Old 04-20-2022, 11:04 PM   #1
60short
60short's Avatar
Re: Post your 60-66 craigslist finds
Originally Posted by cwcarpenter98 View Post
That's a good deal for that transmission! I would buy that in a heart beat if it was close by
Yes, the 4 bolt side cover overdrive transmissions are the same length as the long tail shaft 3 speeds. I have two of the overdrive transmissions. The one currently in my truck came out of a 65 C10. I forget the count, but it has finer splines on the output shaft than the standard 3 speed I pulled out of my truck. The other overdrive that I have has the same spline count as the old 3 speed I pulled out.
I believe the output shaft spline count ran from 55-64 and then changed in 65. Another difference I noticed is that the input shaft necked down on my 55-64 overdrive trans but did not neck down on the 65 I put in the truck.
I was hoping you would chime in, you have most of the knowledge ive seen here on these beasts, ...
Ive sent him an email, Im in the middle of trying to sort a transmission swap, but $50 is $50, and probably worth the risk
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is offline   Reply With Quote
Old 04-21-2022, 12:01 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Thanks, I did a lot of research on them before I made the decision to acquire one. I've had it in my truck for over three years now and picked up a second as a backup or for spare parts if needed. The only thing I haven't done with one yet is to rebuild it, but that will come eventually
But yeah, $50 is $50. The overdrive book by Randy Rundle is a great resource for digging into the details on how it all works.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 05-28-2022, 11:13 AM   #3
forestb
forestb's Avatar
You guys are a couple of decades off. Those are now great grandpa trucks��
forestb is offline   Reply With Quote
Old 05-28-2022, 09:51 PM   #4
jocko
jocko's Avatar
64 GMC Motorhome $6K
She's a beaut Clark!
Old 05-30-2022, 07:50 AM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-30-2022, 12:21 PM   #6
factorystock
factorystock's Avatar
Read the GMC camper ad ( very clean original piece by the way Jocko), looks like somebody already destroyed the clutch. Note position of pedal. Never liked the way the 4 speed gear shift pattern was for rookie drivers, some latter patterns had the more accurate L 1 2 3, I could see how somebody could blow a clutch or U joint pronto.
factorystock is offline   Reply With Quote
Old 05-30-2022, 04:29 PM   #7
oem4me
oem4me's Avatar
I actually love it! Considering the low initial cost and wide open potential for a build-to-suit camper interior, it wouldn't take much to create an awesome food service rig for vintage car shows etc. Picture a big walk-up window under that awning, or maybe on the driver side.
I'll take two hot dogs and three beers please! LOL!
Old 05-30-2022, 04:12 PM   #8
forestb
forestb's Avatar
I think it was ruined at the manufacturer when they put the camper on it
Old 06-09-2022, 10:30 AM   #9
jweb
jweb's Avatar
66 stepside in San Diego
https://sandiego.craigslist.org/csd/...494089108.html
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 06-22-2022, 01:38 PM   #10
MusicMan70
MusicMan70's Avatar
Nice Panel up in Medford
https://medford.craigslist.org/cto/d...499607272.html
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 07-21-2022, 09:44 AM   #11
Bridgeman57
Bridgeman57's Avatar
Thumbs up Re: Post your 60-66 craigslist finds
Found this 61’ for $12. Going to look at her tomorrow. What do you guys think. I feel it’s worth way more then that in its current state. Minor Surface rust above window and on bottom of doors he says. 350 with a Muncie 4 speed with Bluetooth radio 🤙🏻
Bridgeman57 is offline   Reply With Quote
Old 07-21-2022, 09:53 AM   #12
62c30
Minor surface rust above which window? If it's the front windshield it's probably a lot worse than it looks. On my 61 I had to replace of above the windshield and the inside was a lot worse than you could see from the outside. Each area with surface rust showing a very lite push with a screwdriver or other sharp object would go right through.
62c30 is offline   Reply With Quote
Old 07-21-2022, 10:38 AM   #13
Bridgeman57
Yeah that’s what I’m afraid of. How difficult is it to replace The sheet metal above the windshield?
Old 07-21-2022, 10:45 AM   #14
62c30
It's not fun. The outside piece above the windshield is reproduced but mine was about a half inch too narrow. I had to replace the inside panel as well but is not reproduced for 60-63. I used a 64-66 piece that I cut the ends off. It was easier for my truck to have the roof skin off to get to it. Yes you could do it with the roof on. So on my truck it was the piece above the windshield, inside and out and the roof skin. If my truck wasn't a bbw and my grandad's truck I probably would have looked for another cab.
Old 07-21-2022, 10:57 AM   #15
Bridgeman57
Yeah it doesn’t sound like fun. I can probably pick it up for 11,500. It’sa beautiful truck. DD at that. For the price would it be worth taking the chance of it being worse than expected.
Old 07-21-2022, 11:21 AM   #16
The Rocknrod
Moderator
The Rocknrod's Avatar
1966 Chevrolet k10 4x4
https://dallas.craigslist.org/dal/ct...510016112.html
1964 CHEVY TRUCK
https://dallas.craigslist.org/mdf/ct...508299411.html
Old 07-26-2022, 02:44 AM   #17
SOON2BLAZE
SOON2BLAZE's Avatar
https://classifieds.ksl.com/listing/68671191
Ruff, but it's a 4 door
SOON2BLAZE is offline   Reply With Quote
Old 07-26-2022, 10:47 AM   #18
forestb
forestb's Avatar
Originally Posted by SOON2BLAZE View Post
That would take too much work to change that into a 2 door. No thanks!
Old 07-26-2022, 10:51 AM   #19
Chevy Fleetside
Chevy Fleetside's Avatar
https://sfbay.craigslist.org/nby/cto...513349228.html
rohnert pk / cotati) He is asking $3300
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-26-2022, 11:00 AM   #20
forestb
forestb's Avatar
He must be living in the 90's when these things were still affordable.
Old 07-31-2022, 10:25 PM   #21
60short
60short's Avatar
1963 Chevy C20 Truck - $15,000 (Goleta)
$15k OBO
Price is negotiable just shoot me an offer or come and see the truck if you’re interested
Located in Goleta, CA
My truck is an orange and white 1963 Chevy C20 3/4ton with a small block 350 V8 and 4 speed manual transmission. I’ve owned the truck since 2017 and is now running and driving really well. Below is a list of all the new parts and wiring I’ve installed on the truck while owning it, and below that list are all the parts I have that will come with the truck when purchased. Whoever ends up buying this truck and parts will have everything they need to finish this amazing build. I’m selling this truck because I need to buy a more family friendly vehicle as my wife and I are starting to plan for kids. I hope that whoever end up with it enjoys the truck as much as I have.
•Work done on the truck:
New 3 core radiator and hoses
New long water pump
New serpentine belt conversion
New Performance Online power steering kit
New Performance Online front sway bar and rear sway bar
New cab mounts
LMC truck rectangle side mirrors and rear view mirror
New Performance Online 4” rear drop springs
New shocks all the way around
LMC truck gray carpet
LMC truck seatbelts driver and passenger
Completely replace all the wiring and grounding straps with _______ wiring harness for the full vehicle for the all the lights, engine, cab, and rear lights
New tachometer
New LMC truck turn signal assembly
New Summit Racing 600cfm carburetor
New ________ performance intake manifold
New Summit block hugger headers
Custom dual exhaust with glass packs
New panhard/track bar
Was able to find and replace all the transmission parking brake components (very rare and hard to find which took me three year to find all the parts and get working)
LMC gas tank relocation out of the cab
New fuel line and filter
New heater fan, lines, and heater valve
All new window weatherstripping
New door panels installed
New brake lines
American racing wheels and new tires
New LMC truck headlights
New LMC truck turn signals
New LMC truck tail lights
New license plate holder
New LMC truck rear bumper
New hood pin and hood latches
New battery (recently)
New battery cables
Wood truck bed was taken out, sanded, and stained
New LMC truck wood bed bolt set
New rear window
Old 08-08-2022, 11:51 PM   #22
jocko
jocko's Avatar
64 C10 swb I6 $24.9K
Old 08-09-2022, 09:12 AM   #23
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Beautiful! Same color as my old '64 Impala convertible.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 08-10-2022, 03:45 AM   #24
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...a-18ec5687e65e 1966 Chevrolet c-20
$13,000
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
Old 08-10-2022, 10:47 AM   #25
forestb
forestb's Avatar
Originally Posted by Wikid61 View Post
Just get rid of the camper and that thing would be awesome.
