Closed Thread
Old 12-12-2014, 06:34 PM   #1451
barmanvarn
barmanvarn's Avatar
Re: What did you do to your truck today? Chapter II
I'm not doing the "cool" stuff yet but today at least I managed to replace the old truck cover with a new one from LMC.
Man, that think fits like a glove. Am very pleased with it.
sorry, no pics.
Brian
'69 GMC C15
Inline 6, 230ci (possibly 250ci)
barmanvarn is offline
Old 12-13-2014, 10:18 PM   #1452
texjake
texjake's Avatar
I got rid of the old Quadrajunk & installed a new Holley Street Avenger 670cfm carburetor today. It sure runs better too. I changed out the jets from 65 primaries & 68 secondaries to 68 primaries & 72 secondaries. I did this hearing that those Street Avenger carbs run on the lean side with the factory jets.
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 12-13-2014, 11:07 PM   #1453
Possmguts
Possmguts's Avatar
sanded a bit more on the cab is all... this part sucks
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 12-13-2014, 11:19 PM   #1454
Elliot949
Elliot949's Avatar
I walked out to the garage and set on a chair and looked at it...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline
Old 12-14-2014, 08:39 PM   #1455
dirtyjim
dirtyjim's Avatar
installed drop spindles and discs on the 67
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline
Old 12-14-2014, 08:51 PM   #1456
Possmguts
Possmguts's Avatar
2.5" drop? I would love to see what the stance is with wheels and tires.
Old 12-14-2014, 08:52 PM   #1457
Possmguts
Possmguts's Avatar
.... more sanding....
Old 12-14-2014, 09:31 PM   #1458
slowcpe
slowcpe's Avatar
Got my PB crossmembers in and mocked up my Boyd tank.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline
Old 12-14-2014, 10:52 PM   #1459
hamjet
hamjet's Avatar
Nothing to the truck, but I did get it a new lease on life. will be rebuilding it in the spring. 348 W engine
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 12-15-2014, 12:09 AM   #1460
dirtyjim
dirtyjim's Avatar
it has front coils from a late 80's suburban with a little over one coil cut.
front tires are 275/45r20, back still needs to come down 2" but I can live with a little rake for now.
dirtyjim is offline
Old 12-15-2014, 09:42 AM   #1461
73737373
Buffed and waxed all the painted cab interior surfaces on my 70 GMC. Looks great...amazing the amount of grime that builds up over 44 years.
Bolted rear frame coil spring supports and cup mount plates back on and installed rear springs. Now I can get the bed back on...next weekend.
73737373 is offline
Old 12-17-2014, 03:11 PM   #1462
Lou Boffa
Lou Boffa's Avatar
Love this board. Yes, a cracked fly wheel sounds a lot like a rod knocking. Replacing fly wheel-found carrier bearing loose--working on that. Who knows what else I'll find before the day is over.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 12-17-2014, 07:25 PM   #1463
TheSeeker
Pulled my hair out in frustration with my holley for the final time today. Im sorry, they must make a good product to have such a strong following but MINE is a P.O.S. sick of trying to get it to keep tuned. Ordered a Edelbrock 1404, I hear its the way to go for brain dead people like me. Anyone want a Holley??!?! (im not offering to sell it admins plz don't delete)
TheSeeker is offline
Old 12-17-2014, 08:18 PM   #1464
R.L.
R.L.'s Avatar
Adjusted my rear brakes, primer my drums getting ready to paint and reinstall tomorrow. Tightened my exhaust at the manifold. Went junk yarding yesterday found a window washer reservoir installed that. Got my doors adjusted, again.
R.L. is offline
Old 12-17-2014, 08:58 PM   #1465
vidman
vidman's Avatar
Set the cab on the frame for the 2td time.It was around 50 today, so spent some time on in the garage.. had to check some tranny clearances because i found out that my low hump did not work for me..[ replaced it with a high hump] I also wanted to check to see if i had room for my 9" booster and it looks like it will be OK, will have to tweek my pass side header heat sheild and add the driver side sometime this weekend but things are looking good. some of the pics dont show it but the clearance is about 5/8 of an inch on the drivers side and a strong 3/4 of an inch on the pass side from the valve covers to the firewall..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 12-17-2014, 10:28 PM   #1466
Lees68GMC
Lees68GMC's Avatar
Really beautiful Big Block truck. Brodix, WOW! Like they used to say; "It will Pass everything but a gas station"
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline
Old 12-18-2014, 12:26 AM   #1467
colgad
colgad's Avatar
Finally got the carburetors TV cable bracket fitted on the Vortec intake and working correctly.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 12-18-2014, 12:49 AM   #1468
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Wow ;
It's been too long since I checked in ~
My truck is still in the paint jail but the frame's looking mighty fine now , IK went ahead and bought all new MOOG ball joints & tie rods ends , might as well .
I've also been out of state and sick as a dog and trying to get some traction on overhauling my '77 292 i6 engine .
I am needing to use the crank shaft out of my '64 292 block as the flex plate bolts are larger in the '77 crank and the new flex plate I bought , can't be used on it .
Anyway , if it doesn't rain to - morrow I'll run a box full of loose parts down to the shop and spend some time in the solvent tank , then go home and hopefully pull the '77 engine's cylinder head , pistons & rods m, crankshaft etc. , I want to send the rods out for rebuilding and measure the bore for the new pistons , blah blah blah , the usual boring overhaul stuff , I love it so much , I'm old & gray now but I never tire of overhauling .
REALLY nice trucks and works I'm seeing here ! .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 12-18-2014, 01:37 AM   #1469
MiterMaster
This is my first post and I want to say that I appreciate conversing and feeling accepted by other people who can understand why anyone would spend more time and money on a 40+ yr old truck than a late model with less miles and A/C.
Today I purchaded oil, a filter, KAT oil pan heater, and an exhaust gasket. Nothing exciting. But I can say, you know its more than a truck when you'll spend your free time in the winter changing your own oil, installing a heater to prevent cold starts while the heater in the cab has yet be be fixed. Its a mistress.
MiterMaster is offline
Old 12-18-2014, 07:47 AM   #1470
Elliot949
Elliot949's Avatar
Beautiful Truck...
Old 12-18-2014, 11:42 AM   #1471
OregonNed
OregonNed's Avatar
Beautiful truck!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 12-18-2014, 11:51 AM   #1472
OregonNed
OregonNed's Avatar
Got the truck out for some maintenance and installed Van style side markers.
Old 12-18-2014, 01:03 PM   #1473
kjdolphins
I love that color... Looking to do around the same color on my truck
Current project:
1972 Chevy c-10 350 (700r4 hopefully) - "Lola"
68 Oldsmobile Delta Custom 455
78 Z/28 Camaro - "Rocky"
89 Camaro RS 305 TBI DD - "Betsy"
kjdolphins is offline
Old 12-18-2014, 05:45 PM   #1474
nicks diner
nicks diner's Avatar
Finally installed bumpers
nicks diner is offline
Old 12-18-2014, 06:58 PM   #1475
Possmguts
Possmguts's Avatar
Since I was off work today I removed the doors and gutted the cab. Its sitting there unbolted and ready to lift off.
Closed Thread
