Old 10-03-2009, 12:36 PM   #126
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: 72 suburban "3drdwn"
Originally Posted by Alan's Classic View Post
I'm enjoying the pic
Originally Posted by jonzcustomshop View Post
I am thinking yes on the GMC grille, so it will match the crew
Well I have been "4 eyes" since I was 5 so If I can find one then it's a go.
What did you end up doing to the dually suspension? Is it bagged now?
We need to hijack this thread with some cool dually pics!
Dually is bagged in the front for now this pic was taken right after I flipped her around to get the back end in for notching and rear air, probably AOL with something more elaborate once my proper operating theater is free of the friends mini truck in there now
Originally Posted by FRENCHBLUE72 View Post
Mine has been sitting also while I have been other projects but this winter she is gonna get some work done to her.....Btw I took my headlights out of her so she couldn't see me workin on other trucks also.... hahhahahahaha
That is funny. I was actually trying to find my buckets to put my bulbs back in so it looked a little more like a runner.
Originally Posted by joe231 View Post
cool shot
I wanna see more pics of the crew cab....got any?
There is a build page in the square section of the forum but I need to update it. I also did a post on installing the flip kit in the suspension forum, otherwise search for RunninLo on photobucket and go to my albums. Ignore the goofy pictures of my big noggin from when Alan's Classic visited. Those seem to pop up first. I'll get some more updates on her as she progresses. it's a little tight for pics in my lil garage,
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 11-17-2009, 05:28 PM   #127
r1lorenzini
SUBSCRIBING!!!!!> i am still drooling damn!!!! SICK
r1lorenzini is offline   Reply With Quote
Old 11-22-2009, 08:59 PM   #128
jmedero
jmedero's Avatar
sick build!! great vission on the burb, keep it up bro. I got a 68 GMC that I am about to start and will be switching the front end out to a Chevy. Let me know if you are interested in the GMC front grille and core suppt.
Keep up the impressive work.
Juan
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 12-04-2009, 01:14 AM   #129
ratty 46
Looking good ........ Updates? I'm in on the subscrip.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 12-26-2009, 11:58 PM   #130
RunninLo
RunninLo's Avatar
Well I have still been working on structural improvements (electrical,insulation, drywall) to shop so not much in the way of burb work. It has also been cold as heck here to make things worse. I did start fitting the Uni-steer column in place. I have the parts to do a two piece shaft but looks like I may get away with doing it in a single piece.
it's a tight fit andI may need to remove the sheild from the factory manifold. worst case I'll have to cut it down to two and throw in the extra u-joint and shaft support.
I have jury Duty (yay,lol) so probably another couple weeks before anything else.
Josh
88 4x4 crew DD
Old 12-27-2009, 12:04 AM   #131
lolife99
67-72 parts collector,…
lolife99's Avatar
Would shorty headers get you more steering linkage room?
Seems like those manifolds drop down right in the way.
Old 12-27-2009, 10:46 PM   #132
RunninLo
RunninLo's Avatar
probably. I had been debating waiting but it would be sooo much easier to move with the steering hooked up. guess I should start header shopping.
Josh
88 4x4 crew DD
Old 02-03-2010, 02:02 PM   #133
Wildstreak
"something witty here"
Wildstreak's Avatar
x2
Love the work, you have a very sick looking burb so far. Do you know what you're going to do about the drive shaft? are you going to use a carrier bearing? does the tub need to be channeled because its so low? sorry for all the questions, Ive just been thinking about using pretty much the same setup as you have for my burb.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 02-11-2010, 12:22 AM   #134
RunninLo
RunninLo's Avatar
Originally Posted by Wildstreak View Post
x2
I have the non-2link carrier xmember that Porterbuilt sells to compliment the rear. I plan to have a new driveshaft made specifically for the burb as it is now. It will use a later model carrier bearing.
I did manage to get the steering hooked up and functional although I still need to make a support bracket for the idler. I realized that I had enough double D bar to do it twice if needed so I just went for it. It is set up very similar to a double cardan at the column with the idler pretty much right above the rear bolt for the upper control arm.
As I mentioned in an earlier post alot of the work has been postponed while doing insulating and sheet rock for my garage. To make room most of my treasures were in a bull pen area of sorts of the side of my house. It is shielded from view on 3 sides. I thought everything was tucked away quite nicely but appearantly some busy-body thought other wise. A love note from my local county agency offering to scrap all my goodies for free arrived recently and so drywall plans have been put on hold while I move everything back inside. Only good thing to come from it was I was one stall short and so the Mrs. let me get a 4 post lift. Here is a shot a friend requested with the dually and 'burb modeling.
The dually will go back outside since it is running and papered the county can't say anything about it but my 4runner and beetle will both fit under so that is a bonus
Josh
88 4x4 crew DD
Old 02-11-2010, 12:27 AM   #135
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Nice lift. The burb looks sick
Alan's Classic is offline   Reply With Quote
Old 02-11-2010, 12:49 AM   #136
ratty 46
Nice work space ...... I'm also glad to see I'm not the only one that gets ball busted by the boys in blue about vehicle tags ....... don't they have criminals to find??
Nice combo shot of both vehicles.
Ratty 46
Old 02-12-2010, 06:44 PM   #137
Number98
Prestige Worldwide
Number98's Avatar
Been there!
I really appreciate the fact that they "offer" to scrap them for free..... such a good deal huh
Number98 is offline   Reply With Quote
Old 02-12-2010, 09:06 PM   #138
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
what bad is your place dosen't look any worse than some of the other places in the area... you must have some real ----- for neighbors..
Old 02-12-2010, 11:23 PM   #139
RunninLo
RunninLo's Avatar
Well Jon you have seen my place. I have a decrative concrete driveway with side pad for my trailer and the bull pen area I mentioned was backed on one side by my 10'foot high storage shed, another by my 17' garage wall , and the third by 12' tall lilac bushes that are too thick to see through. I have the fencing to shield it from view from the side facing Reserve but never got a chance to put it up. There were 3 vehicles which were neatly parked side by side. One of them was running driving, registered, insured and the only reason it was there was to keep it off the street so it wasn't tying up a parking space. I have spoken verbally and shaken the hand of every resident on my block being very up front about what I do, what my intentions are and if there are changes such as the drywall project they all know in advance. I have been told who it was and the coward has told me to my face that everything is cool while filing complaints behind my back. The only saving grace here is the county enforcement officer has been very cool and has only taken action to the extent that I am actually breaking the law. Are just about everyone in the area doing the same to a certain extent? Yeah. I'm lucky enough that I had room to move the non-compliant rigs inside and didn't have to sell anything although coincidentally Heather did sell her '72 scout this week.
Josh
88 4x4 crew DD
Old 02-13-2010, 08:41 AM   #140
jonzcustomshop
1961 crewcab
BTW I didn't mean to make it sound like your place looks bad, because it dosen't
more that quite a few people in our area here have multiple vehicles at thier places.
there is a guy I know over on 10th that has about 10+ vehicles, he just put permanent plates on all of them, and every now and then shuffels them around.
Old 02-15-2010, 04:49 PM   #141
aggie91
I'm just glad to be here!
aggie91's Avatar
Your sub looks cool lay'd out! With it on the lift and your dually under it, how tall is you ceilings to get that to fit?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-17-2010, 09:11 PM   #142
RunninLo
RunninLo's Avatar
I haven't put tape to it but if the contractor did his job right the bottom of the trusses should be 12' up.
The lift is a Danmar D-7X. since i plan to use it mostly for the extra parking space it didn't seem worth it to buy a pricier brand. I got it from Northern Tool catalog. Northern's customer service was excelent and the lift is perfect so far. I did have one issue though. The Caster kit was a very important part of the purchase for me since I will need to move it around from time to time. As I unpacked and began checking items off the parts list I had every single piece but the actual casters. Now the freight company had done a pretty good job with it but it did have a few spots in the shrink wrap where a part or two could've fallen out. There was nothing on the packing list to indicate that the casters hadn't been shipped. I placed a call to Danmar and the guy that answered the phone informed me that the casters were on back order for 90 days. I politely asked why there was no communication to that fact and got sort of a "tough luck, buddy" answer.
I wouldn't let it stop me from buying the lift again but I definitely wasn't impressed.
I have about 6-8" from the roof of the burb to the lights but the frame of the burb is actually hanging about a half inch BELOW the deck between the runways . Theres also approx 8-10" between the Dually roof and the bottom of the runways. Stock height vehicles may not have fit as well.
Josh
88 4x4 crew DD
Old 02-21-2010, 02:04 AM   #143
epashhans
epashhans's Avatar
Just read your entire build here and very, very cool. I was just over in zoo-town today for a nice little day trip with the fam. I can't wait to see your progress with the burb...and maybe someday in real life! Keep up the good work!
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 06-30-2010, 08:15 PM   #144
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
De-amn I love that burb, wish I could find either a 60-66 or 67-72 roller for a good price
any good updates?
I am really interested in more on the rear "dropmember", I've read all the threads on it including all the ones started by Nate. I can't decide if I should use his trailing arm setup or the 4 link, common sense says 4 link but hey I've been wrong in the past.
Ghostwhite is offline   Reply With Quote
Old 11-28-2010, 06:03 AM   #145
SBTork
Garage wrench
SBTork's Avatar
any updates on this one?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-28-2010, 11:31 AM   #146
kev2809
low n' slo
kev2809's Avatar
x2
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-28-2010, 02:09 PM   #147
project 67 sub
project 67 sub's Avatar
x3
project 67 sub is offline   Reply With Quote
Old 12-13-2010, 02:02 AM   #148
RunninLo
RunninLo's Avatar
Sadly, other than moving the lift to about where I was standing when I took those last pictures it is in pretty much the same spot holding the lift down. A '63 Impala SS has taken up living underneath to keep it company though. The duallys have taken up a ton of my time the last few months and I have been workin on MY V30 Crew cab putting in a lift and 315/75/16's. It has been sub 20 degrees for about a month and the Mrs. talked me into remodeling her kitchen so no garage stuff until well into 2011.
Looking forward to spring already,
Josh
88 4x4 crew DD
Old 12-27-2011, 01:26 AM   #149
C@rnut001
I love how your Burb looks... have you gotten to any updates? It sure looks killer!
C@rnut001 is offline   Reply With Quote
Old 12-27-2011, 09:10 PM   #150
ratty 46
Yahhhh ... what progress is being made??
R46
