Old 01-14-2025, 12:05 AM   #1301
IronCanine
IronCanine's Avatar
Re: 67 GMC super custom build
Love the holder. Really love the beverage of choice...side note...did you know this build thread is in the top 15 most viewed 67-72 truck build threads on this site...and the "newest" of those 15. Most of them started in that apparent sweet spot, 2008-2009. Just a fun fact.
IronCanine is offline   Reply With Quote
Old 01-14-2025, 10:16 PM   #1302
chewychevy67
So I did some work with my cornering lights on the driver side tonight. Here's a view with only the driver side headlight on low beam and the cornering light on and off.
chewychevy67 is offline   Reply With Quote
Old 01-15-2025, 10:37 AM   #1303
raggedjim
raggedjim's Avatar
I'm assuming you are going to somehow trigger the cornering lights when the turn signals are on. Do you mind sharing your thoughts on wiring for this?
Nice work, Rg
raggedjim is offline   Reply With Quote
Old 01-15-2025, 11:45 AM   #1304
HO455
HO455's Avatar
Originally Posted by chewychevy67 View Post
So I finally found the switch I want to use for the antenna. It's from a f#*d. There I go swearing again. It's a rocker switch used on power tops. Looks right at home in the dash. I'm having the 3d print shop make me a plaquard just like the fog lights to go on the bezel.
Can you share what year and model you sourced the switch from?
RIP Bob Parks.
Old 01-15-2025, 02:12 PM   #1305
chewychevy67
My telescopic column was from a 1967 cadillac and the switch incorporated the function already so I'm just wiring it the way cadillac did. I also added a speedometer ground switch from a 70s mopar emmision set up that will only ground the lights to 40 mph and over that speed they won't come on. The lights I made work from 1969 chevelle side marker lights with clear lenses.
Old 01-15-2025, 04:22 PM   #1306
chewychevy67
63 64 mercury. Part C3MY-15668B
Old 01-16-2025, 10:17 AM   #1307
raggedjim
raggedjim's Avatar
Thanks! Rg
Old 01-29-2025, 04:09 PM   #1308
chewychevy67
Got the spoiler today from spoilers by Randy. I think it looks great. It came with a spacer to lower it if you don't like it this high. Now I believe it came with a poor paint as I went to wipe off the glue residue and it took paint off Immediately. Probably a spray bomb. So it will have to get refinished and my metal guy may have to take the wrinkles out in the center. For the price I probably wouldn't buy another because of the extra work I now need to do on it but it's here now and looks good and it ends perfectly with the edge just at the fog lights.
Old 02-05-2025, 01:09 PM   #1309
70STOVEBOLT
70STOVEBOLT's Avatar
I was thinking the cornering lights would look better incorporated into the trim, that looks really nice. I put a set of 4 Caddy horns on my truck, plus the two stock hi/low note horns. It sounds a lot like a locomotive. I mounted the Caddy horns on a piece of angle that I mounted right underneath the hood latch. Everything is painted black to be "hidden" and I routed the wires under the lip of the core support. This is a killer build.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-05-2025, 06:24 PM   #1310
chewychevy67
I wanted this too so I purchased it. Can't be a elite gm 60's vehicle without em. You'll have to wait till I receive the parts for more details.
Old 02-06-2025, 09:49 AM   #1311
HO455
HO455's Avatar
Thank you, sir! Now the hunt is on.
RIP Bob Parks.
Old 02-14-2025, 10:31 PM   #1312
chewychevy67
So I got my 3d printed parts today for the cornering lamps and wow they couldn't have turned out better. I cut the rest out of the fender and mounted them. Light shines low and in the corner nicely. I am going to have so.e pieces moulded into 1 piece as I glued some together just to see if I would like the beam pattern.
Old 02-14-2025, 11:01 PM   #1313
IronCanine
IronCanine's Avatar
Impressive.
Old 02-14-2025, 11:27 PM   #1314
chewychevy67
Thanks. Here's the light output with it finally mounted in the fender.
Old 02-15-2025, 02:49 PM   #1315
zicc1835
zicc1835's Avatar
would you consider producing them if there was an interest ?
zicc1835 is offline   Reply With Quote
Old 02-15-2025, 05:28 PM   #1316
chewychevy67
Sorry but I doubt I would. Too many sourced parts to do it but i could give you a more detailed list of parts i used and more information if you would like. Here's the passenger side. No lens for this side yet. I am Going to have the 3d print place mould me 2 new lenses from the one I have already.
Old 02-22-2025, 12:42 AM   #1317
chewychevy67
So I ended up with these vigilites from a cadillac and I couldn't help notice how the contour fits perfectly with the hood. But I'm actually not sure I could put these on. I did get one from a station wagon and I'm going to mount it recessed into the tailgate in the center right above the handle bolts so you can look in the rear view mirror and make sure your bulbs are working and it will be below flush so you can still slide stuff on the gate (like that will ever Happen). i might have to get more creative on the front ones if I do them at all. They kind of mess up the hood lines.
Old 03-03-2025, 05:59 PM   #1318
chewychevy67
So I made the dimple in the center of the gate and added the vigilite. It's a hare under flush of the gate and you will be able to see it in the rear view mirror if your tail lights are burnt out.
Old 03-03-2025, 06:13 PM   #1319
IronCanine
IronCanine's Avatar
Now you gotta drive it in the rain AND in the dark.
Old 03-03-2025, 06:15 PM   #1320
chewychevy67
I can't wait to drive it in the dark.
Old 03-03-2025, 06:21 PM   #1321
IronCanine
IronCanine's Avatar
You're a better man than me. It's so nice. I'd wrap it up in tissue paper and schlep it from show to show. Stand by it all day pointing at it and talking to other old men about it.
Old 03-05-2025, 12:06 PM   #1322
chewychevy67
I drilled a hole in the center of the trunion to run the 3 fiber optic cables thru the gate to the body.
Old 03-10-2025, 02:22 PM   #1323
chewychevy67
Well as it turns out I can not run my cables thru the trunion as the damper is filled with oil and it leaks now so I'll get a new damper and figure another way. While I had the gate off my metal man wanted me to change the rear bed crossmember because my original was really pitted where the wood sat. So as I am comparing the aftermarket and original the hole size and a few things are quite different. It's heavy gauge but in my opinion for what I paid it's not great. Had to make the wiring holes larger for the tail light rubbers or they wouldn't have fit thru and now have to shim it as the frame mounts are welded higher. Had to ream a few holes slightly as well.
Old 03-26-2025, 06:03 PM   #1324
chewychevy67
I added the fiber optic end to the top of the front signal lenses.
Old 03-28-2025, 05:56 AM   #1325
IronCanine
IronCanine's Avatar
Bummer about the trunnion. And with regard to repro sheet metal...and the bed bits specifically....it certainly can vary wildly from factory (in little and big ways). I'm sure you'll make it work though.
Your lighting stuff continues to be off the chain.
