Old 10-20-2024, 07:54 PM   #1276
IronCanine
IronCanine's Avatar
Re: 67 GMC super custom build
Originally Posted by chewychevy67 View Post
Here's a line for ironcanine. Once this antenna is finished I am done doing mods. For real. Metal work will start after it's done. There are 2 things I really wanted to add but I won't be doing. 1 is the short bed tool box. This one is completely do-able but I'd have to mess around with the fiberglass box and the body mouldings. I do have confidence that I could remedy these but I do want to drive this truck someday and the time/money it would take to do this I have come to feel would not be worth it. And # 2 comfortron. Even though they do make a hvac control panel that directly fits in cosmetically I've studied this over many occasions and it's too complicated to work it into our hvac system. So hopefully the parts come in the next 2 weeks to mount this antenna and then it will be off to final metal and in the new year. My head hurts thinking how to work all these cadillac options into this truck. Maby next year I'll complete this build. We'll see how fast this goes thru bodywork. I'm sure it won't be as fast as I like lol.
I'll believe you're done with mods when the truck is done. This whole truck is a GMC-tron. I kid you about it, but I don't want you to stop. I love what you have done/are doing. It is inspired and remarkably cohesive. Don't stop.
When I was rebuilding my horns I bought the other 2 horns needed to make this a 4 note set up. I mounted the trumpet horn on the hood latch support directly behind the center bar of the grille. You can barely notice that its there from the outside. The other I'll find a place for in the engine bay.
Now you're just tooting your own horn.
IronCanine is offline   Reply With Quote
Old 10-26-2024, 10:03 PM   #1277
chewychevy67
Well I got the bezel in the mail today and it fits the body curve of the fender really well. I did use a spare driver fender Just to see if it would fit before I made the mod on my fender I'm using. I was going to do the mod on my passenger fender but where I have it here on the fender sitting in the driver seat you can't even see it. It's behind the Pillar so I might leave it there. Would be easier to mod the cowl behind d it on the driver side because the a/c stuff isn't there. Now to figure out bracketry.
chewychevy67 is offline   Reply With Quote
Old 11-04-2024, 10:59 PM   #1278
chewychevy67
Finished all 4 of my headlights and Well I guess the headlight washers are final. I drilled them into my rechromed headlight bezels. With all the new chrome you can barely tell that they are there.
Old 11-04-2024, 11:03 PM   #1279
Getter-Done
Getter-Done's Avatar
I Like It A Lot.
The early bird gets the worm,
85 Chevy K-20
Old 11-04-2024, 11:52 PM   #1280
chewychevy67
Originally Posted by Getter-Done View Post
I Like It A Lot.
Old 11-24-2024, 10:05 PM   #1281
IronCanine
IronCanine's Avatar
No joke...that's a real 'Where's Waldo?'
Old 11-25-2024, 07:36 PM   #1282
knuckle-nurse
Your rounding third Rod.....
72 Cheyenne C20 BB, air
70 Suburban 20 BB, air, buckets
68 CST C20 air, buddy buckets
72 Jimmy 2wd
72 Blazer 4wd air 4 speed
knuckle-nurse is offline   Reply With Quote
Old 12-08-2024, 09:38 PM   #1283
chewychevy67
It seems like a slow rounding. I did modify my power antenna to use a stainless steel cable with plastic coating instead of the nylon cord that they all use that typically breaks. Might be hard to change after when it's installed. Waiting on parts stuck in Canada Post to finish the antenna. Looks like it might be well into January before I get my stuff or later.
Old 12-09-2024, 12:32 AM   #1284
chewychevy67
So I decided to use the passenger side like it was factory. Centerd it with the bezel. Now for the hard part. Taking the fender off and making it fit nicely.
Old 12-15-2024, 04:18 PM   #1285
chewychevy67
I have to do the cornering lights before I take the fenders off to do the antenna so I cut the holesin the mouldings and made the bezels fit. Scary stuff. At least for me. That's the hard part. Now I can cut the back side od the fender out for the light when the fender is off.
Old 12-15-2024, 05:01 PM   #1286
chewychevy67
I really fought myself how to add these cornering lamps because it's so hard to do any alterations to the exterior of these trucks . They were so we'll designed for their time and altering the lines would be a shame. That's why I could not use that box top and I kept the adjustable mirrors on the original stems and round even if they are less functional. It's tough to make some of these mods without loosing the period look. One thing I don't want to do is make it look modern in any way. Interior or exterior. Except the lighting. I want to be able to see when I drive.
Old 12-15-2024, 07:07 PM   #1287
IronCanine
IronCanine's Avatar
Don't worry. You're threading the needle. Looks great.
Old 12-15-2024, 08:43 PM   #1288
chewychevy67
Thanks. Most ppl wouldn't care to or find useless most of the mods I have done (including myself at times) but it's about what the build will be when it's finished. Here's the other side ans with the lenses in them.
Old 12-28-2024, 07:00 PM   #1289
chewychevy67
Today I bought a spoiler for the front from randy. It should look nice. Here's a pic from their website. It's made from steel and I like that
Old 12-28-2024, 07:46 PM   #1290
IronCanine
IronCanine's Avatar
Slick. I hope this means a diffuser on the back now too.
Old 12-29-2024, 08:12 AM   #1291
72 tigger
72 tigger's Avatar
I like your mods
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 12-29-2024, 11:05 AM   #1292
chewychevy67
Never lol
Old 12-29-2024, 11:06 AM   #1293
chewychevy67
Originally Posted by 72 tigger View Post
I like your mods
Thank you .
Old 12-29-2024, 07:17 PM   #1294
CG
BlahBlahBlah
Just spent the time to go through the whole thread again. Super fun build!
Old 01-06-2025, 09:04 PM   #1295
chewychevy67
So I finally found the switch I want to use for the antenna. It's from a f#*d. There I go swearing again. It's a rocker switch used on power tops. Looks right at home in the dash. I'm having the 3d print shop make me a plaquard just like the fog lights to go on the bezel.
Old 01-06-2025, 09:21 PM   #1296
IronCanine
IronCanine's Avatar
It's ok. Just don't tell anyone....else.
Old 01-06-2025, 09:24 PM   #1297
chewychevy67
The switch will probably wear out prematurely anyway lol.
Old 01-08-2025, 06:41 PM   #1298
CG
BlahBlahBlah
The antenna switch is a great idea, very clever like the rest of your mods. Curious though why you didnt have the antenna go up at key on or maybe when radio was turned on. Course Im not sure if it would go down at key off with no power. I had power antenna in a couple of older cars (Imperial, Cadillac) back in the day but dont remember how they worked
Old 01-08-2025, 07:32 PM   #1299
chewychevy67
Yes I definitely thought of that. I would have liked it to go up and down with the radio on but the radio doesn't have a accessory type wire to activate it. I also thought about using a 4 wire like the 73-76 cadillacs used and then it would go up 10 inches when the ignition goes on and down when it goes off and you can use the switch in between but I have already restored the 68 antenna I have but I have considered purchasing a 73 style.
Old 01-13-2025, 11:55 PM   #1300
chewychevy67
I did some work with Steven back and forth on this cup holder for 67 cabs as hes already made one for the newer cabs and here is the finished product. Works great and it let's you keep the 67 face. Added a cover around the edges to cover up the slider area. Whati like about this is i can simply take the 2 screw out and remove this and slide the ash tray back in without having to go under the dash. I'm going g to have 2 faces painted for this reason.
