11-24-2022, 06:13 PM | #101 |
Re: CPP Rear Disc Brakes not bleeding!!
The Bleeder must point up always, also the E-brake cable is routed to connected under the axle tubes, not over it. This is a dead giveaway that the orientation is incorrect. Swap everything to the opposite side.. that will put the bleeder facing up an the e-brake connection will be under the axle tubes.
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC Last edited by PowerdbyChevy79; 11-24-2022 at 06:27 PM. |
11-24-2022, 06:30 PM | #102 | |
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
11-24-2022, 06:34 PM | #103 |
Post Whore
I'm not sure rotating the unit so the bleeder is on the top is going to work without other modifications. See photo.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-24-2022, 11:14 PM | #104 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
What other mods would have to be done? The pic you posted is very close to how those calipers should be mounted. The twist in the brake line could be relieved and the excess cable hanging from the e-brake could be trimmed. That would clean up the look and allow the guy to properly bleed those calipers. You dont need the Motive Bleeder but if you already have it then by all means, complicate the procedure and use it. Dont let the e-brake cable dictate the caliper position! You may need to temporarily disconnect the e-brake cable so you can rotate everything without fighting the cable. Same goes for the brake line, the banjo fitting may need to rotate to relieve that twist thats in it. That type of e-brake is used on go carts and four wheelers and shouldn't even come into play until the hydraulic brakes are functional. Then route your e-brake cable in a least resistance fashion.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
11-24-2022, 11:35 PM | #105 |
Absolutely not! In fact, take the e-brake cable off the caliper until you get said caliper orientated and bled, then reroute the e-brake cable, reconnect it and trim the excess cable. This is what your looking for or real close to this position.
11-25-2022, 07:06 PM | #106 | |
Post Whore
11-26-2022, 10:52 AM | #107 | |
Mine came from Quick Performance with my 9 inch . Like I said I had to remove the front caliper bolt point the bleeder up and it bled fine .
11-26-2022, 11:02 AM | #108 |
I just hope the old boy we're tryin to help realizes that those brake kits regardless of who manufactured them, all share the same fundamental requirements. That e-brake is mechanical, not hydraulic and can be routed anywhere suitable. Let the correct caliper position tell you where to route each system, anchor them and your golden...
11-27-2022, 07:14 PM | #109 | |
That is exactly how i have them installed, per the manf. Instructions. However i just swapped the brake bracket from on top of the axle to below the axle and now i am able to bleed the brakes. Now i just have to figure out the pedal positioning and why i have to push it almost to the floor for the brakes to engage. Again, rotate each picture clockwise 90 degrees. I dont know why the post keeps rotating my pictures. Last edited by Tx70Gmc; 11-27-2022 at 07:22 PM. |
11-27-2022, 08:18 PM | #110 |
Glad you were able to get them bled. Rotated
11-27-2022, 08:45 PM | #111 |
Did you try moving the pushrod up one inch on the pedal?
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
11-27-2022, 09:08 PM | #112 |
11-27-2022, 09:39 PM | #113 |
Then try moving the rod back to the original position.
11-27-2022, 10:18 PM | #114 |
