Old 03-01-2013, 09:02 PM   #1451
hotrod1
56 - autocross
hotrod1's Avatar
Re: Kabwe's aka Bam's build
Slick!
hotrod1 is offline   Reply With Quote
Old 03-01-2013, 11:45 PM   #1452
Kim57
Kim57's Avatar
Nice fix.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-02-2013, 12:54 AM   #1453
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by hotrod1 View Post
Slick!
Originally Posted by Kim57 View Post
Nice fix.
Kim
You think? Well I hope so.
Thanks guys.
Kabwe is offline   Reply With Quote
Old 03-02-2013, 12:56 AM   #1454
oldman3
oldman3's Avatar
Nice job...Jim
oldman3 is offline   Reply With Quote
Old 03-02-2013, 08:05 AM   #1455
FarmerSid
FarmerSid's Avatar
I think you did the right thing by welding them to the frame. Keep up the nice work my little grasshopper!
FarmerSid is offline   Reply With Quote
Old 03-02-2013, 11:45 AM   #1456
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by oldman3 View Post
Nice job...Jim
Looks like someones been watching episodes of Kung fu. Little grasshopper.lol
Old 03-13-2013, 01:59 PM   #1457
mknittle
mknittle's Avatar
Hey Bam,
What did you do for a nut at the lower end of the spacer? I am going to have to do somthing like that on mine. By the way your truck is really looking good!!!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 03-13-2013, 08:24 PM   #1458
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by mknittle View Post
Hey Bam,
I did decide to weld the spacers to the frame and I used a bolt to line up the spacer holes with the holes on the frame.
I thought long and hard over the lower end nut and as I saw it I only had two two choices.
1. I could use weld-in nuts on the top, or bottom of the spacer or on the top of the frame before I welded the spacer to the frame.
2. I could buy bolts long enough to go through the spacers and the frame.
I chose option 2. I still have the option of a weld-in bolt on top of the spacer if I were to change my mind.
Old 03-20-2013, 06:19 PM   #1459
Baldeagle SR
Bam do you know who makes a rear spring shakel kit for a 56 GMC? I need to move my springs in closer to the frame. Thanks Rich
Baldeagle SR is offline   Reply With Quote
Old 03-20-2013, 07:13 PM   #1460
Kabwe
Certified Car Nut
Kabwe's Avatar
Every kit I've seen sells the shackles with the springs and I don't think they move the springs that much closer to the frame if at all.
I know BCToyBox relocated his springs inside the frame rails for more room. His truck is prostreet. He used the original shackles and just reversed them, putting the driver side on the passenger. I don't know if he has pics in his build page link but here it is http://67-72chevytrucks.com/vboard/s...d.php?t=432758.
I found the pic on his flickr page. He is a cool guy if you are interested just ask him. This pic is before the c-notch.
Old 03-20-2013, 10:37 PM   #1461
Baldeagle SR
Thanks Bam I thought about swaping the hangers . we used to do that on the 55 cars. Rich
Old 03-21-2013, 01:47 PM   #1462
_Ogre
_Ogre's Avatar
an option to thru bolting the frame... when i boxed my frame i left widows to slide the nut in to bolt the bed rails down. i didn't like the look and figured dirt and water would get in there. i welded 2x2 angle iron clips on the outside of my frame to fasten the bed rail too. if you needed to raise the bed 2'' you could use 2x4 angle and weld them in 2 up from the frame. you can see one of the angle clips in this pic
shop air compressor timer
Old 04-21-2013, 11:24 PM   #1463
Baldeagle SR
Bam I hate to be a pest another question. I have a 10 bolt chevy diff 308 possi from a 79 Camaro. I need to narrow the housing , Summit has the ends or do I need the c clip eliminator ends? I don't plan on raceing . just a nice crusser. Can I get any length axels from Moser? with or without c clips. I emalied them but didn't get an answer. Thanks Rich
Old 04-22-2013, 09:45 AM   #1464
Kabwe
Certified Car Nut
Kabwe's Avatar
You do not need c clip eliminators. If you are going with Ford housing ends you will use a the retainer just like the ford rearends. Yes you can get any length axles you need from Mosers. My axles and housing ends are both Moser. I had bought a disk brake kit before I narrowed my rearend so I have to modify my retainers you act as the disc brake bracket also.
The retainer is on the left side.
This is the bracket/retainer I came up with.
Old 04-22-2013, 09:58 AM   #1465
Baldeagle SR
Thanks a bunch . That is what I needed to know. Rich
Old 04-22-2013, 08:22 PM   #1466
oldman3
oldman3's Avatar
Bam, very clever with the combo....Jim
Old 05-10-2013, 08:34 PM   #1467
Rude Dude
Rude Dude's Avatar
Bam I think you need to change the third brake light to one of these, just joking. I saw this in Sport Truck site it was on a tailgate when I saw this light first thing to come to my mind was your truck.
Rude Dude is offline   Reply With Quote
Old 05-10-2013, 09:34 PM   #1468
fabguy
Elev8r Man
fabguy's Avatar
That is a sweet lookin light.
where do they sell those.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 05-10-2013, 11:39 PM   #1469
Kabwe
Certified Car Nut
Kabwe's Avatar
Rudedude I may put one on my 55 car but not on my truck I do like the light my buddy has one on his car.
Fabguy you should be able to get one from most trifive venders such as Danchucks or maybe even the car and truck shop.
Old 05-11-2013, 07:16 PM   #1470
VDOG
Grand PooBaa Member
VDOG's Avatar
Oh great, another nice, clean, beautiful 55 Chevy.
VDOG is offline   Reply With Quote
Old 05-11-2013, 08:45 PM   #1471
Kabwe
Certified Car Nut
Kabwe's Avatar
Yeah but he sold it. I still see the car around town, but its still Donny's car the guy left it exactly the same. I also met the guy who purchased it he seems like a nice guy and very happy with his purchase.
Old 05-13-2013, 04:39 PM   #1472
VDOG
Grand PooBaa Member
VDOG's Avatar
All joking aside, that is one clean 55.
Old 05-14-2013, 12:26 AM   #1473
Dan in Pasadena
Dan in Pasadena's Avatar
Two door hardtop Belair too - ugh, kills me. My Dad gave me his purchased-new one when I turned 16 - I didn't want it. I wanted a van (it was the 70's). What an idiot I was. Someday I WILL have another though. Hopefully to go with my truck.
Dan in Pasadena is offline   Reply With Quote
Old 05-14-2013, 12:31 AM   #1474
Kabwe
Certified Car Nut
Kabwe's Avatar
Dan you do not want to know the cars I've had and the ones that have gotten away. I will tell you one that I regret selling a 1966 GTO. I have many cars get away throughout the years my brothers were lowriders and anything they did not want to lowride they gave to me.lol My 55 210 is not for sell ever unless the bottom falls out financially and truck whenever its done will not be for sell either. If I get bored I will just rebuild them.
Old 05-14-2013, 12:38 AM   #1475
Dan in Pasadena
.... selling a 1966 GTO.
Now THAT would be PAIN.
My Dad's was black with the red/orange over a rich cream interior. A 235 six and 3 speed overdrive because he didn't think the new V8 would be very good - ha ha.
If I could ever find THAT specific car I'd do whatever was necessary to buy it. I know the old license number too. I submitted a form to the DMV about 5 years ago but they couldn't find it. Might have been junked or just lost a cross reference.
