Re: Kabwe's aka Bam's build
Does that ever look straight. How thick do you think the filler is when it is done?
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
#2 | |
Certified Car Nut
Oh I forget to mention another reason I like it so much, it sands really easy. Last edited by Kabwe; 03-10-2014 at 05:54 PM. |
If it's been blasted, etch (really nice panels) or epoxy straight to metal after a wipedown. I mechanically strip with 80 on a da pad in a drill and a wire brush, then 80/150 on a DA to level out. Then filler after epoxying, scrub the work area with 80 for filler tooth. I knock filler down with 80 on a block. If I think it's good, I lightly scrub with 150 to knock the 80 tooth down then SS it. I lay a good spot coat over the bodywork area areas, then a medium coat over the whole thing. Then when it dries, 80 real quick over your worked areas, re-guide if good and 150 the whole panel. Then 1 medium coat with ss, and finish out on that coat. Yellow truck in my sig was done this way.
Sorry to butt in again, Kab.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
Certified Car Nut
Grand PooBaa Member
Its hard for me to follow the bodywork thing. Filler primer, epoxy primer, 2k primer, primer sealer. All I would know to do is sand the body, shoot some primer on and and paint.
Way too advance for me.
#6 | |
Certified Car Nut
Bare Metal - Protect with epoxy primer. You can do your filler work first and epoxy or you can epoxy first and do your filler work on top of the epoxy primer. When sanding you may get some exposed metal if you are doing filler over epoxy. Just hit those bare metal spots with more epoxy. After Epoxy and filler work - This is when you spray your 2k primer, High fill primer, or in my case Slicksand. This is the primer that you use for build so that you can blocksand and get the panel straight and ready for color. This is much harder than it sounds if you are shooting for perfection.lol After 2k primer, high fill, or slicksand - You continue to block this primer out to 400 to 600 grit depending on the color choice or if you are using a sealer. A sealer in my case epoxy primer that is reduced to put uniformed canvas for paint. The lighter or more translucence the color may make you want to block to 600, also a light metallic you may want to block to 600. If you are using a sealer over 400 grit you may be good to go with color. Now you are ready for color. Last edited by Kabwe; 04-22-2014 at 03:07 PM. |
Elev8r Man
Man, now thats funny right there.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
Grand PooBaa Member
I'm with ya VDog but I'm starting to get it.
Not for beginners, but in a production environment, especially if you're spraying sealer, 320 on a DA is a fine finish for most paints. This has to be approached with skill and caution, (cause you can do all kinds of damage to your bodywork) but lots of shops do it. 320 DA the primer out into existing paint, red scotchbrite the rest of the panel, sealer/base over the primer, clear the whole panel.
Certified Car Nut
Well I finally got some color on the truck, well the interior. I could not wait to see what the color would look like so I just thought I'd shoot the interior just to see if I really liked it.
This is my backyard paint booth.lol ![]() Here you go ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Elev8r Man
OMG man!!!!! You did a GREAT job as usual. I looks really good
#13 |
Certified Car Nut
Thanks man. I wish had a paint booth but its not half bad for a backyard paint job done under a Harbor Freight canopy.lol
You are going to paint your next project right? Last edited by Kabwe; 04-20-2014 at 02:42 PM. |
#14 |
Looking good. Glad to see the ball is still rollin.
#15 |
Certified Car Nut
#16 | |
#17 | |
Elev8r Man
I recently picked up an upholstery sewing machine and am trying to learn some basics from a couple friends that own upholstery shops. I figured what the heck because I have the truck and the suburban to do, so I may as well at least learn the basics of doing a seat.
#18 |
big guy
Great job my friend, you have done a ton of work and it shows...
Ray |
#19 |
![]() Join Date: Mar 2007
The color looks great. Nice work.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#20 |
Looking good, love the green
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
#21 | |
Certified Car Nut
#22 |
Certified Car Nut
Thanks guys I appreciate all your comments on the color. I was a little nervous about the green. I'm usually way more conservative when it comes to colors but I thought the truck needed a color that popped a bit more than something I would normally chose. Once I shot the interior I became way more confident in the color choice and actually love it now.
#23 |
Elev8r Man
Ok you got it, keep your phone charged up because as usual I will have tons of questions
#24 |
Love the color
#25 |
That's Pretty Bam!! Looking GOOD
| Bookmarks |
