Old 11-20-2013, 12:09 AM   #1376
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
I'm envious! Any scuffin between the clear coats? Are you still going to cut and buff that?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 11-20-2013, 12:11 AM   #1377
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by litew8 View Post
Very cool
Originally Posted by nasqar View Post
OK, fine....I thought I was doing good with getting the bed painted....but dang bro, this is bed is incredible!!! Great job Mike, keep it up man.
Thanks Eddie. It has it's share of issues. trust me It's not as good as I wanted but it will work for the inside of the bed. The outside needs to be better. I have literally hundreds of hours in my metal panels. not including the cab repairs.
Originally Posted by Dieselwrencher View Post
Nice spray work!!! I'm jealous you have like no dirt or specs in there at all.
Thanks Ryan. Not so, they are there very small nibs they will easily sand out with 2000 or 1500. My old camera doesn't pick up all the small details
I also think photobucket is killing the resolution on the pics when I upload them.
mcbassin is offline   Reply With Quote
Old 11-20-2013, 02:54 AM   #1378
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Hey Mike! I'm fixin' to get ready on choppin my bed sides and wondered if you could sneak me a couple photos of them square holes along the bottom (spacing). Up at #1353 there's a good view of the row in front of the wheel tubs but I can't quite make out the ones behind. I'd like to take my sections where I can cut out some crud in the skin but want them holes to wind up where they oughta be. Not that I couldn't fill any wrong ones and make new ones, but it'd sure be easier to just section it just so. Paint is really looking good man. My eyes are peeled on the assembly and final. I think you've changed my way of thinking on how to go about it.
Old 11-20-2013, 09:32 AM   #1379
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Sorry, missed this last night. Yes it will be sanded and buffed. I'm going t let it cure for a while though. That was most likely the reason for the sand through in the first place. The clear blocks out quick while it's still green.
No scuffing between coats on the clear. "Most" activated paints and clears can be top coated up to 24 hours before scuffing is required.
Thanks for the props. I can take some pics tonight. I hope to get some assembly done on the bed.
Old 11-20-2013, 10:51 AM   #1380
Jahloha
Jahloha's Avatar
Re: 1969 Short Wide
Originally Posted by mcbassin View Post
Kyle had me a little worried so I double checked the A/C duct routing. A little tight with the cluster installed, but I believe it will work good.
Next I started prepping to paint the bottom of the bed and tubs:
Painted - single stage urethane cheap and easy:
Lined with Raptor liner:
Definitely like the raptor liner on the bottom side in these pics. Did you use this on the cab and front inner fenders as well?
What prep did you do?
Love what I am seeing on your thread!
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-20-2013, 12:06 PM   #1381
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks for checking out my build. I apologize for the length in advance....HERE is where I did the cab floor. Notice I added some heat insulating spheres to the Raptor on the bottom of the cab floor. The inner fenders up front will get the plain black treatment. Also, for reference I reduced the Raptor on the bottom surfaces so it doesn't build so high. On the top surfaces it's reduced just not as much. It will spatter big chunks if you leave it just as mixed.
As far as prep goes, I used 220 grit on a DA sander where I could reach and the red 3m scotch brite everywhere else. The light gray primer is Matrix epoxy and the dark gray is Omni epoxy.
On the bed floor (top side) I painted it with the same bc/cc that I'm using everywhere else. I did this so there would be no issue with gray spots. I know now the tinted covers good enough to skip this step.
Old 11-20-2013, 12:24 PM   #1382
Jahloha
Jahloha's Avatar
Re: 1969 Short Wide
Time for a small update:
I have been planning this for a while. I spent a few hours this week to fabricate some exhaust pipe mounts out of some scrap stainless I had in my shop. I couldn't find exactly what I was looking for anywhere so I just made them. I also bought THESE and THESE to use with my brackets. I know it seems overkill but I didn't want to use anything but stainless on the exhaust (hope to have $$$ for stainless headers some day).
Sorry some are crappy cell pics. I will get some better ones
On to the pics:
Sawed and shaped the .125" ss sheet stock:
Match drilled all the pieces:
I made some quick and dirty break/bending and forming tools:
Installed:
Holy cow! Its not even funny how jealous I am of your machines and machining skills. I gotta find someone in Utah who can help with with customized brackets when I need them on my build, but will probably farm it out. Ugh.
-JASON
Old 11-20-2013, 01:52 PM   #1383
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks.
Awe, bringing back some good memories of my exhaust fabrication.
On the custom parts, It is a fringe benefit that comes with the this job. I don't like farming out anything I can make for the most part. Sometimes I just buy parts that are easily made. Sometimes I make things that are cheap to buy.
Old 11-20-2013, 02:11 PM   #1384
Pick
Pick's Avatar
Re: 1969 Short Wide
You just showed me a use for the hardened, unground V-block I have had in the bottom of my tool box since college!
Seriously, you do nice work and come up with some nice solutions to problems! I enjoy watching and learning!
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 11-20-2013, 02:26 PM   #1385
Low Elco
Re: 1969 Short Wide
X2! Nice fab work!
What do you reduce Raptor with? Do you need to do that where you want it "pretty"?
Low Elco is offline   Reply With Quote
Old 11-20-2013, 02:55 PM   #1386
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks, I don't have a press brake so I made a small one. It's handy on small brackets.
Originally Posted by Low Elco View Post
X2! Nice fab work!
Thanks. I used standard urethane reducer. Not very much maybe 5-7%?
I think, and I may be wrong but it seems temperature sensitive too. The cooler temps like we have had lately make it less "pretty". It's pretty thick anyway but when it's 95 in the summer it seems to flow and lay prettier. Ya know.
Old 11-20-2013, 07:43 PM   #1387
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
I'm almost sure I did, but if I didn't comment back when you posted them exhaust fab photos - stellar work!
Old 11-20-2013, 09:45 PM   #1388
knomadd
knomadd's Avatar
Re: 1969 Short Wide
Awesome exhaust mounting idea! Wanna come to the Houston area and do mine?
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-20-2013, 10:07 PM   #1389
swamp rat
swamp rat's Avatar
Re: 1969 Short Wide
X2 to that, i have unground and also my good ones.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-20-2013, 11:31 PM   #1390
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1969 Short Wide
It sure would be nice to have a mil and a lathe in the shop. A guy could make all kinds of things with those 2 (expensive) tools.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-21-2013, 01:30 AM   #1391
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks. Good to see those pictures again.
Thanks and Sure I like the Houston area.
Thanks. I have some big ones 6" I think, those would bend some longer parts.
I have a nice little lathe in my shop still looking for a bridgeport or copy to stick in there. No where to put it right now even I did find one. But I have access to about any kind of machining center at work
Old 11-21-2013, 02:01 AM   #1392
litew8
litew8's Avatar
Re: 1969 Short Wide
Those custom hangers are nice looks super
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 11-30-2013, 11:50 PM   #1393
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks.
Old 12-01-2013, 12:04 AM   #1394
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Finally got past the backward steps.
Had to touch up some more sand through and re-clear on the bedside.
Warning: don't sand through your clear coat, it's a pain to fix.....
Bed assembly begins:
Fitting the tailgate:
Prepping the tailgate for paint:
Old 12-01-2013, 12:06 AM   #1395
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: 1969 Short Wide
Great work mike!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 12-01-2013, 12:58 AM   #1396
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 1969 Short Wide
Lots of little things add up to a lot. Love seeing it come together.
Zoomin is offline   Reply With Quote
Old 12-01-2013, 01:01 AM   #1397
Jahloha
Jahloha's Avatar
Re: 1969 Short Wide
I am loving that bed!!!
-JASON
Old 12-01-2013, 01:31 AM   #1398
swamp rat
swamp rat's Avatar
Re: 1969 Short Wide
I guess a lot of these paints can be sprayed right over the clear and then be re cleared again, so i hear anyway.. Your doing great work!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-01-2013, 09:29 AM   #1399
Bennett68C10
Bennett68C10's Avatar
Re: 1969 Short Wide
Looks awesome Mike
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-01-2013, 09:43 AM   #1400
Crash_OK
Crash_OK's Avatar
Re: 1969 Short Wide
Dang... Looking really good Mike.. If you are working this week on it I will come out and help you/hang out...
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
