Closed Thread
Old 07-07-2015, 09:16 PM   #1276
Pappyx3!
Pappyx3!'s Avatar
Re: What did you do to your truck today part III
Finally! Got the engine in on the 62. Planning to fire it up on Thursday evening.
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline
Old 07-07-2015, 09:21 PM   #1277
TJ's Chevy
TJ's Chevy's Avatar
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 07-07-2015, 09:58 PM   #1278
Lugnutz65
Lugnutz65's Avatar
Repaired the pitted and rusted portion of the bed rear cross sill.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 07-08-2015, 09:44 AM   #1279
HappyHooligan
HappyHooligan's Avatar
Replaced Speedo Driven gear, watched needle bounce around and then slowly down to nothing.
Rebuilt Rag Joint on steering shaft..... twice.
First try Steering wheel was upside down
Replaced fuel sending unit Float. brass one was cracked. Checked ohms on sending unit and continuity to dash and ground. No movement on guage
Drank beer and contemplated my mechanical skills
Hooligan
The Green Hornet
1960 Apache 10 Long Fleet - Driver and Work In Progress
The Death Star
2006 Vstar 1100 - Chopped, Bobbed, Riding the Dark Side
HappyHooligan is offline
Old 07-08-2015, 10:06 AM   #1280
iceship
Love that steering wheel
iceship is offline
Old 07-08-2015, 12:45 PM   #1281
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Scored These Rare commercial Plates I Buddy has Had Them Hanging up For Years
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline
Old 07-08-2015, 07:49 PM   #1282
1971 GMC SHORTY
Got The V8 Helping A Buddy Out
2002 FXDP
Old 07-08-2015, 07:53 PM   #1283
1971 GMC SHORTY
Here it is Love working on Stuff that PO 1/2 Assed Ever THING
2002 FXDP
Old 07-11-2015, 01:36 PM   #1284
jbgroby
jbgroby's Avatar
Got the engine block to cab grounds mounted this morning. I have to remove the heater assembly to get to a hole. I must be getting better as I only smashed one finger.
jbgroby is offline
Old 07-11-2015, 02:17 PM   #1285
LVPhotos
LVPhotos's Avatar
Making a mess! Pulled motor in hopes to attach and install transmission. Cleaning cab and firewall. Some touch up. Truck was originally Omaha orange but green primer? Keeps popping up on the lower cab.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 07-11-2015, 05:40 PM   #1286
OldChevy61
OldChevy61's Avatar
Took the 12 bolt to the welding shop to get the new Captainfab mounting perches welded on and pan hard mount moved over.
OldChevy61 is offline
Old 07-11-2015, 10:46 PM   #1287
scottco
scottco's Avatar
Finished the disc brake 5 hole conversion. Cragar's are on and life is good !! lol
1964 C10 SWB original
1970 SS El Camino
1964 Impala SS
http://67-72chevytrucks.com/vboard/s...d.php?t=649951
scottco is offline
Old 07-11-2015, 10:48 PM   #1288
schpeen
schpeen's Avatar
Keep wax on them. Looks perfect
schpeen is offline
Old 07-11-2015, 10:50 PM   #1289
LVPhotos
LVPhotos's Avatar
Dig it! Like stockish stance. Hot Wheel red stripe tires would be cool.
LVPhotos is offline
Old 07-12-2015, 06:22 PM   #1290
LVPhotos
LVPhotos's Avatar
One step closer! McLeod hydraulic bearing installed because the 2466HKR Hooker Competition Headers don't work with stock arm and bellhouse. Had to clearance driver side bellhouse to clear.
LVPhotos is offline
Old 07-12-2015, 06:34 PM   #1291
mjh1965
mjh1965's Avatar
Well I went and removed and collected a new motor a 350 SBC for my truck today
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline
Old 07-13-2015, 02:13 AM   #1292
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
today I found the left front hubcap for my daily!
they are doing construction on a road I drive on to work, and it was extra rough yesterday. when I got to work I noticed the left front hubcap was missing
I drove home, scanning the route, but did not see it... but then today I drove even slower, and out of the corner of my eye noticed it next to a fence , laying upside down and full of rain water!!
so happy I don't have to bang out and paint up another one!
jonzcustomshop is offline
Old 07-13-2015, 05:35 AM   #1293
Palf70Step is offline
Old 07-13-2015, 05:11 PM   #1294
LVPhotos
LVPhotos's Avatar
Back together! Short of one bolt on motor mount all went smoothly. The fab of the trans crossmember will be tomorrow. Still sitting on stands.
LVPhotos is offline
Old 07-13-2015, 06:03 PM   #1295
Lugnutz65
Lugnutz65's Avatar
Nice work. So what setup do you have for the hydraulic clutch MC and pedal? Please include pics if you can.
Old 07-13-2015, 06:08 PM   #1296
schpeen
schpeen's Avatar
Finally got my steel smoothies to balance after trying 4 sets
schpeen is offline
Old 07-13-2015, 07:39 PM   #1297
LVPhotos
LVPhotos's Avatar
I used a Captainfab firewall bracket, CPP all in one master, Wilwood hydraulic clutch cylinder, McLeod hydraulic bearing. The chrome booster came from Tuckers Trucks either s10 or Nova base 7".
The 2466 HKR Hooker Compatition headers didn't work with arm and had to knock down driver side bellhouse to clear flange. This is why th hydraulic bearing over arm.
Stock pedal. Big feet can hit all 3 if you try!
LVPhotos is offline
Old 07-13-2015, 10:28 PM   #1298
Lugnutz65
Lugnutz65's Avatar
OK, you showed brake stuff too. Didn't need that but it's useful to other readers.
So the clutch MC is Wilwood. Model#? Mounting info? Heim joint and pushrod from the pedal connection?
Old 07-13-2015, 11:00 PM   #1299
LVPhotos
LVPhotos's Avatar
All the parts came with Captainfab kit. The firewall kit has a spot to drill for Wilwood and all hardware and rods came with kit.
http://www.67-72chevytrucks.com/vboa...d.php?t=362375
LVPhotos is offline
Old 07-13-2015, 11:05 PM   #1300
LVPhotos
LVPhotos's Avatar
Under dash... not mine.
LVPhotos is offline
Closed Thread
