Old 03-07-2013, 11:51 PM   #1426
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by ryanroo View Post
They are called zero rate add-a-leaf. they can recenter the axle or not. they are called add a leaves because they become a part of the springpack when you bolt them on with the center pin but do nothing to change the springrate like a normal add-a-leaf. the 2 hole three hole is the choices for moving the axle forward or back
Ryan
Ok. Hence the countersunk holes. His just have multiple positions, right?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-07-2013, 11:56 PM   #1427
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It allows you to move the axle 1" or 1.5". That's why there are 3 holes. You'll end up using 2 holes when you're done. I'm not too keen on the grade 5 bolts they want to use as the new center pin.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-08-2013, 01:34 AM   #1428
jbclassix
Junk Yartist
jbclassix's Avatar
Don't cheap out and use the low grade hardware. Check out this problem we ran into at work. Link-a-ma-jig
-Jeremy
Rebuilding an NP205
Old 03-08-2013, 01:46 AM   #1429
Mattman2010
Mattman2010's Avatar
Use grade 2, it will make things far more interesting when you put the foot to the floor!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 03-08-2013, 04:00 PM   #1430
mknittle
mknittle's Avatar
Yes I have. They are still trying to get the braking power side of it to work better. They sound cool, but I guess don't brake well yet.
Could be not enough manifold pressure. that was one of the problems the cat 3406 had. Swapping a holset turbo helped.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 03-08-2013, 04:17 PM   #1431
mknittle
mknittle's Avatar
Originally Posted by watahyahknow View Post
i think a retarder / magnetbrake would work better ,
i have seen motorbrake stuff but i think it works by smothering the intake air while cutting the injectors the vacuum makes the engine resist reving when running downhill in gear , prolly whont work with turbo's as they get hurt when you cut the air intoo them ... sucks the oil right trough the seals
thosr things are too heavy. all class 8 truck engines can be fitted hith engine brakes and do not work on vacuum thy work on compression and the more manifold pressure the better the braking.We are getting around 30 PSI on a Cummins big cam 2 on the jake.
Mark
My GMC build.
Old 03-08-2013, 05:34 PM   #1432
mknittle
mknittle's Avatar
Ryan, This is off topic but thought you might like to see this. it is still in the mock up stage on the grill shell. the engine needs to be moved back. and and and....
Mark
My GMC build.
Old 03-08-2013, 09:19 PM   #1433
Dieselwrencher
And and and, sell it to me! Nice progress on the ol girl!
Ryan
Old 03-08-2013, 09:27 PM   #1434
mknittle
mknittle's Avatar
yeah, he is moving right along! the problem is the farther he gets the more my 52 gets buryed
Mark
My GMC build.
Old 03-11-2013, 11:20 AM   #1435
truckdude239
truckdude239's Avatar
man i just took 4 hours to read this thing and your not done with it!!
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-11-2013, 03:10 PM   #1436
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I think its taken him more than 4 hours to get this far, so...
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-11-2013, 08:42 PM   #1437
Dieselwrencher
Well sorry man.
Uh, yeah, you're totally right. It'd get done if I quit improving on it every time I work on it.
Ryan
Old 03-11-2013, 08:56 PM   #1438
Mattman2010
I would use that word "improving" very loosely if I where you
Build Thread
Build Thread
Thread
Old 03-11-2013, 08:59 PM   #1439
Dieselwrencher
I got some time to work on it this weekend. I got the zero rates installed, and IDK if I'm exactly am happy with it. Before I started the wheel base was 132". After it's 133.5". So it definitely moved. I just don't think it's enough in the front yet. But I only moved it 1/2". I still have the 1 1/2" hole to try. I also stripped the other hole in my diff housing on the RH leaf spring retaining plate. So I'll have to heli-coil them. I had the inserts but no tap. I didn't realize the taps for a 1/2" heli-coil was an odd size. Go figure. I got the kit today though, so I'm good there. Any how, here's some progress pics.
I cleaned the bed out, removed the rear bumper, and slid the bed back. The bed was way too close to the cab for my taste.
Next I removed the bed so I can start on the GN hitch, frame boxing, and fuel tank swap. (Thanks for the idea Matty)
Almost had a casualty.............
No bed.
Tail pipe won't work when my hitch is finished. I'm planning on running straight pipe now.
Starting on the GN hitch. I'll have a B&W inbetween the 4x4 and 2x4 cross members.
Shoot, just this weekend and this morning, I bet I spent 10hrs working on this thing.
Ryan
Old 03-11-2013, 10:09 PM   #1440
jbclassix
Junk Yartist
jbclassix's Avatar
Exhaust pipe or Ia metro subway!
I agree, I think the axle needs to move forward still.
-Jeremy
Rebuilding an NP205
Old 03-11-2013, 10:10 PM   #1441
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Looking good buddy. Hope to see this one at goodguys this year.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 03-11-2013, 10:25 PM   #1442
ryanroo
ryanroo's Avatar
Looking good! you know i think you are spinning you wheels adjusting that rear axle placement. you know it wont matter when you step up to the plate and link/bag that bad dog...
that gooseneck plan looks good, wish ida thought of that
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-11-2013, 11:03 PM   #1443
Mattman2010
Ryan
Ryanroo was the one with the idea. I stole the idea from him for my gooseneck hitch. Hell if you read his thread he said he wished he would have spaced his so the b&w would set right on top
Build Thread
Build Thread
Thread
Old 03-12-2013, 04:04 PM   #1444
Dieselwrencher
I was talking about the burb tank sonny boy. I already had the B&W to do this with.
Ryan
Old 03-12-2013, 04:05 PM   #1445
Dieselwrencher
Ryan
Yeah, you know it. Bye Bye leaves......................
Ryan
Old 03-12-2013, 04:09 PM   #1446
mcbassin
Still Learning
mcbassin's Avatar
very nice progress Ryan.
mcbassin is offline   Reply With Quote
Old 03-12-2013, 04:58 PM   #1447
Mattman2010
Makes sense now....
Build Thread
Build Thread
Thread
Old 03-12-2013, 08:57 PM   #1448
ryanroo
ryanroo's Avatar
i'm thinkin so.
72 K20 12v build
Old 03-12-2013, 11:21 PM   #1449
ryanroo
ryanroo's Avatar
Mr. Wrencher has a pile of steel hiding in CO...
72 K20 12v build
Old 03-13-2013, 01:48 AM   #1450
jbclassix
Junk Yartist
jbclassix's Avatar
No backing out now!!
-Jeremy
Rebuilding an NP205
