07-27-2020, 07:02 AM | #1301 |
Re: 53 Surburban "Family Truckster"
Marc, what's the process you're using to acheive the brushed look on your grill? I really like the look and I'm taking notes...
07-27-2020, 07:58 AM | #1302 | |
Thanks I'm digging it..
Thanks Jim Quote:
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
07-27-2020, 08:07 AM | #1303 |
We the exhaust got pretty much wrapped up this weekend. My fabricator friend had 31 hrs into this exhaust. keep in mind he would haul the pieces back to the shop to cut/fit/weld. All we have left is to add a hanger to the ends. I'm pretty pleased with how it turned out. It's not quite a full system but longer than a shorty system that ends under the body.
The body will go back on for good In about a week. Thank you Marc
07-27-2020, 08:44 AM | #1304 |
That's looking great, can't wait to see body on (I know you can't either)...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-27-2020, 08:46 AM | #1305 |
Post Whore
Exhaust looks great..!....I'm ready for the body to go on to...!
07-27-2020, 08:48 AM | #1306 |
That's one good looking frame!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
07-27-2020, 08:54 AM | #1307 | ||
Thank you, it needs a good detailing before I drop the body back on. Marc
07-28-2020, 02:41 AM | #1308 |
Coming together real nice Marc!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
07-28-2020, 11:58 PM | #1309 |
beautiful attention to detail
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
08-06-2020, 08:05 AM | #1310 |
Here's where were at. The exhaust is complete and fully bolted in (O2 sensors and all). This Sunday some buddies are coming over to help me drop the body on the chassis for the last time. I still need to detail/clean the frame before Sunday
In an effort to gain more radiator clearance I need about 5/8". Modifications were needed to the radiator and core support to gain some room. I use cooling components fans for a couple reasons. 1. they are a 2 speed fan that move some serious CFM's. 2. They come with a shroud. 3. They are quiet. They are not cheap but on my 48 it solved my overheating issues. http://coolingcomponentsinc.us.com/p...ucts/cci-1770/ I did a similar modification on my 48 but this time around it was better executed. I notched the flange on the top of the core support to move the radiator forward. I then broke loose the welds and I will realign the mounting flange to be vertical. As you know they have a slant from the factory to lean the radiator back. My fabricator friend Josh will weld it back together. These mods should create the space I need. While I was looking at things it became apparent that the top of the factory core support was ugly the way the ends terminated. So I trimmed them back some and capped them off... Now for the bad news. Both my radiator and core support were already painted. Some touch up will be needed here. Marc
08-06-2020, 08:09 AM | #1311 |
More pics....
You can see from the exposed aluminum where the brackets used to be aligned. This is a few pics of the capped core support. Marc
08-06-2020, 08:58 AM | #1312 |
Looking good Marc...Jim
08-07-2020, 06:07 AM | #1313 |
I've never liked how the radiators stick up past the factory shroud on these trucks. Since I'm on a S10 chassis the front frame horns and steering box rerally limit the depth of my radiator and made my Champion 4 core stick up way too much. I've since sold it since it wasnt working for me. I would like to find a rad that can fit within my dimensions and sit below this little sheet metal shroud I have.
Untitled by Spencer Wiedeman, on Flickr |
08-07-2020, 08:01 AM | #1314 | |
Thanks Jim
The hose outlets even lined up for my LT1 (which I think are the same as an LS). Since you are running a shorter radiator you will need a good "sucker" electric fan (see my recommendation in my previous post) and build a shroud at the bottom of your core support to direct air up into your radiator. Before I did that my 48 always ran hotter than I would have liked. Thanks Marc
08-08-2020, 08:38 AM | #1315 |
Looking great Marc.
I saw your post on "bickle" about your door seals from steele. Have you looked at Soffseal? really nice products Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
08-08-2020, 11:10 AM | #1316 | |
Marc
08-10-2020, 09:35 AM | #1317 |
Ok, so I hit a major milestone this weekend. I asked a few buddies over to help drop the body back on. A few areas I was worried about as far as clearances go was the following: The coil clearance to the firewall. The shifter clearance coming thru the floor. Everything turned out better than expected. The only exception was the floor by the tranny. I had to cut more of the floor than I wanted/intended. The thing that changed between mock ups was the drive line angle and the height of the tranny mount. I will just come up with a trans tunnel..
Overall I was stoked with the outcome. Keep in mind that these rims are 20's. I plan to run 22's. Considering that I painted the body panels separate from each other I was pleased how they look next to each other. Here are a bunch of pics.
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 Last edited by youngrodder; 08-10-2020 at 09:51 PM. |
08-10-2020, 09:37 AM | #1318 |
That is looking great.
08-10-2020, 09:37 AM | #1319 |
More.....
08-10-2020, 09:40 AM | #1320 |
More....
For comparison here is a before and after my paint distressing.
08-10-2020, 10:04 AM | #1321 |
Marc, looks great, nice job on the paint. Onward and upward...Jim
08-10-2020, 10:24 AM | #1322 |
dude.. so sick. Awesome work!
John J Bodied 1994 Suburban on custom frame - http://67-72chevytrucks.com/vboard/s...d.php?t=672297 Dad's 1948 Suburban - http://67-72chevytrucks.com/vboard/s...d.php?t=563150 Bagged 1995 Suburban - SOLD Bodied 1995 Tahoe -SOLD |
08-10-2020, 10:28 AM | #1323 | |
Thanks man...
08-10-2020, 11:56 AM | #1324 |
Post Whore
now that's what we've been waiting/wanting to see..!!!!...looks great Marc..!!!...
08-10-2020, 12:57 PM | #1325 | |
Marc
