Old 05-01-2024, 08:18 AM   #1376
MP&C
MP&C's Avatar
Re: 55 Wagon Progress
We had ordered a 4 position switch for the power windows in the wagon, with plans to install in the console. Not knowing the origin of the part when it showed up, I thought some due diligence was in order and broke out the multimeter to test all the switch positions for connectivity. Wouldn't you know, one of the end switches had no contact in one position. Further investigation showed that the spring contact board was held in place with four tabs from the factory, except we only had three, which allowed the board/switch to lose contact. I sent the next picture of the damaged part (pointing to the damage with a white wire) in a message to the eBay seller who immediately questioned my abilities with a multimeter and assured me it functioned exactly as it should.
So for a more direct approach, I assured them I knew how to operate a multimeter, and perhaps they should look at the attached picture this time. To help eliminate any interpretation errors, I had doctored the original rear view picture to make things more obvious since they missed the visual cues the first time....
Oh, that. We'll send out a new switch. Thank you..
So with the console on hold to make sure we didn't have to use a different style switch (in case their whole batch was bad) we turned our attention to the tailgate, and started the fit up of the Mad Mooks polished stainless border trim. https://madmooks.com/ To preface, I will say the Mad Mooks parts are some of the nicest fit and finish parts you'll find ANYWHERE to trim out your Tri-five Chevy, as well as parts for other GM vehicles. Only the corner pieces didn't fit our tailgate. It appears that when yours truly did the rust repairs of the tailgate (before repop's were available) the replacement patches weren't exactly spot on. So yes, this is my F-up..
We had also ordered some stainless strips for the voids in the tailgate from McMillan Rod and Custom and wanted to retain the stainless border to use with these parts.
We had some 19 gauge stainless in stock, so let's give this a go. First order is to make sure we can duplicate the dimpled hole for the countersunk screws...
Next, the folded (side) flange on the trim piece is a consistent width and will need to be real accurate. So we opted for a hammer form to match the shape, used a tipping die to thin the bend location (to tell the metal where to bend) and a backstop on the Lennox to set the flange height. A paper pattern was used to capture the tailgate outline.
After the flange had been folded, the top part of the hammer form is set aside and the bottom section used to hold the part for polishing. We'll get it polished, trim the width and punch dimple holes, and then do a final polish.
Test fit looks much better to match our one-off tailgate.
Robert
MP&C is offline   Reply With Quote
Old 05-09-2024, 08:50 AM   #1377
MP&C
MP&C's Avatar
We got the other side trim done for the tailgate and I had been asked to show the hammer form in more detail, so here's another go.. We actually started by pulling a paper pattern of the profile, some autobody masking paper is taped to hang over the edge, and the tracing done to show where to trim. Although we didn't have the plastic in the way at the time, here the pattern is after trimming.
This is the pattern we use for the overall of the stainless, so that once the flange has been folded we will have a border of paint surrounding the trim (set in somewhat). Once the 19 gauge stainless has been trimmed to match our pattern, we use the tipping die in the Lennox to thin the "bend line", this gives the metal a suggestion of where it needs to bend so we should have a somewhat sharper crease given how the MDF tends to compress under a hammer blow. Where I would normally use one of our round backstops on the lower die, this shows to leave us without contact with the backstop at the initial entry and final exit from the machine, as the backstop is centered on the die. To correct that, we opted for 3/4 flat stock that gives us contact the entire width of the die set.
The backstop distance sets the height of the side flange of the trim, and here is the stainless after running through the tipping die for thinning the bend line.
Then the stainless is clamped between our MDF hammer form, note the outer portion of the hammer form matches the thinned bend line exactly.
The Sandwich is held together with screws and then clamped in the vise for the hammering operation...
https://youtube.com/shorts/5WiGK0550...bhT7Mo5BjpPIHR
Once complete the bottom half of the hammer form becomes a stable base for pre-polishing, and some shorter screws are used to keep thing in unison. We use our typical polishing sequence of 400, 800, 1500, and then polishing on the buffer using green compound for a darker hue.
https://youtu.be/3OGAjPCnGwQ?si=cryFGWW1Q2eeEVfL
After the initial polish, the outer flange is covered with masking tape (to protect from scratching at this next step) and calipers are used to set the width and mark the cut line, like shown here..
The bulk is trimmed away using our Milwaukee M18 shears, and final done using Wurth snips. The edge is fine tuned with our Dynabrade belt file, and then the holes are located and dimple countersunk. Then another polish job, and all the parts are located in prep for drilling the screw holes into the tailgate. Really happy with the nice parallel setback from the edge with these new trim pieces to match my patch panels.
Next we'll get all the holes drilled and our upholstery added in the center...
Robert
Old 05-29-2024, 09:35 AM   #1378
MP&C
MP&C's Avatar
Got some pics from JB at the upholstery shop yesterday. The Radio Flyer wagon is now complete. He was initially going to do tan upholstery, but when he laid the red against the wagon he said the wild color won out. Better match to the build. So this little wagon was painted in Leonardtown MD, lettered and striped in Hummelstown PA, and now upholstered in Lexington SC. It really gets around..
Robert
Old 05-30-2024, 12:32 AM   #1379
mongocanfly
mongocanfly's Avatar
WOW..!!! that is slick!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-15-2024, 07:41 AM   #1380
MP&C
MP&C's Avatar
Some pictures from my recent trip to pick up a new shop truck... July 3rd, I flew out of BWI about 8am with a layover in Denver. Then a connection up to Redmond Oregon.
The truck had some dry rot on the old tires, so rather than tempt fate, I sprung for some new tires and the two fellas I dealt with, Chuck and Robert, went above and beyond to help get the truck ready.. while one was picking me up from the airport, the other was picking up the wheels/new tires from the local Discount Tire.
Upon arrival I find about the most solid, original 1966 I have ever seen. We looked over a few things and installed the wheels/new tires on the truck. My departure was the first test drive. Got to have faith in the old 66..
https://www.youtube.com/watch?v=rKTU0pc7Oqk
I drove south of Terrebonne to Redmond, stopped at the local Walmart for some essentials. A cooler, drinks, ice, a fire extinguisher, and a suction cup phone mount for map navigation.
Heading east out of Oregon towards Idaho. 4-65 AC at its finest.
I wanted to drive past Boise the first day to get an early start around SLC the next day. So I drove halfway between Boise and the Utah border, and stopped at a local rest stop. Set the alarm for about 4 in the morning. Just about had the rest area to myself.
Utah here we come...
I had reached out to Mike to stop by his place for a shop tour, but alas, he had to work the 4th, and with me facing 40+ hours of driving, it wasn't a sit and wait kind of day. I'll have to make time to visit the next time through..
Wyoming. A lot of wide open, with mountains of all shapes and sizes. They even have some that look like someone's been playing Jenga on a grand scale, flat rocks with rounded edges stacked one on the other. The pyramids have nothing on these Jenga mountains of Wyoming. They have plenty of exits off I-80, but most go nowhere. There are exits to put on tire chains, exits to take off tire chains, exits for trucks to park and sleep, and for the messy truck drivers, exits to park and sleep WITH dumpsters to clean out your trucks. Then the exits that go nowhere, but open up to the gravel wide open.
Then there's the entertainment. It's a stock truck.... So I had to sing to myself.. For 3-1/2 days... It was painful to listen to. I may now be a well practiced singer, but not one anybody would care to listen to..
One thing Chuck was not able to get fixed, the gas gauge. He had installed a new sending unit to no avail. Given the 18 gallon tank and an estimated 12 mpg, I should have a safe range of about 200 miles per tank without fear of running out. Just in case, Robert had fixed me up with a couple 5 gallon gas cans so I would have a reserve.
So at every fill-up, I would observe the mileage, bump it by 200, and note it for when I needed fuel.
Knock on wood, this process served well, and I wasn't forced to use the back-up supply of fuel the entire trip. I checked the mileage the second tank and was getting about 12.5 per gallon. About what I expected with a 352 with 3.50 gears and a granny gear 4 speed.
I was chastised by my wife and daughter with the accommodations I was using, so Thursday evening I made it into Nebraska and found a motel for a shower and more comfy bed (over a 1966 front seat)
Robert
Old 07-15-2024, 07:43 AM   #1381
MP&C
MP&C's Avatar
The truck was performing better than expected, but I was losing a touch of oil. Travelling the interstates at ~70 mph, and given tire size and gearing, the old truck was revving about 2850 rpms. Perhaps some oil loss was expected. The transmission housing did have some oil on the outside, so I suspected valve covers. A rear main seal was ruled out as there was no clutch slippage or drips at the front of the bell housing. We were in Nebraska and heading to Hastings. Scenery a bit flatter than the neighboring Wyoming.
I've always considered 3 my lucky number, so I had to capture this....
My stop in Hastings on Friday was at the World Headquarters of Imperial Wheeling Machines. My good friend Pat Brubaker, the owner, dug up a ratchet, extension, and socket so I could snug up the valve cover bolts. The rear bolt on the drivers side proved to be the (a) culprit, with a good two turns to snug up the bolt. After talking shop with Pat, he suggested (as did others) that I stop at the Speedway Motors Museum of American Speed in Lincoln, NE. Quite a bit to take in...
I did find an engine I could use for the new shop truck...
and what is likely the first ramp truck in existence.
Next we headed into Iowa, and a visit that has been on the bucket list for quite some time...
Quite a step back in time.....and the visit would not be complete without a picture in front of the mural...
I could have stayed for a day or two, but didn't want to wear out Joe's hospitality. That, and there was a storm heading in and I wanted to stay in front of it..
I headed the more southerly route on I-74 to bypass Chicago and head towards Cincinnati for our next shop tour, set up for Saturday morning. I drove into Indiana and found a rest stop. And set the alarm for 430.
Robert
Old 07-15-2024, 07:45 AM   #1382
MP&C
MP&C's Avatar
Saturday we had about a three hour drive to our next stop southeast of Cincinnati, at Cornfield Customs. Mike Wagner is among the premiere craftsmen in the country when it comes to metalshaping, it was nice to get to see his shop and some of the projects he has going on.
Mike's shop is a mix of both new and vintage equipment, here is an early Pettingel power hammer that came out of a local warehouse. If only it could tell stories of it's past life...
One of the projects, an all aluminum fabricated hood for a Galaxie, complete with tear drop hood scoop.
Before leaving I had to get a picture next to his 61 Unibody Salt Flats push truck.
Mike, thanks for the hospitality!! From there I had about a 9-1/2 hour ride home. Here's what 11 states worth of bugs looks like...
I had noticed that the fuel economy appeared to be getting better. Or more precisely, that it was taking less fuel to fill up at about the same mileage reading using the tape notation method. So I broke out the calculator again, the last tank was 14.1 mpg. My driving started at about 4 pm in Oregon on Wednesday evening and I was home all safe and sound back in Maryland Saturday night at 9 pm. Quite an adventure.
Robert
Old 07-15-2024, 10:44 AM   #1383
Russell Ashley
Russell Ashley's Avatar
Wow, nice trip, and nice truck to bring home. Thanks for the pictures. I have thought about a cross country drive like that but the time never was right so I haven't done it.
Russell Ashley is offline   Reply With Quote
Old 07-15-2024, 12:17 PM   #1384
joesscamaro
What a road trip! Some beautiful scenery and a cool truck to bring back home. Thanks for sharing. Do you have future plans for the truck? I'm assuming that is original mileage, considering the condition it appears to be in?
joesscamaro is offline   Reply With Quote
Old 07-15-2024, 01:39 PM   #1385
MP&C
MP&C's Avatar
Mileage is actually 134,xxx. It was owned by the same family since 1969 and has always been garaged/barn kept. It had a camper shell on for quite some time, which helped to keep the bed floor so nice.
Plans include some disc brakes for safety, and a T5 or similar so we can get a bit better mileage and be able to drive somewhere without revving so high. Then drive the wheels off.
Robert
Old 07-15-2024, 07:26 PM   #1386
mongocanfly
what a great road trip..!!!! nice shop truck as well.!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-15-2024, 09:28 PM   #1387
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
What an awesome road trip...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-16-2024, 09:07 AM   #1388
HO455
HO455's Avatar
That was an unexpected surprise posting. Thanks.
You were just over the hill from me. Did you drive through the Columbia River gorge on your way east?
Which engine does the truck have? 352 or the 223?
RIP Bob Parks.
Old 07-16-2024, 10:23 AM   #1389
MP&C
MP&C's Avatar
South to Bend and then 20 across to I-84. This one has the 352. Many I’ve seen from that area have the 352 over the 6 cyl. They must have been thinking about the mountains when they ordered it. It sold new in Portland, and the second owner bought it in 1969. I got it from his grandson.
Robert
Old 07-16-2024, 06:54 PM   #1390
HO455
HO455's Avatar
Ah yes, you slabbed it through the desert. If you had had more time you could have gone north on 97 to 84 and seen some of the best scenery Oregon has to offer.
Both 352's I've been around have been dependable, bulletproof, (heavy) and not really considered as powerful.
Nice truck and cool history.
RIP Bob Parks.
Old 07-17-2024, 09:32 AM   #1391
7dee2
7dee2's Avatar
Sweet shop truck congratulations! I’m guessing Oregon was the place to be, my wife and I did a road trip also to Portland about the same time to pick up a new 4-post trailer lift. We might’ve even passed you on the freeway somewhere en route to Utah.
Brett
66 El Camino: BBC, 4sd. Waiting for its turn.
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 09-30-2024, 12:43 PM   #1392
MP&C
MP&C's Avatar
Been playing catchup for a while since my cross-country venture, time for some long overdue updates. Finishing up on our tailgate, the last stainless pieces of the puzzle came from McMillan Rod and Custom in WI. Pretty good source for polished stainless trim pieces...
We had emailed them dimensions for existing holes in the tailgate, and the welded studs were spot on.
All our stainless parts added for a test fit/pre-drill/pre-screw of all the hardware to insure they'd go in straight during final assembly. Here's my contribution to the upholstery effort on the car....
And our tailgate installed....
And our update would not be complete without the requisite back up and punt moment. As we were closing the tailgate there was a slight binding as the tailgate was all but closed. Hey, you know my luck by now. Seems our trial fit in bare metal showed no issues but now we had multiple layers of paint that didn't want to play nice. The hinge notches in the bottom of the tailgate skin were digging into the inside of the hinges..
At this point a hinge is an easier repair than a completed tailgate, so the hinges were milled down .080 on that face and the countersunk holes deepened that much as well..
Then about three rounds of epoxy, block, repeat to eliminate the casting flaws, and on to the organic green kandy basecoat once more...
And then groundhog day, install it once more, with much better results this time.
Robert
Old 10-01-2024, 06:50 AM   #1393
MP&C
MP&C's Avatar
Some updates on the shop truck... When I picked up the vintage farm tags in Delaware the gentleman was having a men's yard sale with plenty of car parts, etc. I picked up some stainless hub caps and trim rings, I just needed to hammer out some dings and paint the letters.
I had installed a used SUN tach to keep track of the rpm's. Not the one I wanted, but you just don't find used Rotunda tachs sitting on a shelf. Or do you... a couple weeks after installing the SUN I found a gentleman in Idaho that rebuilds the Rotunda's. He did have one rebuilt, ready to go. I will say the Rotunda is like a fine Swiss watch when compared to the Sun, a high-quality movement.
The Rotundra did come with a stainless flat mount for installing on a dashboard, and I needed a column mount so let's fabricate...
Another thing I was looking at doing was to fill out those rear wheel wells with a bit more tire. I had searched far and wide for a 15 x 8 stock steel wheel but they always seemed to have the wrong back spacing. I finally had more luck when a friend said he had some Jeep wheels in that size, with the correct bolt pattern. A test fit showed the back spacing to put this one about as dead center in the wheel well as you can get.
Now we have the wheels media blasted and dropped off for powder coating.
The tires installed should have about 3/4" clearance on either side..
Robert
Old 10-01-2024, 02:16 PM   #1394
MP&C
MP&C's Avatar
Well, it's about high time we got back on the console...
We had designed the "hoop" to go around each leg of the horseshoe shifter, and to hold bulb seal rather than a strip brush, for a cleaner look. When we ordered the shifter it came with the new clear bezel for gear indication, but since we didn't have the factory console and it's matching parts, it was a bit much for us to incorporate into our fabricated console. In an attempt at simpler is better, one of the hoops was made with a wider flange for adding gear indicator nomenclature.
Well, we have been waiting awhile for our turn in line at the machine shop, and that day finally arrived
Next was the layout of the locations...
The ends of the slots were cut using a 5/8 diameter RotaCut, joined together between with a Milwaukee M18 14 ga shear, and trimmed afterwards using Wurth snips.
https://youtube.com/shorts/vA83vJVWn...KUzlgmDHCVFgM7
Then the 4-way power window switch was added to the rear, using the same process.
And lastly, our AC vents added. I didn't have any RotoCuts in the 2-1/2 diameter, so we opted for using a hole saw. They can be sketchy when cutting through sheet metal, with the pilot drill wanting to pull the hole sideways. So we sacrificed an extra holesaw arbor to make a bolt-in guide, and changed the pilot bit out for a piece of 1/4 round stock.
Holes deburred and vents installed..
Final version
https://youtube.com/shorts/P94H8M4Ut...YffFOc_l96Whkg
https://youtube.com/shorts/6lWksNqKv...sE_F7LUX7CDUhV
Robert
Old 10-02-2024, 11:56 PM   #1395
MP&C
MP&C's Avatar
I got the 15x8 wheels and 285/70-15 tires installed on the rear of the shop truck. Sure changes the attitude...
Robert
Old 10-09-2024, 09:42 AM   #1396
joesscamaro
The progress on the wagon is incredible! The shop truck is looking nice too!
Old 12-04-2024, 08:34 AM   #1397
MP&C
MP&C's Avatar
Thanks Joe!
More progress on the wagon...
We've been working on the wiring, starting with the gauge cluster. A loop was added between the gauge's mounting screws to provide a bit of strain relief for its harness.
Some of the bundles coming off the fusebox were excessively long, so we made use of fresh connector contacts to shorten the length so we won't have a rat's nest to hide under the dash. We did find the wires to the dimmer switch were too short by a couple inches, so the wires were re-routed too the side of the fuse box for a more direct approach.
The addition of the FI Tech and HyFire 6A ignition components gave us some challenges for power feed wires, so some circuits were changed to "keyed" in order to provide the additional battery circuits required. The original text is easily removed with a few scrapes of a utility blade. My lettering skills are nothing to write home about, and given the size, I used a double stack of lens for these old eyes in the form of reading glasses and a cheater lens inside the welding helmet. First time I've used a welding helmet to paint something.
We needed a mounting location for the Ignition module, and I still can't bring myself to drill holes in this firewall and hang such a wart on it.
Since we had shaved the radio location to clean up the dash, this provided a bit of real estate directly behind the dash.
Our stainless trim insert we made for the dash provided us some hardware for a mounting plate, but the thread length was a bit short.
Some 8-32 rivnuts were selected to match the dash hardware, and 10-32 hex nuts were drilled to accept these (press fit). The rivnuts were trimmed to length, pressed in the hex nuts, and fusion welded using the TIG around the joint.
The plate is .09 thick 6061, and press nuts were used on the back side for bolting the Hyfire to the plate.
Installed....
Robert
Old 01-13-2025, 09:14 AM   #1398
MP&C
MP&C's Avatar
Shop truck update, I had some exhaust parts left under the tree. A 2-1/2" mandrel bend kit and a pair of Black Widow Venom 250's.
[IMG] https://hosting.photobucket.com/b776...490b51e846.jpg [/IMG]
We had a spot going through a crossmember that was a bit snug, so we made a set of dies to flatten the pipe, as well as a plug for the end of the pipe to keep it round for welding to the next piece. Some quick geometry gave us the size and offset needed. Yeah, one of those classes from high school they say you'll never use again.
https://youtube.com/shorts/3m3mNGYTF...iG10O1OFryXYib
Plenty of clearance...
My favorite exhaust... heard and not seen.
test fire (inside the paint booth)
https://youtube.com/shorts/cUAwM1RGm...sK9UDwr_1oLtP_
And a couple drive bys..
https://youtu.be/bx0tNjLgP1Y?si=pjk84lpaog_lAHuF
https://youtu.be/urcF2-tLet8?si=6H8sXZ0B6VvOuOmD
I also "ran across" an engine suitable for rebuild to eventually replace the original 352 one day.
Yup, a 410 Mercury.
Robert
Old 01-13-2025, 11:34 AM   #1399
joesscamaro
The epitome of, "Do it right and do it once".
Old 01-13-2025, 01:35 PM   #1400
MP&C
MP&C's Avatar
Thanks Joe!
Robert
