Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 03-01-2008, 12:01 AM   #126
earl87gta
earl87gta's Avatar
Re: Welders!
Northern tool has there welders on sale now. Here is the one I have I haveent used it yet but for the price and it comes gas ready http://www.northerntool.com/webapp/w...2925_200342925
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 03-12-2008, 10:58 AM   #127
68c10owner
68c10owner's Avatar
Re: Welders!
how is this welder? I found a used one local for cheap. will it do body panels ok?
http://www.daytonamig.com/Pturbo130.htm
Anthony
68c10owner is offline   Reply With Quote
Old 03-12-2008, 11:06 AM   #128
DURRTY
USMC
DURRTY's Avatar
Re: Welders!
probaly will depends how cheap you found it for. I would go for a miller esab or lincoln at that price though similar models go for about the same or less brand new and have a 3 year warranty on the whole thing not just transformer
. for a couple hundred bucks though it ought to be good to go
Semper Fi
DURRTY is offline   Reply With Quote
Old 03-25-2008, 05:14 AM   #129
Woobie
Woobie's Avatar
Thumbs up Re: Welders!
Well, finally broke down after looking on flea Bay, bargain trader, local paper, and local pawn shops and bought a new Lincoln 3200HD. Will look over the instructions tomorrow, set her up and start practicing. Been a number of years since I've done any welding so I'll need to shake off the cobwebs. THEN I can start making repairs on my truck. Looking forward to making some progress!
Later,
Paul
1972 c10
2000 FLHTC 126+k miles, so far
1967 BMW r60
2007 Xterra (Wife's ride)
R.I.P. "ESLL"
Woobie is offline   Reply With Quote
Old 03-25-2008, 06:17 AM   #130
68c10owner
68c10owner's Avatar
Re: Welders!
The last time I ran a bead was about 9-10 years ago with aLincoln weld pak 100. i did ok with it since it was flux core and no expereince. The other day I did a little welding at work with a Snap on welder and gas and I was surprized how decent my weldes were.
Anthony
Old 04-01-2008, 05:01 AM   #131
baggedcten
86 C10
baggedcten's Avatar
Re: Welders!
what welder would y'all recommend to use on exhaust pipe and mufflers? not something to expensive something that would get the job done and not have any problems. thanks.
1986 C10
2001 chevy silverado purchased 8-29-09 sold
2004 silverado purchased 8-27-10 sold
baggedcten is offline   Reply With Quote
Old 04-01-2008, 05:47 PM   #132
slug
slug's Avatar
Re: Welders!
thi last weekend i used a millermatic 130xp,it is a 110 unit. i tryed to use fluxcore, but it was welding like crap and i ran out of f/c wire, then i switched to solid wire and it welded like 100 times better. i was useing the flux core because it was windy outside, but the solid mig did a good job.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 04-07-2008, 06:11 AM   #133
TH53
Guest
Posts: n/a
Re: Welders!
Ive got a 135 lincoln mig, a lincoln AC/DC arc with a poor mans Tig, and a cheap ebay 40 amp plasma. All of them serve their purpose and work great. If any one is looking into starting tig welding and you have a AC/DC arc welder pick up a tig torch and a bottle of argon and start welding, i know it doesn't have the variability of a expensive tig and no foot control or welding aluminum but it will put down some really nice strong beads.
Old 04-08-2008, 02:58 AM   #134
DURRTY
USMC
DURRTY's Avatar
Re: Welders!
Later,
Paul
that should serve you well I have had a SP135 which is the older model of the 3200(i think) for 7 years. Ive run many pounds of flux core and hard wire through it. the thing even fell off the top of an 8 foot ladder once LOL dented the crap out of it but no other damage, I thought it was done for. It hasn't had a problem yet.
TH53 what kind of plasma cutter do you have? I have one loaned to me but I need to have one for cutting sheet metal ?
Semper Fi
Old 04-08-2008, 04:38 AM   #135
TH53
Guest
Posts: n/a
Re: Welders!
DURRTY I have a Everlast 40 amp plasma i works good, better than i expected, it was around $400 to my door. One thing is though if you decide to go with a cheap china plasma be sure to buy a big batch of consumables with it becuse you will be laughed at if you try to get them at a welding supply store.
Ty
Old 04-15-2008, 04:42 PM   #136
hinow41
Re: Welders!
Does anyone know some one in the long island area that could weld some parts on for me?
hinow41 is offline   Reply With Quote
Old 04-24-2008, 02:38 AM   #137
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: Welders!
Any opinions on a Hobart 140 with gas conversion kit (for doing tin mainly )
as a first welder purchase.
110v ( had 220v but only 2 lightbulbs and 1 plug-in,so i split it a couple of years back for 8 ft florescents and more plug-ins)
I am a novice (wait,,,I mean a virgin) at welding.
Like anything I've been new at, don't want bottom of the line stuff,but don't think (as a beginner)I need top shelf stuff either.
Was also thinking of the one from sears thats mentioned on pg.1 of this thread (but no response)and haven't seen any mention of the 140 ,any feedback would be awesome.
would like to get one this week before the other half decides it should be spent on something more important (LOL like there's anyting more important right now).I already got stalled out last year for that.
I plan on practicing alot before I even touch my truck.
Appreciate it, Thanks, Trent
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 04-24-2008, 10:02 PM   #138
DURRTY
USMC
DURRTY's Avatar
Re: Welders!
That one will work well for "tin" ( body work? right) its the same or real real similar to the miller and Lincoln 135-140 welders we have talked about.
one thing though, if your breakers are stretched out with allot draw on them the welder will blow the breaker or at least not run to consistent. try to get the welder on its own breaker and a 20amp if possible. other wise turn off as much as you can on the circuit you are plugging the welder into. It will still run decent if you cant just a FYI. I am no electrician, I am speaking from experience, and many trips to the breaker box. Once I got my garage wired properly the welder ran much better and didn't blow the breaker(20amp) again. also if you have to use and extension cord use the biggest gauge wire you can. I also have my 220 on its own 50 amp fuse.
Semper Fi
Old 04-25-2008, 01:15 AM   #139
b&a72
Active Member
b&a72's Avatar
Re: Welders!
I bought a Hobart Handler 140 and put gas on it and it works great. I have done all my welding on my truck with it. Works great on sheet metal and welds up to 1/4 which works for me because nothing on my truck is 1/4 anyways. I also did my c-notch and it worked like a charm.
b&a72 is offline   Reply With Quote
Old 04-25-2008, 01:37 AM   #140
spr85gmc
spr85gmc's Avatar
Re: Welders!
i have about 800 dolars to spend help me choose a welder
spr85gmc is offline   Reply With Quote
Old 04-25-2008, 02:01 AM   #141
hinow41
Re: Welders!
What is a good Mig welder that Is not to much cash? I want something to learn with and not spend a ton of money on.
Old 04-25-2008, 10:07 AM   #142
DURRTY
USMC
DURRTY's Avatar
Re: Welders!
go back through this thread your question should be answered
Semper Fi
Old 04-25-2008, 12:04 PM   #143
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: Welders!
Thanks DURRTY,the durability of my fuse box has kind of been in the back of my mind since the start.If I have to have it upgraded then I will.
I'm positive now that the HH140 is the one for me.
spr85GMC, My budget also is 800.00 I'm pretty sure I can get all my basic stuff for that much,the bottle I'll need might put it a little over that,but i haven't shopped for the cost on one yet
Thanks guys.
Trent
member#7816
'61 GMC in progress
Old 04-25-2008, 06:17 PM   #144
b&a72
Active Member
b&a72's Avatar
Re: Welders!
With my Hobart Handler I was welding for under $800 including the tank,gas, and wire. I bought mine from Northern Tool and came with a cart and free shipping.
Old 04-25-2008, 11:55 PM   #145
spr85gmc
spr85gmc's Avatar
Re: Welders!
i know right now i wouldnt trust my self on welding in a c notch but would this one work good to do that? its not going to receive daily use maybe once a week if that.
Old 04-27-2008, 10:54 PM   #146
hinow41
Re: Welders!
will this welder work for what i need to do? i need to weld on rockers and quarter panales
Amazon.com: Northern Industrial MIG 125 Wire Feed... Amazon.com: Northern Industrial MIG 125 Wire Feed...
Old 04-28-2008, 09:26 AM   #147
b&a72
Active Member
b&a72's Avatar
Re: Welders!
Yes it will work I used it on mine. Did all my body work and my c-notch with it.
Old 05-06-2008, 03:41 PM   #148
Billla
Billla's Avatar
Re: Welders!
I just popped for a Miller Millermatic 140 with Autoset. I considered the 180, but it just seemed like more than I would need and I liked the idea of being able to use the thing on house current even though I have a 220 outlet in my garage.
http://www.millerwelds.com/products/...c_140_autoset/
$649 at the local Central Welding Supply - "blowout" pricing
I bought a spool of non-gas wire just to see if I can still weld I'll go back and pick up the cart and bottle next weekend.
Billla is offline   Reply With Quote
Old 05-13-2008, 05:22 AM   #149
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Welders!
Hobart Handler 187 will do anything you need on your truck. You could get a HH 140 if you want to go with a 120 volt machine, but I wouldn't use it for any heavy stuff like frame work.
Slonaker (not an expert on welders, but learning )
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-17-2008, 07:50 PM   #150
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Welders!
BOUGHT ME A WELDER!!!!!
Picked up a Miller 175 in very good shape from a fellow board member and coworker. Need to get the right outlet in the garage and make me an extension cord so I can drag it out onto the driveway.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
