Old 11-09-2012, 04:24 PM   #1251
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by woodwright View Post
You suck man.
I can set you up with one.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-12-2012, 03:13 PM   #1252
rgreathouse
This things gonna be bad! its been inspirational for my swb 12v/nv4500 build. Does the intercooler piping clear between the inner fenders and battery box fine? ive been debating running my 2nd gen intercooler flipped upside down and relocating batterys.
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 11-12-2012, 03:14 PM   #1253
rgreathouse
Also does your hood latch clear ok? im having a tough time squeezing the 2nd gen intercooler between frame rails and under hood latch.
Old 11-12-2012, 03:54 PM   #1254
Dieselwrencher
The piping clears the battery trays, but I had to trim the inner fender on the driver's side for the intercooler piping to clear.
My hood latch will clear after I modify it. I have to cut it and move it 3/4" of an inch and do the same to the hood guide pin and it will work fine.
Ryan
Old 11-12-2012, 04:27 PM   #1255
rgreathouse
Thats what I fugured... Im thinking about running the intercooler oposite of yours and mounting the batterys under the bed.
For fitting it ill either run a 1" body or trim an inch off the intercooler... I hadnt really thought about modifying the latch so ill be excited to see that!
Have you ran exhaust yet? Its gonna be interesting to get mine past the tcase.
Old 11-12-2012, 04:29 PM   #1256
Dieselwrencher
Yep, I have 4" over the trans cross member and 5" on back. I got 4" all the way through on the 88 burb I'm doing, so it can be done.
Ryan
Old 11-13-2012, 12:02 AM   #1257
rgreathouse
We'll hope so! what radiator are you running? Any pics of clutch linkage? and hydra boost linkage?
Old 11-13-2012, 04:19 PM   #1258
Dieselwrencher
I used a stock BBC radiator for this truck. I can get you a pic of the clutch pedal set up. It was a PITA to figure out and get the rod to travel straight when the pedal moves in an arc. I'll have to remove the linkage for the hydra boost to get a pic of it. When I do I'll get a pic of it.
Ryan
Old 11-13-2012, 09:22 PM   #1259
ryanroo
ryanroo's Avatar
Real men run big radiators!
just kidding... hahaha
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 11-14-2012, 04:36 PM   #1260
Dieselwrencher
Ryan
Will you ever utilize it? Mine stays cool just fine right now. LMAO!
Ryan
Old 11-14-2012, 08:08 PM   #1261
mknittle
mknittle's Avatar
LOL does it have water in it?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 11-14-2012, 08:28 PM   #1262
mknittle
mknittle's Avatar
Lookin Great RYAN!
Mark
My GMC build.
Old 11-15-2012, 03:07 PM   #1263
Dieselwrencher
Actually, it does have coolant in it. I don't think the truck knows it's supposed to be a truck again.
Ryan
Old 11-18-2012, 08:11 PM   #1264
ryanroo
ryanroo's Avatar
What hydroboost are you using? i have the unit from a 01 dodge and it is all sorts of into the intake. i think i need to find a shorter hydroboost, or continue on with my slight modification of normal to get the unit i have on there.
i need to make sure i the ability to use an MC that has a big enough bore for the big front brakes. i think i can maybe get this one to work if i toss the factory intake horn, but it will still be close to the IP
72 K20 12v build
Old 11-18-2012, 08:42 PM   #1265
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Some of the corvette guys mount the hydroboost upside down, that might be an option.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-19-2012, 09:46 PM   #1266
Dieselwrencher
Ryan, my Hydraboost is from a 84 K30. I made a new plate and bolted it directly to the fire wall. You might have issues with as far back as your engine is. If you have to ditch the stock intake just make a flange and weld pipe to it like i did on mine. A stock intake wouldn't fit on mine either. I tried a 24v one, a 12v one may have fit. I also tried a dodge unit on my truck, but the bracket they had on the rear placed the whole mess way forward like you're saying and would have been into my injection pump. If you want a bigger reservoir, get one from a C40 or so. It should bolt on the pick up hydraboost unit.
Ryan
Old 11-19-2012, 09:50 PM   #1267
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Oh never mind. Its getting into the intake horn, I get it now.
Tony
Old 11-19-2012, 10:22 PM   #1268
ryanroo
ryanroo's Avatar
Sweet, i think i have one of those kicking around. ill have to check my hidden parts piles and see if i can make that work.
the engine set back is definitely getting me right now, but i think i can make it all fit
Ryan
72 K20 12v build
Old 11-20-2012, 08:09 AM   #1269
RatRod68
RatRod68's Avatar
There is a member on here that sells an adapter plate to run gm hydroboost setup. There is a guy on pirate running the kit on his K5 with a 6.oh in it
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 11-20-2012, 08:58 AM   #1270
ryanroo
ryanroo's Avatar
adapter plates aren't much of an issue, i can make pretty much anything i need.
i think ill need to follow Ryans path with intake.
Ryan
72 K20 12v build
Old 11-20-2012, 12:53 PM   #1271
RatRod68
RatRod68's Avatar
Ryan
I keep forgetting you moved it back so the back of the valve cover acts as your center console.
Check the super dooty ones. I have a super dooty hydroboost setup with a 95 Explorer master cyl. Everything else under the hood of the explorer is stock. If your interested, I can get some measurements
build Threads:
Leftovers 68 C20
Semper Fi
Old 11-20-2012, 03:44 PM   #1272
Dieselwrencher
Ryan, for what it's worth, I put a stock corvette master cylinder on a gm truck hydraboost in my corvette so I could run the 4 piston calipers. It works great. Maybe that's an option for you too.
Ryan
Old 11-20-2012, 09:00 PM   #1273
ryanroo
ryanroo's Avatar
I am all about dual purpose. a center console that keep the coffee warm? I'M IN! i would take some measurements if you have time, cant hurt to have some options.
Actually ive heard good things about those, i just totally forgot about it. ill probably have to bug the napa guys for some specs when i figure out WTH i am doing.
72 K20 12v build
Old 11-24-2012, 12:57 AM   #1274
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I'm also running a Corvette master on hydroboost with stock D60 discs/11.5AAM discs. Works great and doesn't look too modern under the hood.
There is a split on the Corvette masters with the later ones having a shallow indent for the push rod. I bought one for a 77 Corvette and a 1 1/8 bore and it works great with plenty of reservoir capacity.
Edit: I'm finally building my 68's D60 (after driving my Nova on snow/ice I decided to get my butt in gear) so if you can PM me your address I'll ship the GM D60 arm down to IA.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 11-24-2012, 01:04 AM   #1275
Dieselwrencher
Thanks Lowrollin.
Ryan
