Old 05-07-2008, 12:12 AM   #126
D-Monkey
Re: project INCREDIBLE HULK 6.2L with 6L80E
I only see 1 prob so far, engine isn't orange yet!
real awesome build, if u can figure out how to put that engine in my 04 single cab tacoma, let me know
D-Monkey is offline   Reply With Quote
Old 05-07-2008, 07:53 AM   #127
SCOTI
SCOTI's Avatar
Originally Posted by killer71 View Post
So are we to assume that dod and vvt mean the samething or are they 2different terms?
Everything I've read says they're 2 different things. . . ....
DOD is supposed to delete the firing of sequential cylinders under "limited load" situations @ fixed-rate RPM. What I've read is this means it kills 4 of the 8 cylinders under consistent, constant, light load conditions which theoretically will increase mpg 10~15% on the highway. This seems like it would be tough for an aftermarket/non-mass produced application to maintain its funstionality.... IDK.
The VVT adjusts the cam phasing so the motor is more docile @ idle (producing better efficiency & reduced emissions) yet can maximize output as the cam timing changes throughout the RPM range. This should make an already efficient engine even better (potentially more power per unit of fuel burned or less fuel to match current power levels).
Am I close 68ss?
I'm just curious how these things will respond to the 'tuners' tricks. In communications w/Don, he seems very optimistic.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-07-2008, 05:50 PM   #128
68 short step
you are right on about that scoti.....
i come to realize there are 2 diffrent L92 out there. the first style has the DOD the second (later) has VVT.... this engine is the later.....there is currently 1 aftermarket cam manufacturer... and tuneing is bout 8X harder then the 'normal' LS1 computer.... there is more tables to mod and diffrent tables at diffrent RPM/load/ temp/ octane leveles etc............
68 short step is offline   Reply With Quote
Old 05-07-2008, 08:14 PM   #129
SCOTI
SCOTI's Avatar
Hhmm. . ..... We need one of these DOD systems w/some turbos.
Switches to 4cyl mode on the road w/slight boost to keep the power levels like a mild 5.3L & then w/a romp of the pedal, it comes alive on both cylinders & boost like a LS7 on roids.
Mo powa.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-10-2008, 08:37 PM   #130
steelhorse
steelhorse's Avatar
Lookin good!
steelhorse is offline   Reply With Quote
Old 05-12-2008, 03:10 PM   #131
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Holy crap I dont know I missed this build thread,good work guys...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-12-2008, 06:15 PM   #132
68 short step
you havent missed it yet
here are tbe engien painted my tradmark color... the oil pan is gonna be switched to a f-body style, so thats why it isnt painted too..
Old 05-12-2008, 06:38 PM   #133
71Hulk
There's gotta be some headers lying around that place somewhere...
71Hulk is offline   Reply With Quote
Old 05-12-2008, 06:55 PM   #134
68 short step
yea, just a few sets....ill get a money shot for ya with em on there..
Old 05-12-2008, 07:02 PM   #135
71Hulk
you always do...
Old 05-13-2008, 08:04 AM   #136
tk-mpl
tk-mpl's Avatar
Talking Re: project INCREDIBLE HULK 6.2L with 6L80E
So did you do any mods inside or are they going to be bolted on top???
tk-mpl is offline   Reply With Quote
Old 05-15-2008, 05:30 AM   #137
68 short step
got the 23 gallon aluminum fuel cell, mounted up. i had to remove the rear crossmember to mount it, but the rear hidden hitch will make-up any rigitity that was lost..... i welded the nuts to the inside frame , so it wont be a pain should the fuel tank need to come out...... also started to work on the accesseries, got the starter cleaned/painted, and the P/S and ALT bracket cleaned/painted, and the P/S pump itself will be blasted and painted tomorrow, then it'll all be reassemembled and installed back on the engine... and lastly here are the 1.5" lowering blocks that i blasted and alodined..
Old 05-16-2008, 06:00 AM   #138
FRENCHBLUE72
PROJECT 7DEUCE
Wheres that fuel tank from?
MEMBER #6377
Project "7DEUCE"
Old 05-16-2008, 06:11 AM   #139
71Hulk
fb72, the tank is from board member fuelcellguy!
Old 05-19-2008, 03:27 AM   #140
68 short step
still painting on the acceries... got the PS pump blasted and painted, all the pullies painted and its about ready for some clear to make it shine
and started the wiring harness
Old 05-19-2008, 06:26 PM   #141
memphismatt
memphismatt's Avatar
That last picture scares me!
'68 C 10 short step
'92 C1500 RCSB
'92 C3500 ECDRW
'96 C1500 ECSB
memphismatt is offline   Reply With Quote
Old 05-19-2008, 07:20 PM   #142
my67chevytruck
Under Construction
my67chevytruck's Avatar
It may scare us.... But Don has it down Pat!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-19-2008, 08:45 PM   #143
SCOTI
SCOTI's Avatar
He makes it look easy doesn't he?
I took the plunge & just looking @ the motor/trans in stock form is over-whelming right now. I wan't to start stripping it down to necessaties (eliminate all the late model requirements), but I'm worried I won't know where it all goes back if I remove too much .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-19-2008, 09:17 PM   #144
Rokcrln
Rokcrln's Avatar
You are doing one heck of a job on this truck, I am very impressed!
I just bought a 5.3L/ E4L60 that is one of those DOD motors but have been told by several aftermarket Companys that it is not worth keeping that way. I was told it is not go into 4cyl mode like I thought it would. It only shuts off the 4cyl's for about 1.5sec every 30-45sec. If it shut them off for any longer it would do damage to the cylinders, valves, rings and what ever else. The MPG gain is even lower that the reported 10-15% but for a company like GM it makes a differance for their over all Goverment mandated program so they can bring us toys like the LS7. I am dropping my 5.3L into a 51 Ford F1 that I am building for a shop truck and figured this was the best way to fix a Ford
How much clearance do you have between your front tierod and the Height monitors? I looked at mounted them their but was not felling too comfy with how close it was looking at steering lock and full bump so I mounted them off the frame and Z'd the link.
Also what year did they start the DOD and VVT on the Vortec's?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-19-2008, 11:46 PM   #145
68 short step
kevin,
dunno who you talked to at what company.... but how it works is the ECM sences the throttle position, and load. if its within the limits it'll shut off 4 cyl. indeffently to conserve fuel....
how it does this is through oil pressure to 'special' two piece lifters....when in the 4cyl, mode the outer part of the lifter moves with the cam, but the inner part does not move.. I E the pushrod nor valves move either...when the ECM sences a change in the load (going up a hill), or more gas (pedal position chages outside the limits) it switches back to 8cyl. mode... it does this in meer milliseconds and cant not be detected, other then the exhaust tone....as a matter of fact those DOD cylinders receive less ware do to this function....
Scoti,
welcome to the club.....you know we'll require a thread with pics
Old 05-20-2008, 06:22 AM   #146
mfarmer
Excellent build. I am always amazed buy how these trucks can be hiding so much bad stuff behind there beautiful exterior.
mfarmer is offline   Reply With Quote
Old 05-20-2008, 05:56 PM   #147
HuggerCST
HuggerCST's Avatar
Nice! Looks like you've got the right man for the job, Hulk. Have you decided on the colors, or did I miss that? Can't wait to see it done.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 05-20-2008, 07:45 PM   #148
71Hulk
2 tone!
Old 05-28-2008, 06:36 AM   #149
68 short step
got a little progress to report,
switched to a f-body oil pan and windage trey (for better ground clearance),evrything looked good on the internals too, and got some braided stainless steel fuel line with AN fittings ran.....
Old 05-29-2008, 04:57 PM   #150
PipsC10
PipsC10's Avatar
where did you get your lower kick panel patch panels? I love the way you mounted your front ride height sensors, awesome build!
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
