08-22-2020, 03:14 PM | #1326 |
Post Whore
Re: A '54 named Busty
thanks found a brush on can of the same ACE brand black paint I've been spray painting with so I went with it cause I did not have to mask much and just ended up with a black forearm ha ha
Note: a quart was way way too much as my mima says a pinch would have done it |
08-22-2020, 03:42 PM | #1327 |
Post Whore
everyone's a ganghstah 'till it's time to do ganghstah stuff
08-22-2020, 03:57 PM | #1328 |
Those turned out nice. What do you do this time? Not the wire brush method right?
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
08-22-2020, 04:08 PM | #1329 |
Post Whore
Yeah...we got hurricanes pushing in...we always get crazy weather when they do
08-22-2020, 04:22 PM | #1330 |
Post Whore
wire wheels FTW
08-22-2020, 04:27 PM | #1331 |
Post Whore
08-22-2020, 04:53 PM | #1332 |
Post Whore
We get a few quakes here, but not like yall...to wet here to worry much about fires....
we got hurricanes and tornadoes and humidity and skeeters
08-22-2020, 09:03 PM | #1333 |
Post Whore
then I went out and rented this completely useless coil spring compression kit
and after badinkering with it for an hour or two I decided to give up on the passenger side cause clearly installation is NOT the reverse of removal, ha ha |
08-22-2020, 09:05 PM | #1334 |
Post Whore
THIS MUST BE WHAT HELL LOOKS LIKE !!!
08-22-2020, 09:10 PM | #1335 |
Post Whore
... but we still had beer so we pressed on
I decided to do the driver side My Way (hang the upper control arm, conjoin the spindle to it with the lower control arm attached only at the front to the spindle) then insert coil spring and gently jack the whole contraption up and whalla job done! |
08-23-2020, 03:42 PM | #1336 |
Post Whore
and today we completed the B Side of the Symphony of Destruction
join us next month as we overcome our money problems and set out to do the brakes |
08-24-2020, 08:33 AM | #1337 |
Man, that looks so good. Well worth the effort of cleaning everything and painting. Awesome job!!!
08-25-2020, 10:01 PM | #1338 |
Post Whore
08-25-2020, 10:08 PM | #1339 |
Post Whore
oh give me a brake!
08-25-2020, 10:09 PM | #1340 |
Post Whore
so since the front pads looked like they had plenty of meat on them I decided to see if I can salvage the front brakes and save a few duckets
08-25-2020, 10:10 PM | #1341 |
Post Whore
they actually cleaned up real nice and even passed the drop test, ha ha
08-25-2020, 11:30 PM | #1342 |
Post Whore
the passenger rotor cleaned up real nice as well
08-25-2020, 11:31 PM | #1343 |
Post Whore
and the mandatory stare and compare
08-25-2020, 11:33 PM | #1344 |
Post Whore
honestly the only thing wrong with these rotors was that the passenger side had a broken lug, simple fix really
08-25-2020, 11:36 PM | #1345 |
Post Whore
the calipers were next to get some love
08-25-2020, 11:37 PM | #1346 |
Post Whore
Ridges? We don't need no stinkin' ridges!
08-25-2020, 11:41 PM | #1347 |
Post Whore
and just like that we knocked off another 2 seconds off our quarter mile putting us well under 45 seconds, ha ha
so I used a sanding disc to take the ridges down, but here I just show you how I get every inch of bristles off my wiring wheels Last edited by Gregski; 08-25-2020 at 11:47 PM. |
08-25-2020, 11:43 PM | #1348 |
Post Whore
chics dig smooth calipers, just sayin'!
08-26-2020, 08:29 AM | #1349 |
That is a whole lot of work right there. Now are you going to get some of that fancy red caliper paint on there?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
08-26-2020, 08:53 AM | #1350 |
I like the brake work.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
