#126 |
Re: One-Man Cab & Bed Lift
I had the idea to lay it on the bed floor so I could make some arms to bolt up the bed floor to the dolly to provide a stable place to work on the bed and maybe even flip it over to clean up the underside. I have two or three naked bed floors and my bed dolly stays busy holding other things, just a thought.
#127 |
![]() Join Date: Jan 2009
Payment sent for cab and bed lift. Thanks
#128 |
![]() Join Date: Jun 2013
Payment sent for cab and bed lift, Thanks!
#129 |
Hi Kevin, I like your bed and cab lifter, would it also work for the '73-'87 cabs?
#130 |
Junior Member
![]() Join Date: Dec 2010
Are these plans still available? Saw it mentioned that the plans were $18 now. Just wanted to make sure before I sent over the payment (wanting both the bed lift and cab dolly instructions). Thanks!
1969 CST-10 - "Glory Bound" - build in process (slow going) 1971 Cheyenne 10 2006 GMC Yukon XL Denali Isaiah 46:4 - I will be your God through all your lifetime, yes, even when your hair is white with age. I made you and I will care for you. I will carry you along and be your Savior. |
#131 |
![]() Join Date: Apr 2015
I'm shure evey know u can make the cab lift with 2x4s and the cab dolly. I've made a the bed lift with metal sleeve tubes not that hard to make. But steel was a little pricey and my local steel yard.. i think I just saved $100 then to buy a new one all ready made.. but it works great!!!
#132 |
Member WiggyHD and I built one[cab flipper] to bolt his cab onto and I plan on using it for some of the 6 trucks I have in line to work on and just want to say LOVE it
#133 |
I also purchased the plans and built one. It is extremely useful. It has become one those tools I could not do without as I usually work alone.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#134 |
hi
are the cab plans still available? if so pm me the price and sending info thanks for any help jeff
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
#135 |
Anyone else have the problem when they built the lift and tip and flip dolly that their cherry picker legs are too tall and will not slide under the dolly making it so I cannot transfer the cab (on the cherry picker) to the dolly?
This also got me to thinking about transitioning the dolly from wheels to the legs. I had thought that I would just use the cherry picker to lift the cab up and off the wheels and stick the legs in and lower, but with the cherry picker not fitting underneath, that is a no go. -Bob
1971 Chevy C-10 Currently is rust repair |
#136 |
![]() Join Date: Jun 2012
Are the plans still available?
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#137 |
Sorry guys I haven't been around for a bit, new job has taken over all my waking hours and then so but it's starting to calm down a bit.
If you have any questions or concerns please PM me and I will always get back to you as I check for PM's weekly just don't surf the site as often. As for the clearance issue with the engine hoist not fitting under you can use larger diameter wheels or add a block between the wheel mount and the bottom of the dolly. As for lifting it to add the legs I always use a floor jack. Kevin LFD |
#138 |
#139 |
landarts
![]() Join Date: May 2005
I reached out to Kevin at this address and was able to purchase plans. kevinl.lfd@icloud.com
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
#140 |
Thank You
