Old 01-17-2025, 09:39 AM   #101
raggedjim
raggedjim's Avatar
Re: 1958 Pontiac Wagon Build
Nice work! I have started on the cab of my truck, I'm not doing as well as you are!
Rg
raggedjim is online now   Reply With Quote
Old 01-20-2025, 11:31 AM   #102
Tempest67
Tempest67's Avatar
Well, the quarter panel is on.
I finished off the inner wheel well and 'truck drop off' area, and welded the quarter on. There was also a piece at the front and rear that needed a small patch.
The weld seam will be under the quarter molding, so it will not be seen.
Overall, I am pleased with with my first home made exterior patch panel.
Time to move on to the next rusted area.
Tempest67 is offline   Reply With Quote
Old 02-10-2025, 05:24 PM   #103
Tempest67
Tempest67's Avatar
I removed the windshield and NO rust in the window channel.
The rear Passenger side window is solid, but the Driver's side rear needs work.
2 out of 3 ain't bad
Old 03-03-2025, 12:04 PM   #104
Tempest67
Tempest67's Avatar
Hey Guys
Started working on the tail gate.
The outer panel only needed a small patch, but the inner panel was gone.
....onward and upward
Old 03-03-2025, 12:06 PM   #105
dsraven
Getting serious now.
Good work
Old 03-03-2025, 12:14 PM   #106
Tempest67
Tempest67's Avatar
Thanks, a lot of pieces to make this one.
Old 03-06-2025, 12:43 PM   #107
HO455
HO455's Avatar
Great work! I have a question if you don't mind.
I can't tell from the photos as to what you did with the factory folded edge on the bottom. Did you have to cut it off or somehow unfold it and re-crimp it back down?
Thanks in advance.
RIP Bob Parks.
Old 03-06-2025, 01:14 PM   #108
Tempest67
Tempest67's Avatar
Yes, I unfolded it and crimped it back down (hammer and dolly)
1 corner, where the patch was, the metal was rotted, so I made a new piece and welded on a new 'folded' piece, you can see the edge piece hanging there in the first pic
After I epoxy prime it, a little filler will hide the welding imperfections, I hope
Old 03-07-2025, 12:49 AM   #109
HO455
HO455's Avatar
Thanks. I have this fantasy that someday I will replace the rusted metal in my spare hatch for my Burban. And after some paint I would have a nice rust free hatch.
RIP Bob Parks.
Old 03-10-2025, 10:50 AM   #110
Tempest67
Tempest67's Avatar
welded in another patch along the lower edge of the tail gate opening and a little one in the corner. Then put rear wheel on and lowered onto hoist to see new quarter patch.
Old 03-31-2025, 11:29 AM   #111
Tempest67
Tempest67's Avatar
Time for an update.
I turned the car around (I can only work on 1 side at a time) and started on making the rear 1/4 patch for the driver's side.
I used the same paper template I made for the passenger side, bought some metal, and the pics tell the story. It is not welded in yet as I have a lot of inner wheel well work to do, but it's getting there.
note, that cheap little English wheel did OK.
onward and upward....
Old 04-21-2025, 05:26 PM   #112
Tempest67
Tempest67's Avatar
Driver's side rear quarter update
you can see in pic 2 the piece I removed after the 'Cut 'n Butt'
more welding and grinding to do, but coming along
Old 06-25-2025, 04:09 PM   #113
Tempest67
Tempest67's Avatar
Hi guys
Well, work has slowed down due to other summer activities, but I was able to finish up the driver side rear window channel, and finish up the quarter and put the wheel back on. Inner wheel well finishing up will be done when the body is off the frame.
Enjoy the summer
Old 09-11-2025, 05:41 PM   #114
Tempest67
Tempest67's Avatar
started working on the tail light area with another 2 patches
Old 09-12-2025, 02:14 PM   #115
scottofksu
scottofksu's Avatar
GORGEOUS work! Thanks for sharing!
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 09-22-2025, 05:54 PM   #116
Tempest67
Tempest67's Avatar
Had a busy weekend with family stuff, but was able to do another small patch on the firewall, and more grinding needed beside that patch, but it will be easier to get at when the body is lifted
Old 09-26-2025, 12:00 PM   #117
Tempest67
Tempest67's Avatar
I finally found a pair of tail lights for the wagon (sedan and coupe tail lights are different) from Desert Valley Auto Parts in Arizona. (DVAP)
This is the first time I have dealt with them and all went well. They sent pics, gave a description, and even called me to discuss the pics. The tail lights were not cheap, but they are in decent condition and could be used 'as is' on a "driver".
pic shows the tail lights, after a quick polish, and the difference in size beside a coupe/sedan bezel
onward and upward,
Old 10-14-2025, 10:17 AM   #118
Tempest67
Tempest67's Avatar
I am back at it.
I am working on finishing up the firewall and the heater delete plate I made earlier was bugging me. (too big and looked home made...whatever it was I was not happy)
So, I filled in the semi-circle hole on the upper part, welded in some new metal aorund the square hole, and made a new plate to cover the hole. I thought of welding in the plate, but decided to go with the 8 bolts instead. I also welded up a bunch of holes that I don't want.
I am planning on a Vintage Air kit and am not sure how/where it will attach to the firewall, but I hope this will work.
Old 10-18-2025, 09:18 AM   #119
HO455
HO455's Avatar
Your firewall is looking good!
I just noticed the frame is fully boxed. Is it boxed full length? Does it have an large X-menber like later cars?
RIP Bob Parks.
Old 10-20-2025, 10:56 AM   #120
Tempest67
Tempest67's Avatar
All 1958 to 1964 GM fullsized cars had the X frame with the drive shaft going through the middle with a hanger bearing
It makes things a little different, and routing the exhaust will be awkward.
Old 11-04-2025, 12:13 PM   #121
Tempest67
Tempest67's Avatar
still plodding away at rust, this time the drivers door
onward and upward
Old 12-08-2025, 11:54 AM   #122
Tempest67
Tempest67's Avatar
Hi Guys
Working on getting front bucket seats and console mounted before I paint the floor.
I welded some feet to the seat bases, and here they are propped in the car. Now I need to make some floor braces.
progress continues, ..........slowly
Old 12-08-2025, 02:40 PM   #123
3drburb
Very impressive work!! Love it.
3drburb is offline   Reply With Quote
Old 12-08-2025, 05:31 PM   #124
Tempest67
Tempest67's Avatar
Thanks burb,
Custom work takes time, and I am trying to make it look like a period correct option. (does that make sense?)
as they say, it's your car, do it your way
Old 12-08-2025, 06:03 PM   #125
3drburb
Originally Posted by Tempest67 View Post
Thanks burb,
It make sense to me, but I am still amazed of the metal work on some of the repair, and like the use of the newer Pontiac parts.
As for doing it your way I totally get it as I have deeply cut and modded my 64 Olds Cutlass that I have owned for about 20 years, and the only time I got nervous was cutting into my spare hood to add the 66 Pontiac GTO hood scoop.
