Old 10-30-2010, 10:26 PM   #126
baclay9
Re: Prepping for a BBC conversion
Do you happen to have a part # on the fans you ended up going with? I looked through the thread and couldn't find it. Do you remember how many cfm they were?
baclay9 is offline   Reply With Quote
Old 11-04-2010, 07:14 PM   #127
east1la
nice truck you have their. what size tires do you have on your truck? I have a 1987 chevy pickup, that i'm working. i'm thinking of getting some 20 inch rims for my ride.
Originally Posted by 87Lowrider View Post
Thanks!!
They are 20" American Racing - Torq Thrust II's
Kenny
east1la is offline   Reply With Quote
Old 11-11-2010, 06:15 PM   #128
sarge75801
Let me see if I am seeing this correctly. The front water hole on the intake manifold is where you put the temp sending unit, you ran heater hoses from one of the top intake outlets, blocked off the other top intake hole, ran the 2nd heater hose from the radiator, blocked off the two holes on top of the water pump. Is this correct?
I'm building an '82 shortbed with a big block, and using the same intake you have, and want to get it right...
Scott
I replaced my valve covers today with the tall ones since I had spacers on the heads and the short ones... Looks much better. I also installed Comp Cams Full Roller Rockers because the stamped rockers were not allowing proper oil flow according to the mechanic who has been helping me through some of the issues.
I also got my flex-a-lite electric fans working good today after relocating the sending unit to the front of the intake and blocking off the hose to the water pump.
sarge75801 is offline   Reply With Quote
Old 11-28-2010, 12:33 AM   #129
Valhalla
Valhalla's Avatar
very nice truck man. I am picking that body style for my next when my 70 is done.
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh
Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own.
SqueegeeMan
Valhalla is offline   Reply With Quote
Old 12-26-2010, 06:47 PM   #130
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Sorry for the delay.. I've been off the board for a while, but if you still need it, that's a Flex-a-lite 220 fan set rated at 2500cfm. Get something bigger if you can. It does great above 30-40mph, but idling in traffic it doesn't take long to get over 200 degrees and keep getting hotter. I start figeting when I see that temp rise too much for my liking and look for ways to get some speed to get the temp down. I've found that if you take the temp outside and add 100 degrees to it, that's where the water temp usually hangs.
Here's the link to the one I got from summit
http://www.summitracing.com/parts/FLX-220/
87Lowrider is offline   Reply With Quote
Old 12-26-2010, 06:48 PM   #131
87Lowrider
87Lowrider's Avatar
Tire sizes are in my signature below.
Old 12-26-2010, 06:53 PM   #132
87Lowrider
87Lowrider's Avatar
Scott
Scott,
That's correct. There may have been a better way but I haven't played with the options. This one works though.
Kenny
Old 12-26-2010, 06:54 PM   #133
87Lowrider
87Lowrider's Avatar
Thanks!!
Old 04-16-2011, 09:23 AM   #134
baclay9
Where does your oil pressure sending unit go? I thought I knew where it went, on the drivers side of the block at the front just behind the power steering pump. But the threads are nowhere near the same. Is there some kind of adapter I need?
Old 04-16-2011, 02:44 PM   #135
sarge75801
There a couple of holes near the oil filter mount. Your oil pressure gauge should have come with 2 adapters, one of which will fit these holes.
Old 04-16-2011, 05:23 PM   #136
87Lowrider
87Lowrider's Avatar
That's where mine is.. driver side of motor just above the filter. Hole already there to screw sending unit into. Connects to control unit of the Dakota Digital cluster.
Kenny
Old 04-16-2011, 06:58 PM   #137
sarge75801
There are two holes, different size. Autometer sends adapters to use either hole
Old 04-20-2011, 09:31 AM   #138
baclay9
I have another one for you. I didn't see much info about your transmission. I am assuming it is a TH400?
When going from a TH350 to a TH 400 did moving the trans crossmember to the rear mounting location accomidate the longer trans? I went ahead and moved mine it hopes that the trans would line up.
Old 05-14-2011, 09:20 PM   #139
87Lowrider
87Lowrider's Avatar
I really can't remember but it seems like we had to modify it a bit. I'm also thinking we used the x-member out of the '76 donor truck as well.
Next time, I'm under it, I'll look and see if it's the original one or not and what changes we made to it if any.
Ken
Old 10-31-2011, 07:04 AM   #140
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Did you do any other changes when you blocked off the by-pass hose? I've heard if you block it off the water won't circulate right & could run a little hot. Great work by the way!!!!
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 10-31-2011, 07:48 AM   #141
87Lowrider
87Lowrider's Avatar
Thanks and no I didn't do anything else, but, I've had a problem with it getting hot though. I wrote it off to something that was normal for the engine setup, but now that I've done some reading recently to figure out why, I've concluded that I should have not bypassed the by-pass. I am going to reinstall the hose this week and see what happens. I'll let you know how it turns out.
Old 01-30-2012, 05:27 AM   #142
81C10LS3
81C10LS3's Avatar
god i love this truck!!! by chance, do you know what offset/backspacing those wheels are. My rims are like your old ones but the offset is off so i need spacers or new rims...thx
81 C10 LS3/6L80 - frame off - in progress
81C10LS3 is offline   Reply With Quote
Old 03-27-2012, 08:44 PM   #143
87Lowrider
87Lowrider's Avatar
No, I don't. I've looked around but can't find it. I had it documented somewhere though.
Old 10-02-2012, 07:43 AM   #144
87Lowrider
87Lowrider's Avatar
Yesterday, the 87Lowrider was sold to a dealer in S. Indiana. I picked up an '05 Silverado Stepside 4x4 as it's replacement. Thanks for all the help from everyone here in getting it to where it was.
