't have any pictures right now, but I love how it turned out. So pictures are coming on that area as well.
Old 04-04-2023, 11:29 AM   #18
Roostre
Roostre's Avatar
The passenger side cab corner is welded in and ready for some body filler. It isn't perfect, but not bad for my first attempt at a cab corner and is much better than the sheetmetal patch backed by expanding foam insulation.
I did have to cut a pie wedge out of the lip next to the door to get everything to line up. The door was installed, and the lower body lines are able to be aligned, so everything should be good. Now I am going to go over and do the drivers' side cab corner before I start bracing and cutting to replace the floor.
Old 04-04-2023, 03:18 PM   #19
HO455
HO455's Avatar
Looking good! Keep up the good work.
RIP Bob Parks.
Old 04-04-2023, 05:02 PM   #20
Roostre
Roostre's Avatar
Thanks! It's definitely not a professional job, but will be good enough for me.
Old 04-07-2023, 05:07 PM   #21
Roostre
Roostre's Avatar
I've been back in the shop doing rust replacement on the cab. Today is a sunny 56 degrees, so I decided to wander back to the other shed to take a look at the rest of my truck.
Apparently, the door leaks. Stupid predominant northwest wind through the winter. This picture may be more appropriate for the trucks in the snow thread?
Thankfully the cab is nowhere near ready to go back onto the truck at this point.
Old 04-07-2023, 11:17 PM   #22
Roostre
Roostre's Avatar
I worked in the shop for a couple of hours tonight. I got the driver's side cab corner cut out. I cut it at a slightly different spot from the passenger's side, just below the factory stampings in the rear of the cab. I'm hoping that this will make it easier to align and weld in. While this corner wasn't as rotten as the passenger's side was, there was still plenty of sheet metal riveted in place and covered with body filler. I'll have to cut my patch panel to fit and weld it in another night. It feels good to be making progress again.
Here are some not very exciting pictures of the cut out.
Old 08-24-2023, 11:36 AM   #23
Roostre
Roostre's Avatar
It has been a few months since I've done anything. Hopefully I will be able to get back into the rust repair on my cab. I did manage to get the driver's side cab corner welded back in. Cutting below the factory stampings did make it easier to align the patch panel and weld everything in. Unfortunately I didn't get any photos. Now I'm on to patching a couple of rust spots in the firewall. After that, I will be bracing the cab and removing the complete floor and rockers. It should be exciting, for me anyway.
Old 01-07-2024, 09:28 PM   #24
Roostre
Roostre's Avatar
It has been a while since I've been able to work on the cab repairs. I finally got out and removed the patches that someone riveted onto the interior floor of the cab where the floor meets the firewall and the inner A pillar. There is a disappointing, but not unexpected, amount of rust there. I'm more glad than ever to be doing a complete floor. I plan to just patch the lower parts of the firewall, there is a section about 7 inches by 3 inches that I cut out on the driver's side and another area a little larger that I will be cutting out on the passenger's side.
I got the driver's side cut out and a patch made. I didn't weld the patch back in for a couple of reasons.
First, I only had 22ga. sheet steel laying around, and I think that may be a little thin. I was really happy with how the patch turned out, it wasn't bad for a guy with a vice, a hammer, and a cheap Harbor Freight break. I was able to find some 16ga, and hope to make the patch out of that.
I also need to patch in the bottom of the A pillar, and that will be much easier without this piece of the firewall and with the floor out.
Next up will be to cut out a similar area on the passenger's side. That also won't be welded back in until I am able to patch the lower A pillar.
Here's some pictures of the area, the cut, and the patch. Enjoy.
Old 01-07-2024, 09:30 PM   #25
Roostre
Roostre's Avatar
Here are a couple of close-up pictures from outside the cab showing the damage to the lower A-pillar. I think I have my work cut out for me in this area.
