Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-09-2025, 04:43 PM   #1
NDM
Re: Bucketlist Blazer -Restomod build 6.6liter L8T
Trans cooler pretty much complete.
NDM is offline   Reply With Quote
Old 02-09-2025, 04:44 PM   #2
NDM
Originally Posted by ndm, post: 6338817, member: 3745
I think I may have a potentially aggravating issue brewing up for this swap. When I keyed on to test that everything would fire once I get fuel lines complete, I went to test the 6l90E trans and got an error message. No communication. After researching for a while, many people have had the same issue. I went through some of the troubleshooting steps that folks recommended and still I get no comms to the trans. I have a feeling that this will be a long process to figure out and fix the problem. I think the motor is going to fire right up again but I have a feeling that driving it may take some effort because of the tranny. Eventually I will get it. Hopefully it will not be as bad as I expect.
Replying to my own post. I found the issue with the no communication issue. When I posted the last post, I was on my way to a week long cruise. During the cruise, I concluded that there had to be something that I did during assembly when I converted from 2wd to 4wd. Well that was it. The barrel/ seal that inserts between the 6l90e tcm and the harness was not locked in properly. When you install the TEHCM controller (tcm) you have to seat the seal from the outside the trans into the controller and lock the lock inside the controller. It appears that I locked the lock before I seated the seal. It took me 5 min to fix.
1.Dropped the pan
2.Removed the harness connector
3.Unlocked the lock
4.Removed the seal
5.Reseated the seal
6.Locked the lock
7.Plugged the harness connector back in properly
8.Plugged the Holley 6l90e controller and verified that there was communication.
9.Said "F^ck Yeah"!
This means that the truck should in fact be able to drive once I finish the tank fab and running the remainder of the fuel lines. This is very good!
The seal that I am talking about is shown being unlocked at 4:49 and removed at 5:02 in this video
https://www.youtube.com/watch?v=Q1d4yPzGx-A
Old 02-19-2025, 08:12 PM   #3
NDM
Placeholder..... Definitely going to need this video in the future. For now I am good but 100% need to save this video!!
https://www.harrop-usa.com/lt-tvs2650-engine-kit/p196
https://www.youtube.com/watch?v=07K3LkpsXwk
Old 02-22-2025, 11:26 PM   #4
NDM
I am pleased that I have finally sorted out my fuel pump module and sending unit setup. as of tonight, they are both installed on the upper quarter of the stainless fuel tank. Everything except the sending unit is made with 304 stainless and bolted with stainless hardware. of course the fittings are aluminum but I have made this thing E85 worthy. Tomorrow, I plan to remove these parts and finish welding the tank together. I had to make sure that the holes for everything were cut before I could weld it together completely.
Once the tank is done it should go pretty quick as I have the rest of the swap tasks already 95% complete. I have a couple wires to complete for the fueling and I just need to connect the old and ignition wire to the new Holley ignition wire.
Old 03-04-2025, 11:11 AM   #5
NDM
Every time something works out on this build, I get so happy. Tonight, I realized that all the planning that I have done was successful. I fitted the stainless tank in place and it fit as expected. I did have to trim about an inch out of my factory rear crossmember but the plan was to just not have to move it completely. That would have caused so much more work and planning. The tank fit about level with the top of the rails and now I have the precise locations where I need to put the fuel filler neck and tank vents. This is very good. This is the last big piece of the puzzle. It will not be too long now!
I will have to make some beauty panels for the tank but as of now I have 18.5 inches of ground clearance to the tank. It also fits within the departure angle of the rear. That means that I will drag the rear bumper before I hit the tank. This thing will likely never see hard offroad duty. I am turning it into more of a street machine. If by chance I ever damage the tank though, I could drop my custom fuel module into a 21 gallon factory replacement as they are within a quarter inch of the same depth.
Old 03-04-2025, 11:13 AM   #6
NDM
Tank filler and two vents are welded in. I used leftover 1.5 inch stainless exhaust tubing from my Honda chopper exhaust build for the filler. The vents are just stainless 3/8 90 degree barbs that I got off Amazon. I pressure tested and welded up any holes before I added these three so I know that the tank will be leak free once I add a viton seal to the sending unit and fuel pump module. It appears that the stinking teflon does not seal well. The viton sheet should solve that. I still have to fab up either tank straps or tabs to hang the tank. I am leaning toward tank straps like factory. I have three pieces of 1/8 in thick stainless bars that are 1.5 in wide x 48 in long. I can bend them up and drill a couple holes and be done.
The only thing left to weld is the 5/8 in filler neck vent. Hallelujah!
Some of my welds are not too bad. Others are not great but oh well.
Old 03-05-2025, 02:09 AM   #7
Richard
Enjoy seeing the progress. Keep at it!
Richard
Old 03-05-2025, 02:08 PM   #8
NDM
Thanks. I am hoping to have the tank installed and plumbed this weekend. By next week I should be able to drive it.
Old 03-06-2025, 04:08 PM   #9
NDM
Super happy! I bought a cheap ( not really) press brake from harbor freight just so I could make 1/8 in 304 stainless tank straps. I just need to drill the holes and I can hang the tank. My sheet metal brake was not up to the task and kept making radiused bends on my test piece. Glad I tested it before ruining my 48 inch long straps.
I am seriously debating adding a -8AN drain port to the tank. I would attach a long -8AN tube to it to allow me a drain line directly into a gas can or bucket. I have the stainless bungs and it would only take s couple minutes to weld up. The tube would be secured high up above the tank. I could just add the port and use a cap. That would work too.
Old 03-07-2025, 07:31 PM   #10
jaros44sr
jaros44sr's Avatar
Being able to drain the tank is always a good idea just MHO
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-07-2025, 08:49 PM   #11
NDM
Yeah. I am just tryinhg to decide where I want to put it. Front, side, rear, centered,etc. The -AN 8 port will allow any debris that could get stuck in the tank to be flushed out too.
Old 03-13-2025, 10:08 PM   #12
NDM
Last minute addition. I added the -8AN fitting to the front passenger side of the tank to allow easy draining when needed. There will be either a cap installed or a fitting with tube ran high up. The tube will allow me to drain fuel right into a gas can whenever I want to. It will normally just sit unused. I really debated this but decided that having the ability to drain the tank easily is better than not having the ability. This way I can get 99.99% of the fuel out when I need to. The aluminum surrounding the bung is drawing heat out of the hot welded metal.
An additional benefit is that if I wanted to or needed to, the return line could be plumbed here since it is at the very bottom and would be submerged. That would allow me to run a third fuel pump if I ever wanted to run a gazillion pounds of boost! Lol!
I posted a quick video to youtube for folks that are looking for an answer of what to replace their broken or lost factory u-bolt for the tank straps. Posting it here in case someone finds their way to my build. This is also a place for me to document my journey. I still look back at my old builds to find answers to things that I built a long time ago.
http://https://youtu.be/EkmTsehdTZA?si=8c6rPq0VkqEU833T
Old 03-14-2025, 10:45 PM   #13
jaros44sr
jaros44sr's Avatar
Nice work now is the time to check for leaks
SAFETY FIRST
AS usual, off topic
Jim
Old 03-18-2025, 03:10 AM   #14
Richard
Congratulations on the work moving forward. Looks like you have a path forward. Hope you get past the bug. You have more stamina than me. When I am working a lot I find it difficult to move forward at a steady rate. Thankfully for me it has been slow at the body shop and I have made a lot of progress in the last few weeks.
Richard
Old 03-20-2025, 10:03 PM   #15
NDM
These two videos have been sooooo motivating along the way. White C10 with the same motor as I have. I am not sure if he is cammed and stuff like me but the results should be similar but with the ability to do 4wd takeoff! I have watched these on repeat probably 100 times each!
It does not help that I dream of living in the southwest!
This is the website link to that c10. Looks pretty factory install to me. That means that even though I will have 8 inch more tire height, I should also have over a hundo more power to make those babies spin.
https://totalcostinvolved.com/testim...holas-vincent/
https://www.youtube.com/watch?v=gaew0Ia0JRI
https://youtu.be/X_aZ5tX3d38
Old 03-21-2025, 01:42 PM   #16
jaros44sr
jaros44sr's Avatar
Looks like you have some leaf spring bushing repair in your future maybe spray some penetrating fluid on it now….
Nice work on the tank straps. How’d the clamps turn out?
SAFETY FIRST
AS usual, off topic
Jim
Old 03-21-2025, 01:44 PM   #17
NDM
Phase 2 includes 4 links with Johnny joints. I will lube them for now though. Thanks.
Old 03-21-2025, 03:57 PM   #18
NDM
Needed to run-
-fuel
-power steering fluid
-tranny fluid
-coolant
Needed to drive-
-fill diff
-fill transfer case
-install driveshafts.
-install cowl with antenna
-install grillwith lights
-install bumper with lights
-Secure the air filter/make a box for it
Non essential stuff to do-
-Run exhaust past axle and out the back
-wiring cleanup inside the cab.
-add a 6l90E dipstick
-belly pan beneath the fuel tank
I will 100% be hearing this thing run again within the next 24 hours. I need to let the Ecu and motor talk to each other for a while to learn each other. I will cycle everything and look for leaks.
I plan to drive this thing by the end of the week!
Old 03-23-2025, 01:13 AM   #19
NDM
Filled the power steering reservoir., Trans fluid, coolant, and added 2 gallons of fuel. I had my son standing by with a fire extinguisher and when I went to start it, I realized that the main vehicle fuse had popped. Likely due to all the work. I did some tests to make sure that there is no shorts anywhere and did a prime with the secondary fuel pump straight to the battery. I will not be able to start it until I grab a couple of the fuses tomorrow morning. I could jump it across the terminals but I would rather have another fuse pop to warn me of any potential problems. The good news is that there is no leaks so far other than my goof up where I put too much tranny fluid in. I forgot that I need to start it, let it warm up and work the fluid through the cooler lines. OOps!! I cleaned the bloody mess up and popped the plug in to avoid any more leakage.
If all goes well tomorrow, I should be able to run it and let it start learning. It is too bad about that fuse. I was looking forward to hearing the roar again.
Needed to drive-
-fill diff
-fill transfer case
-install grill with lights
Old 03-23-2025, 11:41 PM   #20
NDM
I bought a new starter since my buddy at the store cut me a deal. It helped alot but there is still something wrong. I do not seem to be getting spark. I think it is a crank issue but will troubleshoot with holley possibly tomorrow. I am so bummed out that I have not been able to start it. I had it running on the engine stand so it has to be something small and silly. I have fuel pressure. I upgraded my starter wires to 0 guage since the tiny 6 ga was warm during crank. The engine grounds are 0 ga. The battery and alternator is 0 ga. Wtf??? I loaded the tune into the ecu again.
Oh well. Maybe tomorrow then.
Old 03-24-2025, 12:49 PM   #21
NDM
We have liftoff! I have a noise to investigate which I think is a power steering noise but I will remove the belt to isolate whether it is a motor noise or pully noise.
If all goes well, I will record the video and upload.
a few moments later-------
YEEESSSSSSSSSSSSSS!!!!!!!!!!!!
No motor noise other than louder dual springs. The rumble is SICK! Feels like a big block rumble. I can breathe a little now.
Old 03-24-2025, 05:54 PM   #22
NDM
Good news/bad news
Good news- Found my noise and it is not the power steering or the alternator.
Bad- apparently the water pump was damaged in the donor's accident or possibly there is something inside the pump because it is the source of the noise. They are not too expensive but I have to basically tear the whole front of the motor off to replace it.
This was the donor so I cannot be too mad about it. I should be able to have one quickly but I have to strip all the hoses off and hopefully not drop all of my expensive coolant. Should not take more than a couple hours with the coolant drain.
Old 03-24-2025, 05:55 PM   #23
NDM
Water pump will be here tomorrow. I can still start it but just not for too long. Here is a short video as proof.
https://youtube.com/shorts/xfJ3r2TsB...vX2Yc_jjzBD8GZ
Old 03-26-2025, 12:07 AM   #24
NDM
Next issue. The truck warms up slow but once it does, the temp shoots way up there. It is a brand new water pump and the radiator that I was using with the small block. I know I need to run a shroud to allow the fan to suck alot of ir through the radiator but the temps are not acceptable. For now I can let the fan run wild at 80% duty cycle but I gotta get this sorted. I will order up a lower thermostat. The factory one is like 200 degrees.
So the truck is running and learning. I plan to get the driveshafts in and button it up enough to drive this weekend. This is a great time. Finally I have success.
Another issue is the flex fuel sensor does not seem. To be sensing the ethanol. I am sure there is a simple wiring reason. I will find it.
Did I mention that this thing rumbles like a big block? It is fantastic!
Old 03-26-2025, 08:38 AM   #25
NDM
After a little research this morning, I realized that the temps should not be a problem. GM designed these things to run around 210 degrees +/- 10 degrees. I am used to motors running around 180 to 190 degrees. I am going to return my fan settings to normal and just monitor it. The higher temps apparently are good for engine longevity and economy. It is hard to wrap my head around it but I will accept it.
I am going to start putting everything back together so I can finally pull it out of the garage.
Short list-
Diff cover and fluid
Transfer case fluid
Driveshafts
Grill
Bumper
Secure some wires
Cowl
