08-05-2020, 12:10 AM | #101 |
Well I have been busy between work and projects at home. I haven’t accomplished much but I finally was able to get some more body work and then lay some more paint down.
My lines on my color break are not as crisp as I would like. Any tips here would be great. For some reason my white paint bled through the tape. I am using 3M tape that is supposed to be designed for this so I am not sure what I am doing wrong. I would like to figure this out before I paint the cab with the two tone. Posted via Mobile Device |
08-05-2020, 12:25 PM | #102 |
Re: Grandpa’s 63 C10 build
Welcome back J...I was wondering what happened to you! After you lay the tape down are you going back and pressing it down with a bondo squeegee or a credit card or your fingernail or anything? I always make sure I press down firmly before I paint. What 3M tape are you using? I think I use the green 3m tape for lines like that.
08-05-2020, 01:09 PM | #103 |
I use 3m fine line tape 3/8" then mask with blue tape and paper....Front end looks good....maybe some gold lettering, for Idaho.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
08-05-2020, 02:46 PM | #104 |
Thanks guys. Yes I am using the green tape, I believe they call it fine line tape. I have been pushing it down but haven’t used a tool. I guess thinking back I was just pushing it down with my hands. I will try using a credit card. Thanks for the advice guys!
As far as the busy goes, I have been building a retaining wall around my so called daylight basement. Here is a pic of the hole I had to dig! Just got the footing poured yesterday. Next is the wall. Thanks again guys, love the support and advice. Posted via Mobile Device |
08-05-2020, 02:48 PM | #105 |
08-07-2020, 05:11 PM | #106 |
On your rad support where it's painted white can I suggest you put some flat or satin black just behind the grill like they do from the factory? I find it doesn't look good when you see color behind the grill. Keep up the good work!
08-08-2020, 09:16 PM | #107 | |
08-09-2020, 08:19 AM | #108 |
J...Just read your build thread and first off hope the Covid has passed and all is well.
Your truck is looking awesome, what makes it even more special is that is a family truck which is really cool. Im looking forward to watching the rest of your build.
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
08-09-2020, 04:38 PM | #109 | |
Thanks man! I am hoping to make some progress here soon. I have a LMC package that should be here tomorrow. Doing this on a tight budget as most of us here are doing. I have really enjoyed all the support and advice from this forum. Thanks for following along. I can look for hours at everyone’s builds on here. Posted via Mobile Device |
08-09-2020, 11:35 PM | #110 |
60-66 Nut
Your PM box is full and I can't reply to your PM.
08-10-2020, 01:33 AM | #111 |
08-10-2020, 01:36 AM | #112 |
Well tonight I got the front end bolted back on, brake master bolted and bench bled and a bunch of under hood parts painted. Still need to put some flat black behind the grill. Posted via Mobile Device |
08-10-2020, 08:41 AM | #113 |
Go to your Private Messages...click on the box of the messages you want to delete so there is a check mark in the box, then go to the bottom of the page and choose "delete" and press "go".
08-10-2020, 08:44 AM | #114 |
Looking good! I am almost to that point. I got a "new" radiator support from John. I blasted it this weekend and painted it...now I need to install it if the rain will stop!
08-10-2020, 11:57 AM | #115 |
Okay, so the problem was I was doing everything from my Iphone. I had to log onto my account using a PC to delete the messages.
63 C10 |
08-10-2020, 07:57 PM | #116 |
Looks really Good..Grandpa would be proud for sure
08-11-2020, 12:54 AM | #117 |
Thank you! My aunt who I have a great relationship with doesn't know I am fixing this truck up. Grandpa being her dad, I can't wait to surprise her with it the next time she comes to town. I hope to have it finished before then. I know I will get a teardrop or two! I know it will mean a lot to her.
I actually led grandpa's funeral procession to the cemetery with this truck. I know that might sound pretty redneck, but it meant a lot to the close family.
63 C10 |
08-11-2020, 08:25 PM | #118 | |
08-14-2020, 09:02 AM | #119 |
Okay, I have seen some different posts on here about front fenders.... I ordered some because mine are shot. All I can say is wow! If a product sucks this bad you should do something to fix the issue! I am at a loss. Triplus absolutely sucks! They aren’t even the right length!
Anyone have any suggestions? Posted via Mobile Device |
08-14-2020, 11:51 AM | #120 | |
I bought a set of aftermarket ones..ONCE. it cost me more trying to get them to line up and fit
08-14-2020, 01:02 PM | #121 |
Yeah, I am going to attempt fixing my original panels but I am super nervous. I hope and pray I don’t mess it up!
63 C10 |
08-14-2020, 10:45 PM | #122 |
60-66 Nut
Yes I always recommend repairing your original fenders if at all possible. Even those that a lot of people say are shot are still repairable. You will spend that much time or more, reworking the repro fenders.The repro front fenders have always been crappy. They will never correct the poor quality issues because everyone keeps buying them.
08-29-2020, 05:25 PM | #123 |
Finally got out to the shop to work for 10 minutes! Man life has been busy!
08-29-2020, 05:29 PM | #124 |
Got the grill painted, new headlights and bezels, radiator painted and a couple more little things done like power steering hoses and a couple other things. Starting to take form. Now I need to spend some time cutting up these crappy full fenders to patch the originals
08-29-2020, 08:53 PM | #125 |
Looking real good!!!
