#126 |
Re: Finally!!! 6.0 POWAH!!!!
Man glad to hear you got it on the road and you can enjoy the fruits. When do we get to see some vid of this beast
#127 |
Soon as I can get someone to hold the camera
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
#128 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Waiting Anxiously.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#129 |
STOP! Hamma time!!!
Damn! I hate looking at this thread cause it’s got me jonesen for getting my 5.3l swap finished. But now I want a 6.0l to rid myself of the regret factor. Congrats on a finished swap. You gotta get that camera on that engine and do another sound check soon!
Plan your work and work your plan!!!, or pitty da fool!! ![]() 87 GMC BaseTrim, 305 under the wrench/TH400/ 92 Chevy 1500, 350,TH700R4 sittin on dubs |
#130 |
PCMCOBRA, Was the 6.0 a single line fuel rail or a duel line?
Thanks in advance. Last edited by Cherub; 10-08-2008 at 05:04 PM. |
#131 |
single, no return.
Running the vette filter/regulator back next to gas tank.
#132 |
Thanks man.
One other thing how did you resolve the issue with the drive shaft and transmission? the yoke size is different correct. |
#133 |
Cherub,
I had the driveshaft shop use a crossover ujoint. Finally changed to a truck intake, so now I have a cover on top of it. ![]() Looks better.
#134 |
67-72 parts collector,…
![]() Join Date: Nov 2002
pcmcobra,... How much money do you think you spent on this swap? I'm trying to justify doing one of these someday. Any chance you could give us a break down on all the prices?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-23-2008 at 08:43 PM. |
#135 |
hmmm.
3500 motor and tranny 350 shipping 500 harness 300 tune 150 new gas tank 400 fuel pump, misc an hose/fittings 100 new tranny cooler 300 new lokar oil/tranny dipstick,throttle cable and tranny linkage 30 91 burb cluster (for electric speedo) 200 driveshaft work 600 headers 200 reconnect exhaust/fit new pipe maybe I should stop now? lol Next up is new posi/3.73 gears. Then big brakes all around. Then, maybe bag'it
#136 |
![]() Join Date: Apr 2005
[QUOTE=pcmcobra;2943187
Finally changed to a truck intake, so now I have a cover on top of it. ![]() Looks better.[/QUOTE] Did the one from my Burb motor work? Are you happy with the tune now? Need some pictures, ![]()
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#137 | |
Why did you go with a truck intake mani? What manifold was on it before(ls6 ls2)? Last edited by Cherub; 10-24-2008 at 08:48 AM. |
#138 | |
![]() Join Date: Mar 2006
When are you going to take me for a spin in that bad boy...or even let me behind the wheel? ![]()
1986 C10 - LWB, 305/700r4, posi, vortec heads |
#139 |
Rob, yes the intake you gave me is on it now. Had to get some brass inserts for throttle cable bracket. No problem. thanks!
Cherub, I had a van intake, same as a truck, it just did not have mounting provisions for a cover-reason why I went to truck intake. Ogre, if rain holds off this weekend, I'll be running around, give me a call!
#140 |
pcm quick question. What motor mounts did you use? cause my stockers with polyurathane inserts are not lineing up. Im going to just try stock ones and see if that fixes the problem.
#141 |
Cherub,
I used carshopinc plates and stock mounts/inserts, lined up just right no problems. One of these days I will get a video made!!!
#142 | |
![]() Last edited by Cherub; 11-23-2008 at 09:47 PM. |
#143 |
Gen III Power
Any updates on the 6.0 ?? New tune ?
Did you end up going with a big break conversion ? Im still in the works with mine...May be a couple steps closer in the next few months.. Hope to see some updates !! ![]()
---Bob--- '81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon... |
#144 |
hessian,
New tune, all is well. No big brakes yet, still saving for the new rearend. Sorry for the late reply.
#145 |
i got my lq9 complete for $2000 tax included its an '07 w/ 27k miles
#146 |
Thats a beautiful set up pcm im trying to get around to starting mine i need a new tranny and fuels system and the little stuff so the motor is sitting and waiting for now
#147 |
what fuel pump is everybody using? i've got an ly6 6.0 and i've seen people talk about using an '87 tank because it has baffels and an ac delco ep 241 pump but i cant find any infor mation on this pum in regards to its pressure capabilities... can somebody point me towards a good pump that would allow me to use a stock tank?
'87 SWB GMC LY6/6L90E '70 JEEP CJ5... My new toy '06 Hyundai Accent... DD Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1# |
#148 |
a/c delco ep381. will work w/ stock 87 sending unit and tank. its rated at i believe 80psi.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#149 |
btw, hows the truck running pcmcobra??
#150 |
thanks for the reply i'll look into it
