#1 | |
Old member
Re: What did you do to your truck today.The 3rd chapter
Did you have to redo any of the handle area. I have a 67 stock wheel I cut down but haven't finished it yet. I'm not sure what to use on doing the handle area that is gone.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Did a reset on the EFI unit which means I now have to go through Initial tuning procedures and then let it relearn from zero...hoping to solve some idle issues and get overall better results. This should have been done post top end rebuild anyhow!
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Aug 2020
I have used POR15 before. 1 pound in the smallest package it is available in, $33-$35 bucks. It's nice for larger areas like that, easy to work and a longer working time.
JB Weld steel stick is good for crack filling. It is a grey color which is nice for darker wheels and such. The only down side is it starts curing up quick. Says 5 minutes... As long as you cut off a small chunk at a time and work one crack at a time you're good. Have to try not to over do it tho because obviously it will take a lot of extra sanding to shape and smooth out |
![]() Join Date: Aug 2019
I bought a 7042210 carb today off of Market place.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I'm gonna swap out my ho52 with a Dana 60. I buttoned up the 60 and geting.ready to do the swap.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
You going to change out the adjuster lever? It's not hitting the adjuster wheel in this pic.
I test fit Blue in th shop too. I think I need to move the beer wagon though....lol
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul Last edited by Ol Blue K20; 01-01-2021 at 09:34 PM. Reason: add |
Post Whore
![]() ![]() Join Date: Sep 2008
Nice work Dale.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#11 | |
66clow, can you start a thread and show how you ran your A/C lines. I haven't done mine yet and am always looking for a better way.
#13 |
Yeah, I noticed they sold me the 11 inch lever. I swapped it for the right one. Good eye though.....
#14 |
#15 |
Thanks! I had to go to the parts store several times when I last did the rear brakes on my truck. One of the adjusters were "boxed wrong", as we call it in the parts bidniz. It took three tries to get the right one! It used to be that I told the parts store guys what I had, and got the correct parts. Things have certainly changed. I patronize the local NAPA, and those guys have owned that store for decades. They know their stuff, for sure. Some of the help, not so much. They know that when I come in looking for something old that isn't in their system, they can turn me loose on the paper catalogues to find what I'm after.
#16 |
![]() ![]() Join Date: Mar 2016
I took some pictures as the new owners came to take the '71 away today.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE ![]() Last edited by 3757chevy; 01-01-2021 at 10:39 PM. |
#17 |
This summer will be sooo much more enjoyable here in Florida. Got the AC installed.
#18 |
![]() Join Date: Oct 2013
Replaced front and rear bumper brackets.
Installed front and rear bumper. |
#19 |
Mr. Cheyenne
![]() Join Date: Jun 2020
since getting my truck back from my brother its not what have I done to my truck today but what I have done everyday LOL!
In the last week I have: Got my Side Mounted Rally spear tire installed - took a 8 inch bolt from ebay! removed my radio and ordered a new Classic Sound radio/speakers from http://garytayman.com/ Bought a white radio delete plate here on the forums and installed yesterday (thought I was going to be without a radio longer, so that will be for sale soon) re-did the dash with properly painted lens and replaced the tin from 70shortfleet Replaced hard as rock/splitting vacuum lines for ducts (starting from reservoir to dash). Found out I have a original GM key but the keychain had worn a hole so big the middle values where gone (LocDoc sold me a glovebox lock and is making me two new keys that match my truck). The fun does not stop there, parts on the way for days to come! Like rubber stops for the glovebox. Screws / j-nuts for the headlight bezel and other screws/spings for the headlight cans.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#20 |
No pictures sorry, but changed the carrier bearing while the driveshaft is out of the truck.
Changed rear diff fluid. Had exhaust manifold crack brazed, media blasted and painted it. Removed battery box, media blasted the rust off, primed it and started first coat of paint. Removed all core and oil galley plugs. Blew out all passages with air and ran brushes through all holes. Chased all threads Cleaned all lifters and cleaning pistons and pushrods Started the hone cylinder #2. It has a couple of pretty good scratches in it and will determine if I have to got to .30 over (I will hone it with my 3 stone hone until scratches are out and the remeasure to see if bore is in spec). I really think I should just send block to machine shop and go .30 over. |
#21 |
Mr. Cheyenne
The fun does not stop there, more parts on the way for days to come! Like rubber stops for the glovebox and hood sponges. Screws / j-nuts for the headlight bezel and other screws/springs for the headlight cans that seem tired and loose. I even got a Glovebox light kit that is coming my way! I am sure I even have forgotten things I have ordered - its going to be like Christmas when packages arrive! LOL
#22 |
![]() ![]() Join Date: Jan 2005
I finally got to start working on converting to front discs last night. I ordered a kit several months ago, and the supplier had to shut down due to COVID. I ended up canceling my order with them, and got a Western Chassis kit from Performance Online instead. They were able to ship within three days of placing the order. The kit arrived the day before we left town for a week, so all I had time to do was paint the drop spindles and calipers. We're finally back home, so last night I tore everything apart. I will be drilling out the upper ball joint rivets and pressure washing the control arms tonight.
#23 |
Wow Rich, so much fun you did it twice. LOL
#24 |
Mr. Cheyenne
That was not fun at all - though I am getting faster at it! So much so, I'll likely be doing the dash cluster *for a 3rd time* because I am getting dash light bleed-through into my left turn signal! I am thinking perhaps during the radio install, instead of pulling the cardboard glovebox out again I'll go from the dash cluster side. That thing is not so easy to get out (I have A/C) and it is already getting slightly damage in the upper left corner.
I just have to figure out how to seal the cardboard indicator tubes to the tin. The little seals that go under them are hard as a rock and I cannot find where to buy replacements.
#25 |
Mr. Cheyenne
Daughter wanted to have a drive, so i took some photos. So that is what I did today, took some pictures LOL
| Bookmarks |
