#126 |
Tasty Cakes!
Re: Air Ride For Dummies
If I am not mistaken, he took and inch off of the SD cups. That means the cups are about 1 1/2" tall. I cut mine 7/8" short, making my cups 1 5/8" tall. Supposedly on the 67-72 factory control arms, the bags will rub at full dump when the cups are cut 1". Some people don't care about this since there is no air in the bag, but I didn't want mine rubbing at all, so I left the extra 1/8". I don't know the results yet, b/c my suspension isn't done atm.
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
#127 | |
Great Thread guys One ? How is the frame drilling? Does it take an hour a hole, and a few bits....or is it not so bad? ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#128 |
Tasty Cakes!
Well, I started out w/a step bit after a recommendation from this board. I got about half-way down the bit before it decided to stop cutting. Luckily Lowe's took it back (it was like $35!) I then got the Titanium(?) coated Bosch bits and combined them w/some good lube. Cut through the frame like butter! I used a hole saw for the air fitting hole. Just took one drill bit and one hole saw bit for those, but I will use a new ones on the other side. (I've only done one side so far) The worst part was the hot metal shavings that got on me! OUCH! If u are drilling from underneath, make sure u wear long sleeves and eye protection!
#129 |
Jumping In - You are right about the "HOT" Metal shavings. Had tiny little dots on my neck from burns. "Do Not Drill Without Proper Eye Protection, I could only imagine.
To continue - I made a template for the top holes, Started with 3/16", then to 1/4", I believe next I went straight to the 3/8". For the airfitting hole I also used a hole saw (slightly used). I started with the same procedure up to 1/4" bit, Then to the 1" hole saw. I installed Slam's RE 7's, With 1" x 3/8" bolts and washers. |
#130 |
Hot shavings... ohh yeah. I got a rather larger one right in the crook of my arm. I still have the scare. It made me look like a druggy with a track mark.
shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#131 |
Tasty Cakes!
I was wearing short sleeves... (I live in AZ, I don't think I even have a long sleeve shirt anymore
![]() People who work on these things all the time are probably shaking their heads. But this is my first truck, so I'm learnin! So I will stress again... EYE PROTECTION!!
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 07-24-2008 at 07:48 PM. |
#132 |
Junior Member
Is the bed cut on this truck? I wanted to know.....cause its real low in the back (c-notch, lowering blocks) You would think the pumpkin would be hitting. Any bed pics??
going to sell this one...looking for a SWB project next. |
#133 |
I'm looking to bag my truck. How much cash do you have tied up in parts for the complete system?
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
#134 |
The OP hasn't been around in a while & I haven't seen his truck locally either.... not sure what happened to him.
#135 |
GM ONLY BABY!!!
Raceagmc, check out www.***************** for complete air bag kits. Or buy stuff in stages used from other board members in the suspension forum or on ebay. Step bits work good for me.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up Last edited by chevydog66; 07-28-2008 at 11:06 PM. Reason: added more info. |
#136 |
67GMC Slammed
OK so I want to bag my truck also, I want to use the Slam Specialties bag after reading so much about them here, but there are so many options, RE7, RE8, HE7, HE8, I know that R's are 200 and H's are 400lbs. which one do you guys recomend!!! (Oh ya I got a 67 fleet short..)
#137 |
Many truck owners here run Re7's or Re8's. 7's being most popular.
To raise your vehicle will never exceed 200psi. Unless you need 2 ports save your money and go with 7's from SuicideDoors. Last edited by Kayotic; 02-07-2009 at 12:45 AM. |
#138 |
I bought the Air Ride's from Suicide Doors after the Slams were out of stock and on backorder.
I haven't installed them yet, but I was assured that they are a better quality bag vs Slams.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
#139 |
67GMC Slammed
Hey Tim question... I cant decide between c-notch (which I already installed) or a full step notch. I do not have tires to see where I will sit, and don't care to "lay the frame" I was looking at your stance fully lowered, and I love the stance, what size tires do you have? Over all height.. trying to get an idea to help me decide..
#140 |
Tasty Cakes!
Resurrect an OLD post why don't you?
![]() Edit: Ok, my bad not THAT old, but I think it was as done as the dry-ass steak I had last night. ![]() And RE-7's are plenty for the rear.
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 02-07-2009 at 07:42 PM. |
#141 |
67GMC Slammed
sorry pretty new to the site, so much info to take in, did not even bother to look at dates, just goes to show you how awesome this community is, I still got an answer pretty quick thanks guys...
#142 |
Tasty Cakes!
Sorry, hope I didn't come off as an ass. I AM an ass, but didn't mean to be in the post.
![]() There is TONS of info on this board about bagging your truck. I did mine (noob alert!), and I got all of the info here and from a few well-placed calls.
