Old 11-11-2021, 07:53 PM   #1376
Barnfind46
Barnfind46's Avatar
Re: What did you do to your truck today part IV
A few more.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 11-21-2021, 10:09 PM   #1377
Canadian63GMC
Canadian63GMC's Avatar
Stripped the paint off the passenger door this summer, just getting around to reskinning inner and outter skins and treating inner cavity with sealer…Name:  ACE50E3C-3774-4BB2-8B75-C354ABC1A610.jpg
Canadian63GMC is offline   Reply With Quote
Old 11-22-2021, 06:03 AM   #1378
The Rocknrod
Moderator
The Rocknrod's Avatar
Nice.
Old 12-04-2021, 09:47 PM   #1379
blacknwhitedog
Finishing up my 4 link conversion.
blacknwhitedog is offline   Reply With Quote
Old 12-05-2021, 12:25 AM   #1380
Chevy Fleetside
Chevy Fleetside's Avatar
We had a Christmas cruise so I decked out the truck
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-05-2021, 01:18 PM   #1381
pdxhall
pdxhall's Avatar
Originally Posted by 66x3 View Post
Pdx what is your plan for color?
I am going with seamist jade with a white roof. The paint is a 2 year only color for 62-63. Very rare but I really like it.
I've been working for a week on aligning all of the panels on Sanity. I want to make sure it all lines up reasonably well after all the body work done.
I set out the bed wood and strips to get ready for installing to measure and mark the bolt holes that need to be drilled.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 12-05-2021, 08:50 PM   #1382
MT65
Finally finished my driver side exhaust over the rear end, under the panhard out to the tip, with the weight restrictions and short shop time after hip surgery, everything takes forever……
MT65 is offline   Reply With Quote
Old 12-05-2021, 09:16 PM   #1383
Canadian63GMC
Nice! Is that all tig welded?
Old 12-05-2021, 09:50 PM   #1384
MT65
Yes, tig weld. On finishing, mig tacked during mock up…for myself it’s easier to give it a quick tack. I make all my exhaust systems to be able to be taken completely off without cutting anything, the vband clamps allow that.
Old 12-05-2021, 09:52 PM   #1385
Canadian63GMC
Very nicely done.
Old 12-06-2021, 12:52 AM   #1386
MT65
Thank you, appreciate your kind words….
Old 12-11-2021, 10:16 PM   #1387
MT65
Finally finished both sides on my exhaust….
Old 12-11-2021, 10:47 PM   #1388
AcampoDave
AcampoDave's Avatar
^^^awesome^^^ I wouldn't mind seeing a little more of that.
AcampoDave is offline   Reply With Quote
Old 12-11-2021, 11:11 PM   #1389
Canadian63GMC
👍 agreed
Old 12-11-2021, 11:30 PM   #1390
MT65
Thank you, its tedious and time consuming, but I like to build my own, lots of these pieces were left over from my last 2 cars…
Old 12-17-2021, 02:10 PM   #1391
66C10LB
MT65 meticulous job on your exhaust! Looks great. Don't think that I have seen one tucked so close in behind the tire before.
66C10LB is offline   Reply With Quote
Old 12-17-2021, 02:22 PM   #1392
66C10LB
Old 12-17-2021, 04:39 PM   #1393
MT65
Thank you for the nice words, its got just under an inch on clearance, takes more speed than this truck will do to make the tire grow that much, at least I hope so🤔🤔🤔
Old 12-19-2021, 07:55 PM   #1394
racecougar
racecougar's Avatar
Had to run to Home Depot for a fitting last night. When I came back out to the truck, the sunset looked great, so I snapped a few pics with my iPhone. Wish I would've had a real camera and been in a better location than HD's parking lot, but for a total impromptu shoot, I think these turned out well.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-19-2021, 09:06 PM   #1395
MT65
Finished mounting my rear sway bar, a front bar from an early 70’s Camaro should be fine, may have to fine tune end links when its on its wheels…
Old 12-19-2021, 09:24 PM   #1396
MT65
Old 12-21-2021, 10:02 AM   #1397
MT65
Finally resting on its own , maybe a little fine tuning on stance, 5” ground clearance as it sits…
Old 12-22-2021, 07:04 PM   #1398
The Rocknrod
Moderator
Started working on stuff and ended up pulling the engine. I over did it as usual.
Old 12-25-2021, 02:56 PM   #1399
Chevy Fleetside
Started painting my new spindles to replace the one that broke.
Old 02-10-2022, 12:27 AM   #1400
62bagger
62bagger's Avatar
I finished replacing the bed wood and raptor lined the inside of the bed. I got it finished and mounted back on the frame.
62bagger is offline   Reply With Quote
