#101 | |
![]() Join Date: Jun 2002
Re: Previous owner '68
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#102 |
I did get the other fender off. Unfortunately trying to tighten to the breaking point stripped out the threads on the bolts! So I continued drilling them out, using a good drill with cutting fluid.
Scrapping undercoating, it is a joy.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 01-20-2024 at 08:27 PM. |
#103 | |
![]() Join Date: Dec 2009
Myself ![]() I am working on one of my better half projects. I have used Wd-Forty or brake cleaner to soften the undercoating. ![]() About the drilling of those bolts. Here is my detailed process. ![]() ![]() ![]() #1= HSS (High Speed Steel) center drill the Bolt. Link: https://www.grizzly.com/products/gri...its;%20Grizzly Just an Example link. #2= Drill the head of the bolt 25% less than the diameter of the bolt. This gives you 12.5% if you drilled Off Center. Then only drill to a Depth of the head of the bolt. #3= Then take an Impact drill/ air ratchet / air gun and try to tighten them till they break off. #4= If they still spin/ Then I put Vice grips on the nut/ Then step up the drill size tell the head of the bolt goes away.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#104 |
For the undercoating I use a combination of heatgun, scrapper, and brute stupidity that seems to work well. Then, after all the scrapping, I wipe everything down with lacquer thinner to soften the stubborn spots, and scrape again.
As far as the bolts, your process and mine are almost spot on, except I usually soften up the bolts with intermittent bouts of cussing.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 01-22-2024 at 11:52 AM. |
#105 |
Now on to some previous owner type crap. i started out loving the 60-66 chevy trucks, I still love them but have lately (last 25 years) focused on the 67-72 trucks. Nothing against the 67-72 guys, but, we are a bit spoiled. The earlier trucks guys tend to be a bit more more creative on getting things done. When I started out with a 64 chevy there were NO aftermarket parts for them. No fenders, no bumpers, no inner fenders, no NOTHING! Everything we did had to be a homebuilt solution.
One of the early things I did on my 64 was convert a 3-on-the-tree to a floor shifter column. I decided to do this on the 68. So here goes some old school tech...
#106 |
My disassembled 3 on the tree column. The truck is a 505 exterior but the column is 503, I guess this makes sense, I have seen this before.
#107 |
Then, this. I plan on running a floor shifter (auto by the way).
#108 |
Ain't nobody got time for column shifting... Some people wonder why I might keep the shifter shaft, well, you have to, it supports the upper column cover and gives the stack-up for the column. Trust me, you need it. But you don't need those ugly old shift levers, they gotta go.
#109 |
How warm has that shop been the last week or so? Its been cold as hell.. Im guessing your roads over there have probably been iced up too. Ours sure have lol.. Doesnt look like any of this weather has slowed you down
#110 |
I have one of the Mrcool units and it usually keeps me around 66 out there in the winter (that's where I keep it set). On some of the coldest days I saw 63 in there first thing in the morning. As long as I can walk out there I'm going to get something done!
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 04-23-2024 at 10:04 AM. |
#111 |
Started filling in the shifter hole with my favorite 2 part metal epoxy.
#112 |
After more sanding, more jbweld, and some primer I ended up with this.
#113 |
I replaced both of the bearings while I was in there and checked the wiring on the turn signal. Those bearings cost way too much for what they are. I'm sure there has to be a more cost effective (cheeper!) solution but those parts guys got me by the short ones.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 01-23-2024 at 11:17 AM. |
#114 |
Dug through my paint cabinet, found some 503 in my favorite flavor, acrylic enamel. Hmmm, mixed in 2015, should be fine.
#115 |
Couple of coats, column looks okay, collars need sanding and recoat. And, yes, there is a run on the column. I pretended I was a 1968 union worker who was just about to go on lunch when I painted it. Looks factory imperfect.
#116 |
I will sometimes sneak over to the squarebody side of the board to see what the cool kids are doing these days. I noticed a bunch of those guys (at least 3 of them) are putting jeep parts on their trucks. Hey, I like jeeps too, so I started looking for a place to fit up a jeep part. In particular this odd looking P.O.S. (piece of shaft) from a 84-94 Cherokee.
It looks like it fit right on there. Ha! If you will recall I painted up a 1972 steering box to use on the truck (it was there, I used it). The shaft on that box is 13/16" splined. The hole on the intermediate shaft is 3/4". So I broke out my reamers and miraculously I had a 13/16" reamer! If you are going to do this save yourself a bunch of reaming and use the 79 up steering box. It is already a 3/4" shaft. I also think some of the earlier trucks have 3/4" splined shafts but don't remember for sure.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 01-28-2024 at 12:08 PM. |
#117 |
Then I had to deal with the column side connection. The 67 and 68 don't come with an intermediate shaft like the 71-up, so first I cut the steering shaft. I left about 1.5-2" of the 3/4dd shaft at the end.
#118 |
The column side of the intermediate shaft has a coupler for a 1"dd shaft (which the squarebody trucks have at the end of their columns). So somehow I had to get from 3/4"dd to 1"dd. Too bad nobody makes a bushing to do this... Ah but gm does! And it comes in a long enough piece that you can get 3 or 4 bushings from it.
The hardest part of this is melting out the plastic and driving the solid shaft out of the hollow shaft.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 01-25-2024 at 03:30 PM. |
#119 |
Welded the bushing to the shaft. It ain't going nowhere.
Like a glove!
#120 |
A little paint, leaned it against the work bench, it fell. I locked the shop and came in the house. Tomorrow I have the opportunity to paint it again, I could use the practice. I really should have waited on painting the column, now I have to worry about scratching it until it's in the truck. Live, and hopefully, learn.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 01-24-2024 at 09:54 PM. |
#121 |
You are a creative fella. I'm enjoying your build!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED
#122 |
Thanks joey, I like to try to solve problems, but sometimes I make new problems! This build thread is about to slow down a bit, the posting is about to change to real time! Plus I have most of the easy stuff done, next comes rust repair.
#123 |
I'm glad it's slowing down soon, your posting pace was making me feel pretty dumb about the amount of time I spend looking at my truck and trying to decide what to tackle first
Maybe I'll start a VERRRRY SLOOOOWWW thread for Big Blue.
#124 |
Slow is good. You should start a thread, there are some multi-year build threads out here.
#125 |
Worked on the column paint, not happy about it yet. Here are some pics of the shifter column and shaft.
| Bookmarks |
