#1351 | |
![]() Join Date: Jul 2012
Re: 48 Burb, bagged, 5.3, 20 year wait
Mark, that would be awesome and is on our list! |
#1352 |
Awesome! just let me or Dad know when and we will be ready for ya
![]() Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#1353 | |
Simple? What's simple?
![]() Join Date: Apr 2007
I can install the compressor on the engine as it sits with the stock inners, but the pulley is *just* touching and the tensioner sits about a 1/4" too far outboard (below the compressor) to work with my engine location. I figured an inch would do me, that way I'll have 3/4" clearance and enough space to actually get a belt around the thing. I may bump it a little more than that, time will tell.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#1354 | ||
Worked on the fuel fill today and made a little progress. The fuel fill 90 degree elbow worked really well. Here I made use of a couple feet of 2 inch tubing to determine where hole needs to be. The digital angle finder was pretty handy to make sure the pipe runs uphill from the tank fill. |
#1355 |
And the outer fill pipe is coming through about right here. Now to figure out where it needs to pass through the fender. Hmm...make a pattern of the fender, make a wire form buck of the fender...?...lots of complicated ideas.
#1356 |
Finally thought of a much simpler solution and made a copy of the fuel fill pipe, except with a card board tube for the end.
Install the fender, insert the tube, trimming the card board end of the tube until it just touched the fender. Marked the contact area on the inside of the fender, pulled fender back off, drilled hole with hole saw and reinstalled. |
#1357 |
When your floor and inner wheel well are sprayed with Lizard Skin it's a good idea to chase out the threads before bolting the fender on. Amazingly I did think of doing this before installing the fender.
#1358 |
Just a little shaving on the fender and inner fender holes and this fill pipe should be good. This will permit the fill to drop into the hole a little more. Thanks dwcsr...nice job.
#1359 |
![]() Join Date: Mar 2007
Looks good (per usual) Doug.
is the plan to cut the filler tube at an angle so that the cap is close to the same angle as the fender? Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#1360 |
Thanks Marc, Yes, going for cap being parallel to the fender. I think if the fill drops in a little more, after a bit of hole clearancing, the cap will be there. If not, we will cut, chop, weld...
#1361 |
Thank's Doug for the offer on the fender, Dad said he will use the one he picked up.
Sub's looking good. Mark...
#1362 |
Great tip to chase threads after Lizard Skin being sprayed on.
I always do this, after paint and powdercoating. I would like the cap more to the fender also but I'm sure you will get that right ![]() Fuelpipe itself looks great!! Not much space I see on those old cars
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#1363 |
nice filler job. again the small details that most people will never notice. but take hours and hours of thinking and building.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#1364 |
Thanks Mark, Kees and 99. I agree Kees and 99, the cap needs to be parallel and closer....and it takes time! Here is where I am heading. Still have to refabricate the fill pipe.
#1365 |
Looks good Doug....I like it, I like it.
Marc
#1366 |
![]() Join Date: May 2015
I agree...I like it..looks as if it was made that way.
#1367 |
![]() Join Date: Mar 2011
Very nice Doug...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1368 |
Nice touch!! When you get the filler done it will look like the cap is glued to the fender. Ya I forgot to chase some of my holes after lizard skin acts like your cross threading.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#1369 |
That's the way I like it!
It's all in the small details
#1370 |
Awesome updates Doug, can't tell you how happy I am to see this one under way again. This is one of my favorite threads! As always your attention to detail is awesome, thanks for keeping me motivated.
-Richard
I may have too many Chevys... Is that possible? ![]() 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
#1371 |
Marc, Mongo, Jim, Lower, Kees and Richard thank you for your kind words. Really minor progress...though as we all tell each other ... progress is progress.
The fill tube dwcsr fabbed up would have been perfect if I could have placed it farther forward. In execution that idea didn't work and here we are. Now to connect pieces to fab up another fill that works here. Ordered two mandrel bent J pipes so I can whittle away at it. Probably Saturday. Headed to PRI in Indy tomorrow. |
#1372 |
Reconfigured the fill pipe to work with where I needed it to be by cutting apart what I had, then fabricating / cutting pieces to fit. Made it in three pieces and here are the first two going together.
#1373 |
Final piece in place...
#1374 |
Putting a bead on cross fill pipe for better retention and sealing in the connecting hose. Terrible picture, I know, as there is too much stuff in the back ground. Only picture of this I took.
#1375 |
The bead came out decent.
| Bookmarks |
