Old 04-10-2015, 10:57 PM   #1426
Chrispbrown36
Re: Restoring Rusty
I am glad you did the troubleshooting on the reverse lights. I have to do it myself eventually. Thanks for blazing the trail man!
Chrispbrown36 is offline   Reply With Quote
Old 04-11-2015, 02:37 AM   #1427
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by greg64 View Post
The rear brake/turn signals pass through the turn signal switch on the steering column... Since the hazard works, it's clear that the bulb itself works and that the wire is intact...I think the problem is in the turn signal switch.
Yup I was afraid of that, and since I just replaced one old flasher and one new one with two matching brand new ones and that did not do the trick, I think I have no choice but to tear the steering column apart - AGAIN
Gregski is offline   Reply With Quote
Old 04-11-2015, 02:46 AM   #1428
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Turn Signal Switch
say, whacha got there Greg? A brand new shinny turn signal switch? Nice! How much did that set you back? $38 bucks from O'Reillys - not bad
Now if you only had that when you had the steering column all apart in order to replace that key lock cylinder?
Wait what did you say? You did have it back then? Well why on God's green earth did you not install it then you Pollack?
Old 04-11-2015, 02:50 AM   #1429
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Oh, I see.. you did try to install it but the darn thing would not plug in to the existing harness and you didn't want to fandango the new connector to "make it work" ok I get it, cause if it still didn't plug in or work you couldn't return it any more
so as my buddy says, what did you expect from an underwear company, LOL
Old 04-11-2015, 02:53 AM   #1430
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
You're welcome Chris, hope you find it useful, I was a bit lazy on documenting the entire process this time, wasn't sexy enuff, LOL
Old 04-11-2015, 09:57 AM   #1431
greg64
greg64's Avatar
Re: Restoring Rusty
Greg, that's funny that you already had the switch! I think there are adapters to convert to the different style connectors. I saw them when I bought my new switch from RockAuto.
If you can get the connectors figured out you could test the new switch without pulling the steering column apart again, just to be sure this is really the problem.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-11-2015, 12:28 PM   #1432
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Titomars View Post
A small warning about painting the booster. In no time the paint will be off it in areas due to the normal brake fluid seepage. That is why they were never painted. You might try something epoxy based.
Well Goooood Morning to me Rusty!
Why you dirty rabbit!
Old 04-11-2015, 12:32 PM   #1433
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Would you care to explain yourself Greg?
Why sure your honor.
You see all was well until The Greg realized he forgot to put the Booster Push Rod back in when he did the brakes a few weeks ago. So the other day he quickly removed the master cylinder and while nobody was a lookin' he put the rod back in. Problem solved he thought.
Well that was just the opportunity for the brake fluid to seep out, like a thief in the night under the cover of darkness.... hee hee
Old 04-11-2015, 12:34 PM   #1434
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
all together now
" IT AINT EASY !!! "
Old 04-11-2015, 01:02 PM   #1435
cnorth
cnorth's Avatar
Re: Restoring Rusty
I think it is just your meticulous approach to the revival of rusty that you put yourself through this keep up the outstanding work
cnorth is offline   Reply With Quote
Old 04-11-2015, 07:37 PM   #1436
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Turn Signal Switch Hell
Saturday
...so the day began with a tour of all the auto parts stores in town
As you recall I bought a turn signal switch at OReillys that would not plug in to my original harness, so...
NAPA - had the same one as OReillys
AutoZone - had the same one as NAPA and OReillys
Tognottis - were out of stock but could order the same one
PepBoys - were out of stock but could order the same one
so it was time to take matters into my own hands, now you haven't wrenched until you modified a part or better yet modified a tool or made your own
now does this make me a Master Mechanic (I didn't say that) LOL but I did make my own tool, for the record that is
Old 04-11-2015, 07:40 PM   #1437
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
for those of you who think I am nuts, here are the two plugs compared, trust me they be different
TOP - old original one
BOTTOM - new and disproved one (hee, hee)
(someone mentioned get an adapter, well the only place that had some sort of adapter it was for the 67-72 trucks plus it cost $50 bucks plus shipping and had to be ordered)
Old 04-11-2015, 07:43 PM   #1438
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
having swapped the connector, it was time to test the new switch before pulling out the old one completely and feeding the new one through, no sense if that aint be the cure
Old 04-11-2015, 07:45 PM   #1439
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok, that fixed the left rear turn signal, ie Yellow wire
pic of my least favorite step in tearing apart the steering column, getting that stupid ring clip out with a flat screw driver, I swear even the manual says just use a flat screw driver, geez lame design
Old 04-11-2015, 07:48 PM   #1440
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok some parting shots of the turn signal switches before one goes in and the other goes in the trash
I tried to see what possibly could be broken with the old one, but gave up, having bought a replacement already, and going to file this under cheap insurance
it did have a crack where the turn signal lever screws in, left side of the pic above the round hole
Old 04-11-2015, 11:32 PM   #1441
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
guys would you know what's the difference between Electric Parts Cleaner and Electronic Cleaner?
I bought both hoping my old turn signal switch just needed a good cleanin'
same company makes both, so they aint just competitors
Old 04-11-2015, 11:32 PM   #1442
greg64
greg64's Avatar
Re: Restoring Rusty
That's great that it worked!
Greg
Old 04-11-2015, 11:35 PM   #1443
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
~ i gots to tell you I am a bit electroniced out, tired of wires and switches, give me some nuts and bolts and old fashion grease anyday ~
Old 04-11-2015, 11:44 PM   #1444
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Power Steering Pump
and so we move on to the Power Steering Pump, I hear a noise when I turn the steering wheel to the left and when I turn it to the right, sounds like somebodys' stomach's growling, plus it is filthy and I can't tell if it's leaking or it leaked back when some dude named Noah borrowed the truck to build a boat or something like that
Old 04-11-2015, 11:47 PM   #1445
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so out it comes, lets take a closer look at that beauty
Old 04-11-2015, 11:51 PM   #1446
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and this is the burrow she left behind, I see some paper towels and Mineral Spirits in my future
Old 04-11-2015, 11:55 PM   #1447
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and so it begins...
Old 04-11-2015, 11:58 PM   #1448
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
removed the pulley... I ordered a new pump and I'm sure it aint gonna come with a pulley, also since I don't know how much free play there should be in the shaft as it moves a tiny bit to and fro in the bearing I am cleaning this pump in case I can salvage it, the shaft actually rotates pretty smoothly I expected to hear some square bearing noise or at least rubbing
Old 04-12-2015, 12:00 AM   #1449
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and a couple hours later
looks like I will be getting two new hoses, the high pressure hose and the low pressure one, both have cracks
looks like all I may be keeping is the brackets and the pulley, and after all that cleaning, nice going Greg
Old 04-12-2015, 12:03 AM   #1450
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ah what the heck lets get some glamour shots of that ol' pump, why not
