#1 | |
Re: Make it handle
Think of it like this.... If the shock were perfectly vertical, then 1" of spring compression would result in 1" of shock travel and zero rotation at the mounts. Now put that sucker at 45 degrees. The same 1" of spring compression results in much less shock travel and it's had to rotate a few degrees on the mounts. So, your shock now has to "absorb" the same amount of "energy" with reduced displacement. That's about everything I know about shocks! Actually, I don't know jack about shocks, but the geometry makes sense don't it?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776
Re: Make it handle
ok, I'm in the planning stages of a tear down rebuild. I love my truck and it pains me to tear it apart cause I know this is more than a winter project but it's lasted 45 years and if it going to last another 45 some things need to be done.
I like the idea of a complete package. I know my strengths and happily defer to smarter people than me who have put together a system of parts that all works well together not the current mishmash of shinny bits I currently own. I'm looking at no limits wideride front and fatbar rear or porterbuilts dropmember and tubular trailer arms setup or hotchkis' setup Rob has mentioned several times about unsprung weight so it seems important (I know it is) and so I like his wideride setup. But for the rear, do I need a huge truck 12 bolt. Nope, the truck is never going to haul much more than a cooler. It's done it's time, paid it's dues and can now settle into a nice midlife crisis. I have a toyota to beat the crap out of. I've looked at irs but a custom setup is beyond my budget and retrofitting something like a mark VIII looks like a huge project with limitations on brake, wheel and ratio options. So is there a solid rear axle with a similar track width but maybe a little lighter? I'm not running any huge numbers for horsepower (375-400) and thank you Rob and everyone else that has contributed or asked some really good questions. |
Re: Make it handle
for my money I would go with Robs Parts first class stuff He talks the talk and most important he walks the walk
![]() Join Date: Jul 2010
Re: Make it handle
Good one, right on the money. As you change the angle of the shock away from the true path of suspension travel, the dampening rate drops. Here are some calcs from old notes.
Shock angle - Dampening 0* 100% 10* 96% 15* 93% 20* 89% 25* 82% 30* 75% 35* 66% 40* 59% 45* 50% You can see that the farther you lay a shock over, the more rapidly it looses effective dampening. These factors also hold true for spring rates, such as on a coil over shock. Understanding these relationship can help a chassis builder tune a vehicle suspension. Heres an example. Lets say you want the shock to have 200lb/in/sec (simplified term) dampening rate, but all you have available to use is a shock with a 300lb/in/sec shock. If you were to mount this shock at a 35* angle off of the true suspension travel line, you would reduce its effective dampening to 66%. So, 300lb/in/sec x 66% = 198lb/in/sec dampening rate. This relationship between mounting angle and dampening rate can be a good thing, for those who understand it, or a bad thing for those who don't.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
Re: Make it handle
Got my new copy of StreetTrucks today. looks good. WOW, I've been published! + a btchen C10 on the cover
Re: Make it handle
Mr. Thread Killer
Re: Make it handle
Looks like I have lots of reading, rereading, taking notes, comparing notes and editing notes to do. For now, I'm just trying to concentrate on what would make a 93 street truck perform and ride best based on a 4/6 or 5/7 drop in three different scenarios. Budget, Mild and Wild.
#8 | |
Re: Make it handle
A guy with a truck
Re: Make it handle
What month? I'm no longer a subscriber, but I'd like to grab a copy
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). |
Re: Make it handle
it's the September 2012 issue
Re: Make it handle
I see your f*rd is on fleabay! What for?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
56 - autocross
Re: Make it handle
Rob:
Congrats on the article. You deserve it! |
#13 |
Re: Make it handle
Thanks HotRod1
Sid The garage is full, the shop is full, the trailer is full, and if you know about so-cal real estate, more space isn't an option. HellBoy took the last spot and Tina's mustang is coming along quickly. Someone else needs to know what it's like to drive a bad ass F-100. ?? Could be you
#14 |
Re: Make it handle
How to get the BEST DEAL EVER I made a comment on another thread here about buying an IFS. It may have sounded like I was steering the OP towards our product. Yes, thats how I make a living, but that wasn't my goal. Everyday I talk to people about their projects, and more than half of the stories are not so good. Poor quality parts, bad shop experience, over budget, too long....... Many of them are removing parts they bought and installed, only to be unhappy with the outcome. This is the heart of the problem. So how do you get the best deal without getiing screwed? Do your Homework. Ask the right questions, and if you don't know which ones to ask, ask about that too. Forming a relationship with a builder or retailer will help. Not a virtual relationship, but a personal one. Call them on the phone, or stop buy. But, don't waste their time, be ready, have a notepad and pen, and listen to what they say. Think about why they may say these things. Never buy on impulse. You can get Price, Quality, or Service. - But you can't have all three. Most of us are building what amounts to a 4000 lb. bomb. If you plan on driving your truck on a public road, with your wife, girlfriend, and/or kids, set out to make it safe enough for the HP you put in it. Our goal is to grow the classic truck hobby in general. More people building and driving more old trucks. To do that, we have to finish them, drive them, and live through the experience.
p.s. - never put your wife and girlfriend in the truck at the same time.
#15 |
![]() Join Date: Nov 2011
Re: Make it handle
Not even if they are the same person????? I tend to think of my wife as my girlfriend lol.
J'aimi 54 Chevy 3100 5.3/4L60E (Plan to make summer daily driver) 54 Chevy 3600 "Destiny" future project (Plan to build for my daughter) 72 C10 current daily driver 74 Nova Son's DD (His 1st car, we had to start him off right) 00 F*rd Expedition wife's DD (She's the trader in the house and doesn't drive a GM )
#16 | |
Re: Make it handle
![]() ![]() ![]() no kidding, one in each ear... sage advice Rob
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#17 | |
Re: Make it handle
This is one of the main reasons I respect you and your company. It is always refreshing to see another vendor who shares similar principles and values. Sound advice all the way around! If I were to emphasize anything you mentioned, it would be the planning process. Take your time in the "discovery" portion of the process. Ask LOTS of questions. Know what you are building BEFORE you build it. This will help ensure that all parts will work together to achieve the desired end result. A clear and solid plan will do nothing more than save time and money in the long run! Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#18 |
67cheby
![]() Join Date: Sep 2008
Re: Make it handle
AWESOME !.....what you are saying is dont do it like MIKE LOSH did !! LOL, 9 years and countless amounts of parts put on and taken off ...never to have been used other then mock-up !! LISTEN guys these are great points to keep you build from dragging out like mine did !!
#19 |
Re: Make it handle
Man, you guys are way more advanced than I am. I am working on my 87 short bed and really want to make it handle. My dream would new crossmembers, coilovers front and rear, big sways etc but I will never be able to afford that. One of my daily drivers is a supercharged newer Camaro with a bunch of suspension mods and I love it.
My 87 has CPP tubular uppers with Moog BJ's, completely rebuilt lower arms with 1" Belltech springs and I have a 1-3/8" sway bar that I have not installed yet. All of the other front suspension is brand new. The truck rides great in the front but HORRIBLE in the rear. Like really hard. I know it's an old truck and won't ride like a caddy but this is to the point where I think something is very wrong with the rear leafs or there is some kind of bind. I've asked other people with squares if I could push down on their truck in the rear and I can move theirs up and down. If you try to push down on mine, it doesn't budge. I hate it. Should I remove a leaf? Ii put new AC Delco rear "Stock replacement" shocks on the rear and it did not change it. I have Eibach 2" drop shackles on it now and they did not alter the ride at all. I would love the Ridetech rear mono-leaf springs but at $800+ for them, I can't swing that. Are there any other things I can do? Any donor trucks with the same leafs that I can make a "Bastard pack" out of that will ride better? A good 4 link rear coilover kit that doesn't require a frame c-notch?
My mother is a recent cancer survivor and this truck build is for her |
#20 | |
Re: Make it handle
#21 |
Re: Make it handle
Thanks Nate. You are so right. If you were building a house, you start with a contractor or architect, you don't just run down and buy lumber (OK, well I do that sometimes) Now that some of these trucks cost as much as houses, maybe a little more planning is needed. "If you fail to plan, your planning to fail" (from Yosh, one of my mentors).
Brush it off Mike, your truck is turning out great! Nate, mark your calender for Saturday, sept 8th. The next So Cal Challenge at AMP in riverside
#22 |
Re: Make it handle
Interesting idea I just thought of... An 09+ Dodge truck has a 4 link rear end, find a rear end, brackets, and bars and you'd have a pretty decent start to a 4 link. Not to mention discs and 5on 5.5... Pictures and measurements in a bit.
'55 3200 283 4 speed '68 Pontiac Firebird Poncho powered with a 6 speed |
#23 |
Re: Make it handle
I have drivin one, pretty nice - how wide is it?
#24 |
Re: Make it handle
That was my thought they are a nice riding truck that handles pretty well out of the box. Steal some technology from Dodge and apply it to the old truck.
#25 |
Re: Make it handle
If you want the perfect oportunity to put your truck through the paces, come out to the So Cal Challenge on sept 8. This event is at Adams Motorsports Park (AMP) in Riverside. A full day on the track, time-attack and shootout, 5 classes, show and shine, vendors... $10 gate entry, $20 show and shine (gets two in), $60 competitor (gets two in) always a great day, more track time than anywhere. www.socalchallenge.com
| Bookmarks |
