Old 04-12-2015, 12:35 AM   #1451
enaberif
Re: Restoring Rusty
Does the bracket that mounts to the water pump have the nut still attached to it? Mine didn't and it took me forever to figure out why it was such a pain in the ass to install lol. I had to weld a new nut on and fixed the issue.
enaberif is offline   Reply With Quote
Old 04-12-2015, 10:35 AM   #1452
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
When you refill the system, use synthetic P/S fluid. Much reduced steering effort and greater pump efficiency. I can palm the wheel lock to lock on my K10 while sitting still on clean dry pavement at 750 rpm idle.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 04-12-2015, 10:47 AM   #1453
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Why yes, yes it do, here are some pics of it from different angles
Gregski is offline   Reply With Quote
Old 04-12-2015, 02:28 PM   #1454
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
cleaned that side of the block a bit to get it ready for the new pump and the newly painted brackets
it is just the right amount of clean for a truck, you don't wanna over do it you know, jk
Old 04-12-2015, 02:30 PM   #1455
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Hey what do you know, there are two bolt holes down there anybody know what bolts up to those (in a different application of course, I know that) do Camaros have something there for example?
Old 04-12-2015, 03:04 PM   #1456
enaberif
Re: Restoring Rusty
Lower bolt holes are for car alternator mounts or power steering mounts. You can have high or low mounts. The same holes are on the other side.
I'm glad you cleaned up that hole I was wondering if it had a frost plug in it.
Old 04-12-2015, 06:12 PM   #1457
CodyWorks
Re: Restoring Rusty
Finally!!! It took me forever but I'm finally caught up on this thread, and on Gregski's truck. I'm hooked! Great progress brother.
Cody
CodyWorks is offline   Reply With Quote
Old 04-12-2015, 07:10 PM   #1458
greg64
greg64's Avatar
Re: Restoring Rusty
Now, I'm not saying you're wrong, but I had thought those bolt holes (and the ones on the other side) were for a front-engine horseshoe mount. Back in the days where the bellhousing had mounts on both sides. Also for medium duty trucks with a single front mount.
Anybody seen factory brackets that hang the alternator off these holes?
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-12-2015, 07:37 PM   #1459
enaberif
Re: Restoring Rusty
Yes that is another reason why they are like that as well.
Low mount alternator -> http://i.ebayimg.com/images/i/360668...-1/s-l1000.jpg
Low mount power steering -> http://67-72chevytrucks.com/vboard/a...1&d=1245449377
You won't normally see these used in trucks because of our frames and how they get in the way. But in cars and older trucks they could work because of more open space.
Old 04-12-2015, 08:53 PM   #1460
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
We will accept the lower power steering mount but the Russian judge objects to the lower alternator mount photo as it appears to be an after market fab. Now we are not saying the alternator can not hang from there, I think on the big blocks it might could though I think the power steering pump going there is more likely, se we will need a stock OEM photo in order to move you to the lightning round, LOL
Old 04-12-2015, 10:37 PM   #1461
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
for some reason I decided I was not going to paint the pulley in the valley of the belts, maybe cause it looked unpainted originally, maybe cause a part of me believed the paint would make the belt stick
so anyway, rolled up two paper towels and shoved them in the groove, and that kept the paint out nicely
Old 04-12-2015, 10:40 PM   #1462
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I must say the reason I bought a GM product was because I reconned the parts would be in abundance, I mean they made 1/2 a million of 'em and then they made a 1/2 a million more, LOL
yet here we are watchin' the paint dry while we wait on the power steerin' pump to arrive
Old 04-12-2015, 10:44 PM   #1463
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Power Steering Pump Hardware
man I hope I 'member where at least half this hardware goes, LOL
semi cleaned, (but not too much)
Old 04-12-2015, 11:02 PM   #1464
enaberif
Re: Restoring Rusty
The hardest part about re-installing the power steering pump is all the damn spacers. I'm not sure what happened with my truck but I had to use a lot of washers in different areas so that I could get my power steering pump to be squared and have a straight belt.
Old 04-13-2015, 08:29 PM   #1465
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Fun stuff!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-13-2015, 10:29 PM   #1466
T_Rip75
Re: Restoring Rusty
Great thread man. I just got a '75 Chevy K10 and you have given me some great ideas/tips.
T_Rip75 is offline   Reply With Quote
Old 04-14-2015, 08:38 AM   #1467
bnoon
Re: Restoring Rusty
The only thing better than the Greg's work is the Greg's commentary. Love this thread.
And I thought I told you about repinning the connector! I had to do the same thing to adapt the later column to my '74. GMC, and then again to adapt the later turn signal lever to Red Ryder as well. Very easy to do. I did manage to stab my thumb with the "professional" tool (sharp pick). Maybe I should have used a paper clip as well...
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 04-14-2015, 11:23 AM   #1468
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Thank you I appreciate the feedback, keeps me giong, when it seems like it's two steps forward and one step back, you know what I mean fellas
Old 04-14-2015, 11:24 AM   #1469
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Did you really? I'm sorry if I keep not listening to you like that we're gonna have to get married, (I kid, I kid)
Old 04-14-2015, 01:16 PM   #1470
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
A note to anyone who shoots me a friend request, I accept them all, or at least try to, I am using Chrome as my browser and for some reason I am unable to accept friends, take that as you will, LOL, I will try to fix this issue
Old 04-14-2015, 01:25 PM   #1471
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
wanna share a Lesson Learned about the Power Steering Pump, I don't know why but before I went on this journey I thought the steering pump was one magical unit a black box that made steering easier, the steering shaft was the input and some rods connected to the wheels acted as the output, and whalla you got power steering
Well, the power steering pump is only half of the equation is what I learned, the other half is the steering box in our case or a steering rack in the rack and pinion applications
Furthermore the steering pump is similar to the AC system as it also has a low pressure and high pressure hoses, sure now that makes sense, but before I took it all apart I didn't even conceptualize that, so
Steering Pump <=> Hoses <=> Steering Box
well you all probably knew that but I just wanted to share, maybe to get some of you thinking about it, if you hadn't already
Old 04-14-2015, 01:27 PM   #1472
enaberif
Re: Restoring Rusty
The high pressure and low pressure hose can be determined as the high pressure hose has the clamped fittings where the low pressure hose can use hose clamps.
The low pressure hose is more of a return line that feeds back into the reservoir. When you turn the wheel the high pressure hose is in use to allow the easy movement of the steering box to pitman arm to steering arm to tie rods.
When you release off the turn it uses the return line to feed fluid back to the reservoir.
Old 04-14-2015, 01:28 PM   #1473
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - You Hoser
picked up some parts last night and took today off to start turning some wrenches
so lets compare the old and new high pressure hoses
they look a bit different but I hope the new one will fit right
Old 04-14-2015, 01:31 PM   #1474
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
as you saw above you buy a pre manufactured (and I use that term loosely) high pressure hose, but you buy the low pressure hose, aka the return line by the foot, just make sure the AutoZoner hands you the right type of hose, I'm just sayin'
I bought a 2 foot long section to allow room for error
Old 04-14-2015, 01:35 PM   #1475
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so far so good... well till I picked up the Remanufactured (pronounced: remangled) power steering pump from O'Reilly's (pronounced: Oh really, as in oh really, you want me to put that on my truck)
I hate to sound so negative, but this thing is garbage, look at the return line 90* elbow fitting thing, compare my old one with a nice sweeping curve to the sharp and twisted and deformed new one
I believe if you have to write "Quality" on your box three times in different languages, well maybe your part ain't all that quality
