Old 02-23-2021, 09:50 PM   #101
lower50's
lower50's's Avatar
Re: Project: Tow-Rat (Lil' Blue)
Well you won't have a range problem that's for sure.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-26-2021, 09:03 AM   #102
6DoF
6DoF's Avatar
new power steering pump n bracket to delete the factory vacuum pump gives me all kinds of room for motor mounts! and one less oil leak.
drew up the shock mounts. decided to use RS9000XL shocks for the adjustability, so i hit up service and got a PDF with every shock they make listed with lengths and eye's. took a bit to go thru, but found some.
also sandblasted a factory bezel before i made a backing to mount gauges. the plate is actually CORTEN and will most likely get a clearcoat to keep that look. at this point i'm leaning towards one gps Speedhut speedo centered low, and 2 Banks iDash datalogging gauges above. can display anything and everything i'd ever want, plus datalog and tune the 12v when i start playing with it. i probably won't order those until i get the body back on the chassis for good though.
6DoF is offline   Reply With Quote
Old 02-26-2021, 09:29 AM   #103
6DoF
6DoF's Avatar
so i'll be really disappointed if i never get the chance to throw way too many PSI's at this motor. with that in mind, and my current record of blowing out drive shafts, i wanted to make sure i gave this every chance to live. enter the 1410 series u-joints, ram used them factory on some HD applications and is what the truck-pull guys will upgrade to as well.
i need a 2pc drive shaft just for length alone, and to get out from under the cab easier. i also wanted a CV rear shaft with the CV flange fixed right at the truck arm pivot. this would give me the "perfect" shaft angle thru the entire range of travel. this all meant that i needed a fixed carrier bearing at a different angle than the forward shaft, so really you could maybe call this a 3pc drive shaft. the carrier bearing or mid shaft, will be at the same 6.5deg as the transmission and have a standard shaft between the trans to bearing. the bearing will be fixed to the chassis and give me the fixed CV flange output to the axle.
so the offroad rock racing guys also use 1410, and Branik Motorsports sells this ultimate carrier bearing. however they only sell it with a standard yoke on both ends. Dodge used a 1410 CV in the front of some 4x4 trucks, and dimensionally i figured it could be used in the assembly. i bought a used yoke, mailed it to Branik, and they machined it to work! 32spline chromoly shaft, shimmed bearing pre-load, and ready to weld in. can't weld it with the bearings in there, so once it's fit i'll pack it with grease and install the seals.
Old 03-01-2021, 08:46 AM   #104
6DoF
6DoF's Avatar
small weekend update ... i ended up sleeping more than anticipated cuz my plate order didn't show up. stupid USPS. i guess i also worked on the street jeep some, wired up new Hi/Low heated seat switches Rain this weekend washed the roads clean so i can start driving it to work again!
got the front shock mounts all dialed in. also got the front clip body mounts all figured and ready, but didn't finish. maybe i'll do that tonight.
if anyone is interested, the mounts are made from old ford truck bolt-on mounts that i cut up. i've used them a lot on jeeps before, they are a great starting point.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 03-01-2021, 10:33 AM   #105
lower50's
lower50's's Avatar
Ya I think you will have a hard time braking that, but I don't think your poor little 1/4 drive impact with that huge socket on it will have enough torque to tighten the nut properly
1951 MG TD
Old 03-01-2021, 11:12 AM   #106
6DoF
6DoF's Avatar
i was an engineer with DeWALT Cordless for 7 years before coming back to Pittsburgh, i have a few other toys i could use
Old 03-02-2021, 09:37 AM   #107
6DoF
6DoF's Avatar
oooohhhhh yeah! she officially holds her own face finally!
you might also notice that i chopped out the rad mount and welded it back in. it used to stand proud of the support, but i made it flush to gain another 1/2" of clearance. was going to go further, but this was easier and still helped.
Old 03-02-2021, 11:02 AM   #108
youngrodder
youngrodder's Avatar
Very nice....we need to see a picture with the front sheet metal and laid out.......
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-02-2021, 11:33 AM   #109
lower50's
lower50's's Avatar
1951 MG TD
Old 03-02-2021, 01:06 PM   #110
6DoF
6DoF's Avatar
yes sir!
so page 2 post 62 is pretty close picture ... but i have to wait til the engine is mounted to move it off the current blocks. my plate should have been in on friday, but USPS sucks pretty back and no estimated arrival now.
Old 03-03-2021, 08:36 AM   #111
6DoF
6DoF's Avatar
so that's not going ANYwhere. a little alignment, a little more strap rubber, a few hoses, n fill it.
Old 03-08-2021, 08:27 AM   #112
6DoF
6DoF's Avatar
"Make the noise!"
Old 03-08-2021, 08:32 AM   #113
6DoF
6DoF's Avatar
she now holds the 12v! I'm super happy with the fit/function of these mounts, they aren't going anywhere. but they just lack something, they don't have the same style as other bits on the truck. they are missing with my eye, but unless i come up with something super easy, they aren't getting changed. front of the crank sits 1/2" passenger, and the trans output is 1/4" passenger to help gain clearance for the starter (and a throttle pedal)
Old 03-08-2021, 10:17 AM   #114
youngrodder
Nice job on the motor mounts. They should work. They look very robust.
Marc
Old 03-08-2021, 10:09 PM   #115
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
Originally Posted by 6DoF View Post
"Make the noise!"
Clearly you havent made enough brackets to appease the digital level. Or you probably forgot to put the kettle on. BadObsessionMotorsports
GreasyLikeaBurger is offline   Reply With Quote
Old 03-08-2021, 10:21 PM   #116
6DoF
6DoF's Avatar
Old 03-08-2021, 10:38 PM   #117
6DoF
6DoF's Avatar
YYYEEEEAAAAAAAHHHHHSSSSSSSSS!!
I might have done some things out of order n had to re-do em ... But she's officially hanging. The crossmember should be good for the chassis, was easy in n out, and won't let that trans go anywhere.
I love the flat belly pics, b/c racecar
Old 03-09-2021, 03:43 AM   #118
lower50's
lower50's's Avatar
Nice job!! Will the rubber in the motor mounts give enough for the shake of the diesel? Love your tube work.
1951 MG TD
Old 03-09-2021, 08:36 AM   #119
youngrodder
Love your fab work. The braces and motor mounts look great.
Marc
Old 03-09-2021, 08:40 AM   #120
6DoF
6DoF's Avatar
thanks! i do love my bender
so on the bushings ... i guess we'll find out! i used similar poly bushings for engine mounts on the GM 6.0L in my other Jeep, and they're great. a buddy who has a 12V in a square body used windshield installation urethane to inject his factory Ram motor mounts to fill all the voids. not only does the built engine move a lot less when romping on it, but i actually thought the vibration harshness in the cab was better. it was really different from the stock Ram i drove. i don't know what their original build metrics were for NHV, but i've never thought any factory decisions were the right compromise for me.
side note: if you try and shake the motor, because of the preload in the bushings with the weight, there is NO give in the bushings and the whole chassis moves. if you try and wiggle the trans tail shaft back n forth without the crossmember, the engine mounts only let you muscle it maybe 1/4" total motion. she's locked in
Old 03-09-2021, 08:51 AM   #121
6DoF
6DoF's Avatar
Marc
Ditto, thanks!
Old 03-12-2021, 08:41 PM   #122
6DoF
6DoF's Avatar
made some shocking progress this evening
Old 03-12-2021, 08:44 PM   #123
6DoF
6DoF's Avatar
got the carrier bearing mounted finally now that i knew the angle of the trans output. the sucky part is that i have to knock the bearing races out to fully weld it.
i do have some drive shafts i can start cutting up for temporary bits for the first test drive and sorting everything out.
Old 03-12-2021, 08:54 PM   #124
6DoF
6DoF's Avatar
one thing i really want this to be is reasonable to drive for long distances on the highway. that's going to require a new rear gear to really get there, but I'm starting with noise and heat. while researching mufflers and killing drone on big exhaust for the 12v, the ONLY thing that everyone agreed on was that these resonator/mufflers are the best thing going. even adding another standard muffler after it for a great note that is actually more quite then factory in the cab. but it looks super screwy
my next issue is getting a 5" exhaust to go anywhere reasonable. i have always planned to run it down outside the frame on the passenger side with a side exit in front of the running board. the running board might now get scrapped for a 2nd muffler, but i'll save that for later. the real issue is going to be getting the exhaust around the frame, tire, shock, and body! if building this frame again, i'd move the 45deg section back by 3" to gain enough space to turn a 90 in plane with the ground and then turn a 90 straight up inside to the turbo. as it stands though, i have 5.5" between the floor and frame. i was thinking maybe i would just run a 4" down to the rocker, but now maybe i can crush a 5" down to a 4" tall oval locally there. we'll see, this will be a project.
Old 03-15-2021, 08:07 AM   #125
6DoF
6DoF's Avatar
this next bit of fab is going to make a few of you twitch
off road fab'd some drive shafts for test fitting and set-up this weekend. but will also most likely start driving on them too. section out or in whatever length you want, clamp with angle iron on 2 sides to keep the tube straight and weld it back up. jump around a lot and to the opposite side each time to keep from warping it, grind off the top of the weld to minimize extra weight working against the balance, but leave the weld proud for extra material at the joint for strength.
i have actually had very good success doing this with perfect balance at 80mph, and living years under jeeps being beat off road. just not the prettiest, or well accepted solution.
had to make a little clearance on the fwd shaft to the crossmember. held a sharpie on a pc of 1/4" plate and spun the shaft to get about 1/2" clearance. if the chassis twists enough to get that to contact, the solution isn't more clearance but adding a roll cage this shaft is 1410 joints, and will eventually just get a new professionally balanced pc.
the rear shaft helped me set the rear pinion angle and check it thru travel. at full droop i set the pinion 2deg below the shaft to allow for a little motion up under torque loading. at full compression the pinion is only 1.2deg below the pinion, so ride will be somewhere in the middle. axle perches are officially tacked in place, making the axle DONE and ready for final weld/paint. this shaft is a junkyard 1350 cv, eventually i'll get a new 1410 cv unit and have to change the yoke on the axle at the same time. that's probably also a good time to get better gears and limited slip installed.
i'm quickly running out of things to fab and procrastinate doing the floor ...
