Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 12-31-2005, 03:24 AM   #126
67chevemall
67chevemall's Avatar
Re: Rear Fuel Tank swap
some pics
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline
Old 12-31-2005, 11:52 AM   #127
ed455
Captain Ed
Originally Posted by 67chevemall
$25! good score I'd say that is the way to go!
I tried a cell in the bed and now I have it under the bed.
Now I'm looking for fuel sensor ideas for plastic cells?
I got my fuel sensor from Speedway. If you're using the factory gauge I believe you need the 90 ohm model. GM uses 90 ohm sensors. The swing arm is very long and you need to cut it to the correct length for your fuel cell and you'll need to use a hole saw to mount it. If you have gas in your tank you might want to empty is for this as plastic shavings aren't really good for you fuel system (duh).
I have a similar cell mounted and I have a SW fuel gauge. Works well. You'll have to run a ground wire to the body or frame for it to work though.
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline
Old 01-11-2006, 12:10 PM   #128
leadfoot067
horsepower junkie
found this site in my searching.... www.tanksinc.com
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline
Old 01-11-2006, 06:27 PM   #129
Austin C10
1972 C10 Cheyenne LWB
Truck and Car shop in Orange CA have the Blazer galvanized steel tank kit for $192. It does require crossmember removal or cutting, additional lines to run to the cannister, filler tube, and filler installation. Obviously it requires placement of the filler.
Fuel Cell Guy quoted me $375. This tank seems to be pretty customized for my truck (e.g. no crossmember problems, mounts without fabricating stud on a blazer), I'm debating if its worth the additional cost. It also has the filler neck.
I'm probably not going to get too tricky with the filler location. Can anyone describe the best way to locate the filler through a door on the side bed panel? Also, do I need to remove the bed for a Blazer and FuelCellGuy installation? What kind of lines do I need to supply the cannister?
1972 LWB Cheyenne C10 350 TurboHydramatic
Austin C10 is offline
Old 01-12-2006, 01:34 AM   #130
72MARIO
72MARIO's Avatar
I would go with FUELCELLGUYS tank. Being it's a bolt in.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline
Old 01-31-2006, 11:16 AM   #131
hambone1958
hambone1958's Avatar
I got both a Fuelcellguy tank and the ECE tank both fit very well love them both. It all boils down to stainless VS aluminum. I ended up putting the ECE in Jumpin Jimmy will most likely use the fuelcellguys tank in the 67 unless i sell it first.
Alan
hambone1958 is offline
Old 01-31-2006, 09:39 PM   #132
rkarr
rkarr's Avatar
Early Classic's is awesome, especially if you're going to go with fuel injection...
I'ts got the sender and a bung and all the plumbing for the fuel pump, as well as a FILLER VENT I've read too many threads about the new tank being a bear to fill, be sure to vent the filler pipe!!!
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline
Old 02-12-2006, 02:34 PM   #133
project1971
project1971's Avatar
Well I'll join in here... I used a poly blazer tank I got from buddy who bought it and ended up using a fuel cell. I custom made the fuel filler since the truck was bought by my old man and spent ALOT of it's life on 29 Palms base I thought using an ammo can as the fuel fill was kinda cool. Once I redo the truck it will be repainted also and look cool.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline
Old 02-12-2006, 08:04 PM   #134
Brad
Out of the carpool lane.
Brad's Avatar
Is that a pipe fitting on there?!? I REALLY wouldn't use that if it's a screw fitting- one spark and BOOM!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline
Old 03-07-2006, 01:21 AM   #135
JadeEmperor
I didn't get to read through this entire thread and can't get the thread search to work so this may have been answered already. I'm trying to figure out what I need to do to the wiring from my float to my gauge for it to read properly. I've heard that different sending units use different resistance values and in order to get mine to gauge properly I have to put something inline to match up with what I'm using. I installed an 86 Blazer tank (31 gal.) between the rails, with an 86 Blazer unit and float. I'm using the stock 70 gauge. Thanks in advance for any help.
Jimmie
Modern Vintage Autoworks
- '70 Chevy C10
- '74 Chevy C30 3+3 Dually
- '04 Chevy Colorado
Built, NOT, Bought. If you build it...they will ENVY!
Drive Slow, Scrape Hard, or Take Your Truck and GO HOME!
JadeEmperor is offline
Old 04-01-2006, 09:43 PM   #136
stepside67
stepside67's Avatar
I am looking a FuelCellGuy tank for my 67 stepside. Does any have pictures of bed mounted filler neck? I recall seeing one setup where a single board was hinged and flipped up to reveal filler neck. Can't seem to find pictures of this anywhere...
Keith L.
stepside67 is offline
Old 04-02-2006, 11:56 AM   #137
Joe67
67 is sold
Keith L.
Project Copperhead has a bed floor board hinged to expose the filler. Others have used a nice billet type cap similar to the CoolCap offered by AirRide.
At Carlisle Trucks last summer, there was a nice 60s Vette fuel cap used
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline
Old 04-02-2006, 01:41 PM   #138
hoser
My 87 chevy C60 chassis bus has a factory screw on metal cap for its tank..
hoser is offline
Old 04-09-2006, 08:06 PM   #139
saxmo
saxmo's Avatar
Originally Posted by ed455
here's what I did for a gas tank. One thing I alway noted about the old trucks was that the cabs always smell like gasoline.
I agree. I had a 55 chevy truck with tank behind seat, lotsa fumes, not to mention the sloshing noise every time you take a corner or brake, or accelerate, or close the door, or turn up the radio, or reach for the ignition.. well I guess you get the idea.
2004 Corvette Coupe Black LS1 (daily driver)
1973 Ford Bronco (resto/mod @ 95%)
1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said)
1997 Ford F150 4.2L 500k+ miles (trash hauler)
2011 Nissan Juke (wife's daily driver)
1943 Ford GPW WWII jeep (waiting its' turn)
saxmo is offline
Old 04-10-2006, 07:20 AM   #140
Joe67
67 is sold
If you smelled gas in the cab, you had some problems with the tank.
Joe67 is offline
Old 05-02-2006, 08:33 PM   #141
Chris4x4Gill2
Have any of you used the kit from LMC? How does it compare to the others?
From what i have read on here I take it that the one from FuelCellGuy is the easiest to install?
Chris4x4Gill2 is offline
Old 05-03-2006, 07:02 AM   #142
Joe67
67 is sold
I'm not sure about easiest, but I had to only drill 2 or 4 holes in my frame to mount the FCG tank and bolt it up.
I did cut up some rubber gasket material to use between the tank flange and the frame to help with any possible squeaking
Joe67 is offline
Old 05-03-2006, 04:39 PM   #143
Chris4x4Gill2
Ok...newbie question
Is there a how to on the install of FCG's or any of the others? I looked i nthe FAQ's and through this thread but I still have questions.
Old 05-14-2006, 09:06 PM   #144
mongo 72
Anyone know how to get ahold of fuel cell guy? I am interested in one of his tanks but have a few questions that need answering and how to purchase one. Thanks
mongo 72 is offline
Old 05-14-2006, 09:50 PM   #145
TugOwar
FCG has been afk for a while as he gets set up in his new shop. He made several posts in general discussion last week so his PM box should be cleaned out now. Try sending him a PM and see what happens. I think he is still somewhat in the process of moving so give him a few days to reply.
TugOwar is offline
Old 05-17-2006, 06:58 PM   #146
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
I did a job almost exactly like yank's.
I'd been thinking about it for ages, got the idea from the old bel-airs. never got around to it, or had thought money would be better spent until I saw this:
Yes, that's gasoline! and right over the exaust too! I drove it every day, never did smell gas, but noticed that one day when changing my oil.
Time to do the tank swap...
I ordered a blazer tank from brother's truck, mounted it and started on the filler.
I didn't have to cut the corner support that much, but welding the fuel filler, and getting it in there was pretty tricky....
here's what I cut,
as you can see, my truck needs paint, oh, and a bed!
I just welded a hinge to the metal light houseing, and riveted the other end to the body. not the prettiest, but it works. Basically I riveted it for mock up, I will weld it in place and smooth out the rivets(one day).
even with the bumper on, the light swings down almost 90 degrees, plenty of space to get a filler in.
I used it for about 3 months with out a vent hose, and man, what a PITA to fill, took forever, and splashed out regularly. I figured that's not the best thing around my lights(electricity!) so I added a vent hose to one of the vents on the tank. I routed it up and around the wheel well, into the top of the bedrail(not in a stake hole), and put one of those auto purge vents designed for boats on the end. (it's hidden under the bedliner...)
With the vent hose installed, works like a charm.
I've still yet to fill the tank hole on the cab though!
|M|
Mordachai is offline
Old 05-17-2006, 10:57 PM   #147
yank
yank's Avatar
Mordachai, looks good. Placing the hinge on the bottom of the tail light housing gives you a lot more room for the filler neck than I had to work with. If I ever do another one I think I,ll look at putting the hinge at the bottom or maybe even the top of the housing.
Here is a pic of mine
70 C/10 SWB
Go ahead chance it........Columbus did!!!
Steve (Chitlin) Bacon
My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/
yank is offline
Old 05-18-2006, 10:22 AM   #148
Joe67
67 is sold
I've always wondered about spill over and wiring on those setups.
How easy is it to access the fuel cap in there?
Joe67 is offline
Old 05-19-2006, 10:24 PM   #149
Mordachai
Mordachai's Avatar
really been no problem for me, but the wires are wrapped in multpile layers of high-temp, oil resistant tape, that stretchy bubble tape stuff, and the outside is wrapped with the abrasion resistant tape.
I've spilled a few drops since I put the vent in, but not like when it was unvented and splashed out everywhere.
|M|
Oh, I meant to mention, that there are a few companys that sell LED lights to go in your lens. It actually replaces the metal housing that the lens screws into, and is really thin, roughly 1/2" thick. I am really hesitant to put them in the truck, but the red LED with a red lens(with blue dot of course) might not look too bad. you might not even be able to tell it's LEDs behind a red lens(instead of clear - ewwww)
|M|
Last edited by Mordachai; 05-21-2006 at 02:03 PM. Reason: Thought about light clearance & LED conversion :)
