Old 07-01-2007, 07:55 AM   #126
los-lowrider
los-lowrider's Avatar
Re: How to lower my ride? Please help a newbie.
Dear all, in the end I ordered the air lift set up. At the moment front is installed and I am more than confident with the result. I think it's real fast and it works great. The options like leak warning are a great help.
I think this took me a big step forward.
System works with 3/8" valves, slam bags, and
WHAT DO YOU THINK???????????????????????????????
Here's the link to a video:
http://www.youtube.com/watch?v=AA7lSpPhuxI
Plans for next weekend are to install the rear bags which will be hard without welding ( without welding because otherwise I am going to get in trouble with the German TÜV). Hope to accomplish this target. In most cases it takes longer than you have thought!
Also I want to lower the rear additionally 2" with lowering blocks, mount a original rear bumber because this should look lower and a tow hitch.
BTW, I use an Range Rover compressor and it works much better than I imagined. Working pressure is 175psi ( which is a lot in my opinion), compressor turns on at 145psi and it only takes 50 seconds from 145 to 175 with an 20 liter tank.
Best Regards from Germany!
www.los-lowrider.com
los-lowrider is offline   Reply With Quote
Old 07-01-2007, 01:08 PM   #127
boatpuller
boatpuller's Avatar
sweet.if you get the camera out again and have some spare time,film that from the side.i'd like to see that unique truck from the side view going thru the motions.looks like it turned out nice.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 07-02-2007, 10:03 AM   #128
los-lowrider
Next weekend I will film from the side when all is installed!
Old 07-04-2007, 01:35 PM   #129
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Los-
It looks good. Thanks for the details as well as the video.
It's getting there. It won't too much longer before you have it on the road.
So, do you need to go with a bolt-on four-bar (link) to keep it legal?
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 07-04-2007, 02:44 PM   #130
los-lowrider
@boxrodz
Thank you. A four link would be a way but I spend a lot of money this year so a four link doesn't seem to be in my budget. I have to find other solutions. I drive the truck every day at the moment and have a lot of fun. Best of all after some work the system doesn't leak not even 1psi in two days! I am realy confident with the speed and options of the system. As I said above next weekend hope to get the rear done.
Old 09-18-2007, 01:14 PM   #131
los-lowrider
Hey guys, just wanna let you know that everythig is working great with the airlift set up.
I installed the rear bags several weeks ago and set my hangers 2-3" higher but without a lower stance. So I have to cut my leafs. I am a little bit confused how to handle this because i read if you remove leafs you are going to get in trouble.
N2TRUX told to remove a leaf ut as I said I am not sure about this so what would you suggest me to do. Remove a leaf or two or just to shorten the existing ones. I have a four leaf set up.
Old 09-19-2007, 10:41 AM   #132
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You can't cut rear leafs. Are you running an air over leaf setup?
You can remove 2 leafs from the 4 you currently have for a minumum of 2.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-30-2007, 11:07 AM   #133
los-lowrider
Today I have time so I took some short videos for you!!!!!!!!!!!!!
http://www.youtube.com/watch?v=q_jZdy7j3bU
http://www.youtube.com/watch?v=Il_iHCS24K0
http://www.youtube.com/watch?v=oAZEkfN8Llk
Old 10-30-2007, 10:07 PM   #134
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Nice! Looks good, man. Great work you've done there.
-- Will
killthewabbit is offline   Reply With Quote
