Old 09-12-2012, 02:47 PM   #1226
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Kabwe's aka Bam's build
Originally Posted by Kabwe View Post
I will not be posting pics for a long time so you can stop dropping by hook head.lol
No on the real, I will not be posting pics for a while.
HOOKHEAD!! LMAO!!
Have not heard that in years. LOL
VDOG is offline   Reply With Quote
Old 09-12-2012, 03:11 PM   #1227
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by VDOG View Post
HOOKHEAD!! LMAO!!
Yeah I thought I'd get all ghettofabulous and 70's on you.lol
Kabwe is offline   Reply With Quote
Old 10-01-2012, 03:27 PM   #1228
Kabwe
Certified Car Nut
Kabwe's Avatar
Well, not really much to report other than I mocked up the hydroboost unit and plumbed the brake lines.
The morning dew makes the painted frame a not look good in the pic. But the paint is smooth and nice. I used Kustom Shop's epoxy primer and satin black. It sprayed really nice. But the paint is smooth and nice. I used Kustom Shop's epoxy primer and satin black. It sprayed really nice. So for anyone looking for some Satin black and epoxy primer for their frame this may be the ticket. It really was not expensive and you will have enough left to do your suspension parts also.
Old 10-01-2012, 03:48 PM   #1229
OrrieG
OrrieG's Avatar
No proportioning valve, 4 wheel discs?
OrrieG is offline   Reply With Quote
Old 10-01-2012, 04:04 PM   #1230
56ClassicTruck
Coming sling nicely ....
1996 Dodge 3500 4x4
1977 F250 Camper specal 4x4
1956 Chevy 3100 truck
56ClassicTruck is offline   Reply With Quote
Old 10-01-2012, 05:34 PM   #1231
Kabwe
Certified Car Nut
Kabwe's Avatar
Of course there is I'm using an adjustable one it's mounted in line towards the rear. I also have the residual valves installed, but you can't see them. Remember just because you don't see it does not mean its not there.lol Its like magic. Well not really.lol
Old 10-01-2012, 05:34 PM   #1232
JML55
JML55's Avatar
Looking good.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 10-01-2012, 06:09 PM   #1233
mknittle
mknittle's Avatar
Looking good
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-01-2012, 06:14 PM   #1234
hotrod1
56 - autocross
hotrod1's Avatar
forgot about them, hunh?
hotrod1 is offline   Reply With Quote
Old 10-01-2012, 06:21 PM   #1235
Kabwe
Certified Car Nut
Kabwe's Avatar
Forgot about what? You been around me a couple of times and you should know that I don't forget.lol I plan, change, plan, change, plan, but I never forget. I just think too much.lol
Old 10-01-2012, 06:23 PM   #1236
hotrod1
56 - autocross
hotrod1's Avatar
The proportioning valves (LOL). Just teasing you.
Old 10-01-2012, 06:30 PM   #1237
Kabwe
Certified Car Nut
Kabwe's Avatar
Did you read post 1231. I said I'm running an in-line adjustable one. Reading is fundamental at least for those of us that can.lol This is the one I have.
Old 10-01-2012, 06:32 PM   #1238
hotrod1
56 - autocross
hotrod1's Avatar
Just giving u a hard time because I can. I am sure that you have three or four of those things going.
Old 10-01-2012, 06:36 PM   #1239
Kabwe
Certified Car Nut
Kabwe's Avatar
See now you are acting like you know me. That would be my problem, over thinking it.lol I did this during mockup I did not like the clearances for my drive shift. I worried myself silly until I came up with this. It gave me about 3 inches more clearance.
Than I decided the paint on the frame was too glossy for my taste so I stripped it all off and used the Satin Black. I'm sick and I know it but at least I own up to it.lol
This truck should have been done by now. Its just sad that its not.
Old 10-01-2012, 07:05 PM   #1240
hotrod1
56 - autocross
hotrod1's Avatar
See now you are acting like you know me. That would be my problem, over thinking it.lol I this during mockup I did not like the clearances for my drive shift. I worried myself silly until I came up with this. It gave me about 3 inches more clearance.
So in other words buddy, I over think everything. This truck should have been done by now. Its just sad that its not.lol
I can tell you haw many cross members that I have done and pulled apart because I did not like them afterwards.
I found a good solution (for me only) to the cross member hitting the drive shaft scenario. Lower the engine. Get better (lower) center of gravity. I needed to move the engine back a few inches to achieve this it and had to redo the firewall. This gets me a better front to back weight ratio also. The only issue that I see is that the engine looks like a peanut in the engine compartment. Overall, a lot of work.
Old 10-01-2012, 07:22 PM   #1241
Kabwe
Certified Car Nut
Kabwe's Avatar
Yep and lowering the engine was not an option for me. I love the position of my engine. Not too high and not to low. Just right in my opinion.
Anyway I've been blocking the heck out of the cab. Its still not to my satisfaction but its getting there. Here is the firewall, its coming out pretty good but I want to block it a little more before paint. Its pretty straight but not where I want it.
Old 10-01-2012, 07:24 PM   #1242
hotrod1
56 - autocross
hotrod1's Avatar
Anyway I've been blocking the heck out of the cab. Its still not to my satisfaction but its getting there. Here is the firewall, its coming out pretty good but I want to block it a little more before paint. Its pretty straight but but not where I want it.
Yeah, lowering the engine is not for everyone. Makes it look so small in the compartment. Where did it go? Firewall looks great!
Old 10-01-2012, 07:24 PM   #1243
fabguy
Elev8r Man
fabguy's Avatar
Man that frame looks SWEEEET!!!
Great job as usual BAM!
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 10-01-2012, 07:24 PM   #1244
LEEVON
Moderator
LEEVON's Avatar
Looking good, brake lines are clean. I think we're still pretty much tied, although if I was doing any substantial amount of body work you'd be pulling ahead
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 10-01-2012, 07:36 PM   #1245
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks man its coming but I'm not quite satisfied yet. It coming though.
Thanks man. Did you get my PM with the info I promised?
Thanks man. I'm a lot further along than it looks actually. All rust repair, mods, and mockup is done.
Old 10-01-2012, 07:43 PM   #1246
oldman3
oldman3's Avatar
Everything is coming along nicely, great job...Jim
oldman3 is offline   Reply With Quote
Old 10-01-2012, 07:47 PM   #1247
fabguy
Elev8r Man
fabguy's Avatar
Yes sir I did, thank you very much.
I am going to order those soon also.
I have to lower my engine so it fits in the compartment . it sits very high due to the C-10 front clip. Plus it should help with my steering linkage issue.
1939 2 door sedan
Old 10-01-2012, 08:35 PM   #1248
Rods57
Rods57's Avatar
Looking good Bam, firewall is cool, the work now will pay off when you paint.
Rods57 is offline   Reply With Quote
Old 10-01-2012, 08:38 PM   #1249
Kabwe
Certified Car Nut
Kabwe's Avatar
Once again thanks guys. Its nice to know there are guys out there that are as car crazy as I am. So thanks for letting me know I'm not alone.
I'm glad you to the pm and about lowering that engine. Man we do what we got to do to make it work. Do you have any pics of that C-10 clip. I would like to see it.
Old 10-01-2012, 09:50 PM   #1250
fabguy
Elev8r Man
fabguy's Avatar
Here are a couple from my build thread. they are old though.
I need A arms from porterbuilt still!!
Here is a pic of the C-notch
1939 2 door sedan
