#1351 |
Re: 67 GMC super custom build
Well I started on the antenna install today. Its going to be a bit of work to get ths right but it will look so much better sitting without an antenna sticking up. Ill have to make the cover around the antenna tube strong to support the hood hinge .I also extended the bezel retainer so it can be reached once I fill the area where the antenna goes thu on the inner fender
#1352 |
![]() Join Date: Dec 2009
A Power antenna.
![]() I remember the Cadillac's that Momma drove had them. I liked the sound of them when you turned the radio on. BuuZZZZZzzz.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#1353 |
So I got it lined up and it's really good. Wil be straight up. The part i was worried about was there wouldn't be enough room and the antenna would be crooked and stick out of the fender but it doesn't at all. I have the bottom bracket made now I just have to make a upper mount.
#1354 |
![]() Join Date: Oct 2013
Straight fire.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#1355 |
![]() Join Date: May 2006
I always look forward to your posts, never know what is next, very well done and creative
That light bezel is going to be amazing, cant wait to see it
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#1356 |
Thanks. Im glad people enjoy it and hopefully some of you are using my ideas to spark your own ideas. Tonight I made the piece that will cover the antenna area on the upper fender.
#1357 |
As I was thinking about how to route the antenna cable lead i realized that the original cable from the cadillac had a ground strap soldered to it that went to the body. So I soldered one to my nos cable and it will ground to the firewall by the ac unit. Never seen that before on any car/truck I've ever had
#1358 |
Im still waiting for my fender to return to finish my antenna so im just doing small stuff not worthy of a post. Tonight I added a nos vanity mirror to the passenger side visor. Worked out great using the chevelle instruction sheet.
#1359 |
So I've started to make a plate for the ower window switches to mount them to the door panel. Im going to get some threaded tube and Weld short pieces to the plate so I can mount the switches and then I am hoping I can find a glue strong enough to glue the plate to the under side of the panel.
#1360 |
Great progress.
![]() What do you think about using CA glue?
#1361 |
I was thinking about the ca glue with the activator for low energy plastics. I might get a old junk door panel and try some on that before trying it on these.
#1362 |
I test fit my door panels again 1 more time to make sure the switches will sit properly before I do my final mounting and I thought I'd share this Picture. Things are slow but some pieces are starting to take shape. This photo gets me excited. Its starting to look like all the small things are getting taken care of and it wont be long till major changes start taking place all the way to paint. I try to do something small every day I can and the payoff isn't too far away.
#1363 |
Last night I went out with a buddy to look at some trucks being parted out and i found the bracket for the 67 style power steering that I've been looking for forever. Never thought I'd find it like that. Great find!
#1364 |
Passenger side is done as well. Just waiting for Amazon to bring me the glue.
#1365 |
So canada post strike sure held my stuff up forever. Anyway I tried 3 different glues for plastic to metal on the doors panels. Did 3 samples with the pieces of panel I removed from where the switches were and this is the only one that held. Was the only one worth considering. So dont waste your time with anything else if you really want it to stay on.
#1366 |
Smart to test. Always good to know it worked one time at least before you into it.
#1367 |
I agree. In reality I only had 1 shot at getting this right. That glue was so easy to work with. It requires a specific application gun but it was well worth it. Here's a shot of the panels assembled. I like that the switches dont look out of place and kind of follow the lines of where gm placed them in the cars of the 60's. Now once my fender comes back from my metal guy I can finish the antenna stuff and it's ready for final metal work. Hopefully soon!
#1368 | |
![]() Join Date: Mar 2008
NHRA Super Street 469C It only runs 10.90 at 156 mph I was Dragtruck when Dragtruck wasn't Cool! |
#1369 |
Got photos of my dash before shipping from. Just dashes today. Looks great from their photos!
#1370 |
BlahBlahBlah
Thats pretty cool. So you sent in your modified dash and I guess they just vacuum form the vinyl to it?
#1371 |
Basically yes. I made a template of cardboard and they replicated it in foam and vacuum formed vinyl over the foam.
#1372 |
![]() Join Date: Apr 2008
Looks factory to me
71 C10 72 K20 72 K10 Super Kirk |
#1373 |
Looks great.
![]() Cadillac era design with your Awesome design.
#1374 |
I got the pad today. Took a bit longer from ups because of the plane situation in Kentucky. Looks really good. I am happy with the results. Will look better once I paint the bezel again and it matches the new gauge cluster.
#1375 |
Wow. That looks fantastic.
| Bookmarks |
