Old 01-03-2013, 04:20 PM   #1376
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Kabwe's aka Bam's build
Originally Posted by Chevette View Post
For the "frame to the caliper" I bought "Stop-Tech" braided stainless lines. I will use good quality nickel/alloy from the master to the braided. I figure with the limited amount that I will drive the truck, nickel lines will outlast me and after I'm dead and gone, I could give a rats behind what happens to my replacement.
I was talking fuel lines.lol I ran steel brake lines to the braided stainless steel caliper lines.
My fuel lines are 3/8 braided stainless steel for the supply and return that is on the corvette regulator/filter to another 3/8 braided stainless steel supply line that goes over all the bends and turns and then I have a straight shot that allowed me to use a 3/8 hardline that runs the length of the frame. I wanted to run that hardline over all the bends and turns but as you know 3/8 stainless steel tubing is a mother to bend and it was just too many bends so I went with a flexible stainless steel line to the hardline.
I totally agree that steel or nickle lines with out last all of us.lol
Kabwe is offline   Reply With Quote
Old 01-03-2013, 04:40 PM   #1377
bowt1ed
Hey BAM, got any recommendations on fittings for the braided to s/s hard lines? I'm at that stage on mine (actually haven't done anything since receiving the hard lines a few months back - I know, I know..) and ready to kick it up again. Thanks, Jim
bowt1ed is offline   Reply With Quote
Old 01-03-2013, 05:19 PM   #1378
Chevette
Chevette's Avatar
I totally agree that steel or nickle lines with outlast all of us.lol
Perhaps I should go for an overdue eye exam. Apparently I don't see so good. Fuel lines are a ways off for me.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 01-03-2013, 07:34 PM   #1379
Kabwe
Certified Car Nut
Kabwe's Avatar
LOL. I was wondering.lol But its okay we all have brain farts at one time or another.lol I know I do.
I used female 6-an fittings on my braided hoses (I had them custom made cheap locally). I then flared my hardline and used a 6-an sleeve and nut and used a 6-an male union. Here are the parts from Jegs.
Tube sleeves
Tube Nuts
What you do is install the sleeve and nut and then flare you tubing with a 37 degree flaring tool (the tool must be rated for stainless if you are using stainless. That some strong stuff). The sleeve slide up to the flare and the the nut over the sleeve.
Union fitting
By the way here is my flaring tool it works great and the flares are perfect.
Old 01-03-2013, 10:16 PM   #1380
ZR2RICK
ZR2RICK's Avatar
Nice to see you back at it, say can you tell me what made you decide to use a parallel 4 link? I'm trying to decide on weather to just use blocks and air over leafs like "58 GMC" or a triangulated ,parallel, or wishbone type link set up, my chief concern is maintaining fender clearance ( i have 1/2" )through 5-6" of travel since I intend to bag the rear also, and I know the parallel set up allows some lateral movement but can't seem to find any info on how much?
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline   Reply With Quote
Old 01-04-2013, 12:01 PM   #1381
VDOG
Grand PooBaa Member
VDOG's Avatar
Hey I have been looking for one of those flaring tool thing-a-mug-jigs to use when im flaring my mufflers and intake manifold. Can I borrow it?
LMAO!!!!!
VDOG is offline   Reply With Quote
Old 01-04-2013, 02:39 PM   #1382
Kabwe
Certified Car Nut
Kabwe's Avatar
The number one reason I went to a four link was to avoid wheel hop. Now if I were doing it again I would have went with a triangular link system. I just like them better. With the parallel setup you have to use a panhard bar to avoid lateral movement.
LMAO!!!!!
You are to be ignored.lol Anybody that thinks they can flare a muffler with that tool needs to seek psychiatric help.lol
Old 01-04-2013, 07:52 PM   #1383
VDOG
Grand PooBaa Member
VDOG's Avatar
Originally Posted by kabwe View Post
you are to be ignored.lol anybody that thinks they can flare a muffler with that tool needs to seek psychiatric help.lol
lol!
Old 01-05-2013, 01:14 AM   #1384
Kabwe
Certified Car Nut
Kabwe's Avatar
I did not get much done over the holidays but luckily I was able to get the stainless steel fuel lines installed. I still need to install the internal fuel pump that recent came in the mail. Honey dos are killing me.
Anyway here you go
Old 01-05-2013, 11:41 AM   #1385
Kim57
Kim57's Avatar
Looking good Bam.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-05-2013, 01:36 PM   #1386
Dan in Pasadena
Dan in Pasadena's Avatar
Hi Bam. A belated Merry Chrstmas and a Happy New Year.
Why stainless? Any trouble with splitting, bending it? I've read horror stories on other threads about this. What brand/type bender are you using?
Edit: Oops, NEVERMIND! Helps if you go back and read the author's prior posts, huh? lol.
Dan in Pasadena is offline   Reply With Quote
Old 01-05-2013, 04:19 PM   #1387
VDOG
Grand PooBaa Member
VDOG's Avatar
Those are some nice neat lines your running. Now one thing I notice your prop valve, did not know you could run them upside down.
Old 01-06-2013, 12:08 AM   #1388
Kabwe
Certified Car Nut
Kabwe's Avatar
Geez Vdog,
It must be hard on you being wrong all the time, I feel for you man.lol There are in and out ports that are clearly labelled and its flowing in the correct direction.
Old 01-07-2013, 01:25 PM   #1389
VDOG
Grand PooBaa Member
VDOG's Avatar
Geez Vdog,
Man when you cut you cut deep. LOL
I guess it was more of seeing them mounted right side up.
Old 01-07-2013, 01:52 PM   #1390
Kabwe
Certified Car Nut
Kabwe's Avatar
Well maybe you need to get out more. Parkwood also mounted his like this.
If it stinks everywhere you go, well maybe its just you.lol
I feel for you man, sometimes a mind can be a terrible thing.lol
All jokes aside, how is your build coming along? Have you gotten anything done recently?
Old 01-07-2013, 08:59 PM   #1391
VDOG
Grand PooBaa Member
VDOG's Avatar
I managed to get to pick your part for the half price sale on New Years day and found a GMC grille. Other than that, with the weather being off and on and it sitting on the ground I have not had much luck doing anything else.
This weekend im going to get the suspension parts from CPP.
Thats it.
Old 01-28-2013, 05:18 PM   #1392
pbetts
Hi Kabwe and fellow enthusiasts. Congratulations on your beloved truck. I'm envious of your talent. Your build inspired me to sign up after I read most of this enormous thread. Anyway, I've got an old 56 small window longbed with a rust problem. I sanded it down with velcro style sanding pads using my drill about 12 years ago (before I sold it) and sprayed regular spray can primer on some spots and etching primer on the hood (yellow tint) but the rust is back. Now I've re-acquired the truck and am looking to get serious about the body. My questions are this: what did you use to sand down the body? What kind of primer/paint do you use to seal it? Do you recommend products like POR 15 to treat it? It's mostly just surface rust.
pbetts is offline   Reply With Quote
Old 01-28-2013, 08:08 PM   #1393
ratty 46
Surly you're not going to rin that paint are you??? Those paint jobs take years to develope.
Just say no to POR15!!
Repower & drive it like it is.
R46
ratty 46 is offline   Reply With Quote
Old 01-28-2013, 08:15 PM   #1394
hotrod1
56 - autocross
hotrod1's Avatar
I think that is a great patina finish!
hotrod1 is offline   Reply With Quote
Old 01-28-2013, 08:43 PM   #1395
Kabwe
Certified Car Nut
Kabwe's Avatar
If you want to keep the rust I'm not the one to ask its not for me or what I do. As far as what I use to get rid of rust. I had my cab media blasted (be picky if you go this route and only work with guys experienced in blasting cars), but all other items I removed the rust myself with a DA sander and some phosphoric acid for the hard to remove stuff.
What I use to protect the metal? I like 2k epoxy primer. Do you have an air compressor? If you do you can buy a cheap Harbor Freight spray gun to to shoot the primer.
As far as Por15, I know guys who swear by it, but as for me I don't use it. I remove all traces of rust that is within my reach.
Build your truck the way you want and don't worry about what others would do. If anybody tells you to do something to your truck that you personally don't want to do tell them to step off. Its your time and money and you are the only one that has to like it. I would never tell someone what to do with their cars but I will share any information I have that could help them accomplish their goals. Their goals not mine. So feel free to ask me and if I have the answer I will be happy to share.
By the way nice truck you have there and welcome to the site.
Old 01-28-2013, 09:41 PM   #1396
docrock
docrock's Avatar
Bam, you are the king of appropriate responses and political correctness. Going for a political career?
BTW nice work on your truck
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 01-29-2013, 12:11 AM   #1397
Kabwe
Certified Car Nut
Kabwe's Avatar
I actually think I'm not being politically correct. Lately, it seems political correctness is for people to think just because they like something everyone should like it.
I went to car show this weekend and heard a lot of that. Its my petpeeve it really is. Be glad for anyone building anything and keeping this hobby alive.
Old 01-29-2013, 07:55 AM   #1398
xpickup
xpickup's Avatar
Kabwe, very good advise on building your truck the way you want it and not the way everybody else would. Because you will never please everyone. It keeps them all different.
Shannon
xpickup is offline   Reply With Quote
Old 01-29-2013, 11:38 AM   #1399
dhaymaker
dhaymaker's Avatar
I actually think I'm not being politically correct. It seems politically correctness is for people to think just because they like something everyone should like it.
I don't know about "politically correct", it's just one of those terms people like to use (such as "patina")! But, I do like the fact you speak your mind, while seeming to want to avoid stepping on toes or stepping on others' opinions. That's a good thing, these days!
As to your truck, I've been following your build and it's really nice to see another example of someone paying a lot of attention to detail, doing things the way they want, and doing things correctly! Just my opinion!! don
don
"The DRBMan"
2014 Audi A4 (The Wife's Daily Driver)
2017 HD Ultra (The Cruiser)
2003 HD Fatboy (The Ride)
2001 Chevy Suburban (Another back up!!)
For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!!
dhaymaker is offline   Reply With Quote
Old 01-29-2013, 11:51 AM   #1400
Indian113
Indian113's Avatar
One thing that stands out in your build is you try to think things thru and do it right the First time. I've gotten a lot of really good ideas from following your build. Thanks for the help!
Indian113 is offline   Reply With Quote
