10-21-2009, 03:07 PM | #1226 | |
Can't wait to retire!!
Re: PO has me PO'd
And thanks, I will take you up on the offer one day soon. I'm just taking it one day at a time.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
10-21-2009, 09:28 PM | #1227 |
Back in the sticks
Re: PO has me PO'd
I leave here on Monday!! Will be in Hawaii for ten days with the family for a little vacation and then back to Bremerton on the 5th of November. Check in to the ship on the 6th and probably be haze gray and underway. Thanks for the wire tags. Might be able to get that done while I'm waiting to fly out to the ship.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty Last edited by red71cheyenne; 10-21-2009 at 09:29 PM. Reason: Forgot... |
10-22-2009, 07:05 PM | #1228 | |
Re: PO has me PO'd
good luck to ya, and keep in touch
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-22-2009, 07:27 PM | #1229 |
Re: PO has me PO'd
same boat. a guy painted my father-in-law's 70 truck in like 97 or 98. My 69 rusted so bad the cab was sitting down around the mounts. I tried for years to buy the 70 from my brother-in-law. He finally gave me the truck and I thought I had something by running my hand along the bottom of the rockers and visually checking, eyeballing. Brought it home and in the same boat as you, the guy overlayed the rockers. Tons of work now. Scott
10-22-2009, 09:49 PM | #1230 | |
Re: PO has me PO'd
10-23-2009, 06:43 AM | #1231 |
Re: PO has me PO'd
i will get some afterwards pics. most of the rust has been cut away and replaced. replaced outer and inner rockers, one corner post, both cab corners and did some patch work on one floor pan....i will try to get some pics and get them posted. i can check things on this laptop but can't get pics posted. when my home PC is up again i can post the few before pics i have and some latter ones. right now i have parts swinging from near every rafter/truss in the building primed and will start painting parts early next week...will try to post them...s
10-23-2009, 08:33 AM | #1232 | |
Re: PO has me PO'd
Start up a build thread, let us see what you've got & how your working with it. Don't wanna Hi-Jack this guys thread... Last edited by vtblazer; 10-23-2009 at 08:35 AM. |
10-24-2009, 08:03 AM | #1233 |
Re: PO has me PO'd
well, got the electric rad. fan running, man does that Jeep /Chrysler fan blow/suck
Kinda Rube Goldberg, but I have to get a new fan shroud anyway. M&H did it again, just hooked the black and blue wires up, and grounded the temperature wire out, put the key in the on position and success. Removed about 2 inches from the shround, where the fan mounts up I may change where M&H broke out the wire, right now it comes out up at the rad. bracket. I think that it would be cleaner if I break it out down by the relay. I'll call them Monday and see if they mind
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-24-2009 at 09:03 AM. |
10-24-2009, 08:45 AM | #1234 | |
Re: PO has me PO'd
And I had a comment for that last part, but I'll leave it alone.
10-24-2009, 09:02 AM | #1235 |
Re: PO has me PO'd
10-24-2009, 09:06 AM | #1236 |
Re: PO has me PO'd
Thanks! This is a family board after all Possibly a bad choice of words on my part in retrospect
10-24-2009, 09:08 AM | #1237 |
Re: PO has me PO'd
Yep! it defiantly sux
10-24-2009, 10:17 AM | #1238 |
Re: PO has me PO'd
what years does that chrysler fan cover? I had looked back thru and did not see any info might have missed the info but interested in your setups specs. thanks, Jon
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
10-24-2009, 07:37 PM | #1239 |
Re: PO has me PO'd
Got the info off of a thread on the pickup board awhile back. A guy in northern jersey came up with the idea, supposed to be a factory fan outta a cherakee. I'll see if I can find the thread for ya. How's your floorboards coming out?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-24-2009 at 07:38 PM. |
10-24-2009, 07:53 PM | #1240 |
Re: PO has me PO'd
Thanks, they turned out really good thanks for the info. I have gotten my whole cab done all of the cancer is gone and just have a couple of welds to clean up/hammer dolly. Now i am just trying to figure out whether to pay to have it blasted or strip the rest of the years of paint myself before painting.
10-26-2009, 11:37 AM | #1242 | ||
Re: PO has me PO'd
Thanks for providing a link to your build, great work! Now I can watch what you're doin'...outstanding welds Quote:
Tough call on the epoxy, some plastics don't work well, and I have two differant types of plastic, sooo...I'll try to buy on the classified section Now, get back to sanding
11-08-2009, 11:19 PM | #1243 |
Re: PO has me PO'd
Well, rethought this thing again. Seems like the 2WD fan shroud is going to give me the most room, including the area down around the lower rad. hose.
I changed the way the PO of this shroud had it mounted up. Cutting off the two side mounts and just using the lower bottom mount for orientation. There is a gap of about 1/4" between the fan and the shroud, filled it with single sided sticky weatherstrip tape and screwed it in about 5 spots for now...seems pretty solid, but I can add 'J' clips if needed in the future Jon, if you need info on the relays I'm using, LMK Chrysler part # 52079528AB Bamms part # 0481-0320J Thanks 1SIK52 for the rear harness Also picked up some 67/68 side moulding, waiting for clips from Wes @ Classic Heartbeat
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-08-2009 at 11:37 PM. |
11-10-2009, 02:10 PM | #1244 |
Re: PO has me PO'd
Was told by Wes that there are inferior repro clips out there, so we got them from Mar-K, not disappointed even has a rubber grommet behind nut so it doesn't scratch the paint
I realize this has nothing to do with getting the truck running, but after 3 years of searching ( Thanks D. Passmore, Quality guy, I would buy from him again) I just had to see what this moulding would look like on the truck! An issue popped up on the rear wheel opening as the radius is differant on the blazer/jimmy then on a pickup truck. I see a fix, but want to try it first on a junk moulding
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-10-2009 at 02:24 PM. |
11-10-2009, 04:05 PM | #1245 |
Re: PO has me PO'd
Looking good my friend!
11-10-2009, 04:27 PM | #1246 |
Re: PO has me PO'd
So much for going off road with it...
Holly smokes Jim, is that thing lookin' nice! |
11-11-2009, 01:44 PM | #1247 |
Re: PO has me PO'd
There is only two reasons why this truck goes off road...
FISH! And a good friend sitting by a Vermont camp fire with a cold beer in a cooler Thanks guys for the comps., we will meet up
11-11-2009, 09:34 PM | #1248 |
Re: PO has me PO'd
BTW, when is the trip?
11-11-2009, 09:42 PM | #1249 |
Re: PO has me PO'd
Looking Good!
11-11-2009, 10:26 PM | #1250 |
Re: PO has me PO'd
do you have molding for the experiment? I have a few driver quality pieces...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
