05-17-2013, 02:19 AM | #1351 |
Re: Slosh Tubz new company project "Square Peg" frame laying 1987 GMC Jimmy
nnnnnn vvvvvvvvv.................
my rhd build.. http://67-72chevytrucks.com/vboard/s...d.php?t=468712 1964 CHEVROLET BISCAYNE 350CI/TH-350 1968 CHEVROLET C-10 SWB LS1/4L60E |
05-17-2013, 11:08 AM | #1352 |
I think I am building a car vicariously through you! I keep seeing these cool things I want in "my" hot rod. How 'bout an 8.9 liter V12 LS engine!:
http://www.corvetteforum.com/.../man...-ls-engine.php You wouldn't have to shorten the 6 cyl valve covers---I think that justifies it, huh? Posted via Mobile Device
JK |
05-17-2013, 11:11 AM | #1353 |
67cheby
LOL, thanks guys !
05-17-2013, 11:37 AM | #1354 |
http://www.corvetteforum.com/article...-ls-engine.php
the link didnt work this one does i have to say the man has mad welding skills , jesse james must be seeing green (braw lbrawl im the best there is brawl brawl)
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 05-17-2013 at 11:43 AM. |
05-17-2013, 12:54 PM | #1355 |
http://view.internetbrandsauto.com/?...640d7c7217&r=0
Try this one. I didn't notice that it was truncated before! Posted via Mobile Device
JK |
05-17-2013, 05:11 PM | #1356 |
theres a as cast V12 that uses mainly smallblock components for everything but the block and headcastings the crank and camshaft , falconer makes it , this LS1 V12 could be a nice new project for them
http://www.falconerengines.com/falco...2.php?v12=main startingprice 65000 ........hmmmm now where did i hide that moneytree
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
05-17-2013, 05:15 PM | #1357 |
67cheby
Wow
05-18-2013, 03:12 AM | #1358 |
thats insane...i want to know the firing order on that... its gonna be fun getting everything to work together it being efi and one of a kind..
05-18-2013, 05:43 AM | #1359 |
whell jaguar makes a v12 for years so they couldve used a (lucas) distributor from that
nowadays with all the electronics it isnt to hard to add a few more cylinders bmw uses two 6 cylinder distributers one per bank of cilinders i think they do the same with the injection i'm kindah wondering about the ignitionsequence of the 8 cylinder made 12 too , the story does say they weld up two cranks for it adding 4 to the 8 would make it run out of wack i believe ......... then again they could use V6 cranks and have two cylinders fire at the same time or 360 degree apart , doing it that way you could use a v6 ignition with double sparkplugs (cilinder 1 firing the workstroke while two is firing during the exauststroke) been looking into sumtin like this myself (lets just say benchracing doesnt cost a lot exept time ) http://www.jalopyjournal.com/forum/s...d.php?t=533613 i wanted the engines to sit inside the bed but running them the normal way around would make the setup to long to hook up to the rearaxle my idea was to run a setup like that reversed in the bed of a pickup close to the cab with the transmission sticking into the cab driving a v drive or transferbox in front of the cab then a driveline going back between the engines to the rearaxle or both wishever my thought where at at the time , the radiators would find a place at there original spot behind the grille the fueltank would prolly be behind that or at the rear of the bed i think it might make a good showmachine for mudbogging as most of the weight would be pretty centered the engines dont need to be special or realy powerfull as there both working , the expencive part would be the connection between the two engines and the trans , was thinking using gear camdrives sandwished between engineplates filled with engineoil like setup for that
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 05-18-2013 at 06:06 AM. |
05-18-2013, 08:43 AM | #1360 |
I know the pieces fit
Lets try not to get too far off track, there's a pretty cool build going on in here somewhere.
05-18-2013, 08:58 AM | #1361 |
Thats what I was thinking. I wanna see the slammed draggin arz Blazer.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
05-20-2013, 11:31 AM | #1362 |
67cheby
LOL....well here is some great weekend progress, lifted the mounts
05-20-2013, 11:34 AM | #1363 |
67cheby
next widened 1 1/2 inches and lifted 6 inches. It will have a false floor raised 6 inches to match the raise of the Tubs and then hinged for storage
05-20-2013, 11:34 AM | #1364 |
Looking good and sharp Mike!!!!!!!!!!!!
I'm getting ancy to see this beauty!!! AHHH!!!!!
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
05-20-2013, 12:26 PM | #1365 |
Love it!
05-20-2013, 03:34 PM | #1366 |
Nice job on the tubs
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-20-2013, 03:51 PM | #1367 |
By the looks of it, you would think someone was going to put large wheels and tires on it...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-20-2013, 04:01 PM | #1368 |
67cheby
Thanks guys ! We got a little love from Royal Purple today only the best for Square Peg !
05-21-2013, 12:46 AM | #1369 |
Looking good Mike!
-Rus |
05-22-2013, 09:09 AM | #1370 |
67cheby
well I ran out of welding wire last night so I decided to start my Step by Step Slosh Tubz install so here goes !
05-22-2013, 09:14 AM | #1371 |
67cheby
Step 1. Tape 2 pieces of poster board together
2. Lay the tubz down centered on the board 3. Trace the bottom shape onto the poster board 4. Cut out the bottom shape 5. I used the garage door, this works better if you have someone to hold it for you ! LOL, Place the cut out section on the back of the Tubz and trace out the arch of the Tubz |
05-22-2013, 09:20 AM | #1372 |
67cheby
6. Cut out the arched piece, this is what you will use for your pattern, save the other pieces they are the patterns you need to make trim panels to go around the Tubz
7. Now tape the pattern onto the inner fender with the bottom contour following the bottom contour on the fender (this will make more sense when you are looking at it all apart) 8. Trace the top of the pattern onto the fender 9. The bottom edge needs a line marked following the edge of the squares where the nut clips go in, once again this will make sense when you are looking at it 10. Now use what ever cutting tool you prefer and cut it out , I like a 4 inch angle grinder with a cutting blade |
05-22-2013, 09:24 AM | #1373 |
67cheby
11. Next you are ready to bolt in your Slosh Tubz !!
Note these Square body Slosh Tubz were designed around the 80-87 front clips, so there are going to be some modifications to make them work on the 73-79 clips, nothing major, just some of the bolt holes are in different locations so as soon as I get those done I will post those pics also ! |
05-22-2013, 09:30 AM | #1374 |
Sweet Tubz!!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
05-22-2013, 09:43 AM | #1375 |
looks good , i think the biggest problems with making tubs youreself from trailerfenders is making it fit the shape of the inside of the outer fender to prevent roaddebrees and stuff from collecting between the two parts
it might be an idea to run some channel rubber over the cut piece before installing the sloshtub nice thing about that is that you could hide quite a gap with it and prevent some of the wet gunk comming intoo the space between the inner and outer fender to drip down the visible side inside the engine compartment
