Old 03-25-2009, 08:15 AM   #126
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
Originally Posted by Jvsapp View Post
i was going to suggest trying flipping it around and putting the switches under the deck.
Thats what we did.
Worked well!
Joey~AP is offline   Reply With Quote
Old 03-25-2009, 08:30 AM   #127
4dranch
Shloooooong bed member #2
4dranch's Avatar
Re: k5 66
Very cool Joey.
I may come to Texas so that boy can take me muddin....or you all come up and try it out in the Mississippi river bottoms...
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 03-25-2009, 10:01 AM   #128
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
Although it's on the road.....I still need to rebuild the front end and drive shaft and build a new cross member for the transfer case.
The angle of the drive shaft and the cross member dont agree with each other.
Old 05-04-2009, 02:59 PM   #129
62 short step
62 short step's Avatar
Re: k5 66
Joey, can you get me some pics of the body mounts with the spacers? How tall of spacers did you have to have? Thanks.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 05-04-2009, 03:51 PM   #130
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
I didnt document installing the body mounts and spacers very well.
The K5 frame came up, abruptly , in the back, and that is where I dropped the 1st body bolt in.
I leveled the cab....placed the body mounts where I thought they should go on the frame.....and cut spacers to fill the void.
Probably not the best way.....but thats how I did it. Not my proudest moment of the build.
Old 05-04-2009, 04:37 PM   #131
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: k5 66
It works, and looks nice to me...
If you were building a show truck, not a driver, then you might want to spend alot of time on them, but function first, form second...
Old 05-04-2009, 05:10 PM   #132
daverod
SSN 706
daverod's Avatar
Re: k5 66
Nice work on that cab. I thought mine was a rust bucket. Keep up the good work.
daverod is offline   Reply With Quote
Old 05-04-2009, 05:14 PM   #133
62 short step
Re: k5 66
Thanks Joey, thats what I would looking for. Looks good to me.
1965 c-10
86 chevy c/k 20
Old 05-14-2009, 09:54 PM   #134
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Late Model Seat Belts
Seatbelts....
66 to my knowledge didnt come with shoulder belts. Just lap belts.
Cody and me went junkyard scroungin....and molested a late model suburban for its belts.
The floor boards of the 66 are at about a 45 degree angle.....so we had to level things out.....as late model belts work by inertia. The belt housing has to sit perfectly level, so that when ya smash the brakes....a little weight swings in one direction or the other and locks the belts down so that they wont lengthen....allowing you to go flyin thru the front winder!
I then mounted the top mount of the belts with big fender washers. This werent easy, as there was no way to physically hold the nut and washer with your hand. I had to glue the washer to the nut.....and then put the nut in a long box end wrench and slid er up in there. Took several trys.....but we got er done!
Old 05-14-2009, 10:06 PM   #135
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
I did get the stereo plate flipped over and got the stereo installed. Didnt turn out too bad.
I also cut out a piece od aluminum diamond plate for a glove box insert.....and installed a 1-5/16" wrench on the dash for an "Oh ****!" strap.
Old 05-14-2009, 10:10 PM   #136
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Random "Cody and his 66" pix
Old 05-14-2009, 10:40 PM   #137
Jvsapp
Jvsapp's Avatar
Re: k5 66
came along very nice joey. love the oh $hit bar.
Jvsapp is offline   Reply With Quote
Old 01-20-2010, 10:16 PM   #138
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: k5 66
what happened to this build?
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 01-21-2010, 08:39 AM   #139
jonzcustomshop
1961 crewcab
Re: k5 66
I'm guessing its done and he's driving the heck out of it!
...but yes we need an update.
it sure came out nice.
Old 01-21-2010, 09:25 AM   #140
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
He has been driving it.
I will post some more updates on it today.
Old 01-21-2010, 11:58 AM   #141
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
I found some pix of it when we first bought it and thought I would share, as I did not have them when I started posting here.
Old 01-21-2010, 12:07 PM   #142
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
Transmission trouble!
Cody called me from school sayin that his truck would only go forward. I told him thats good. Cause he would look awful funny drivin that thing home in reverse!
We thought that the linkage in the column was wore out, so I went down and bought a B&M floor shifter.
Turns out that the "S" hook had fallin off the valve rod (I guess that is what its called).
Cody was excited about the new shifter, so we went ahead and installed it.
Looks and works real well!
Old 01-21-2010, 12:14 PM   #143
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
We still had the original radiator in it. About a month ago....it laid down on us.
The old one.
I couldnt find a OEM replacement that I could afford, but I did find an aluminum one that was very affordable.
The 1st on came in and it looked like it had got ran over by a bulldozer!
They sent me a 2nd with no hassle. It fit well and was set-up for an automatic, so now we have a secondary transmission cooler.
Old 01-21-2010, 12:26 PM   #144
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
The truck is 4x4, but I have yet to install the front driveshaft. The cardon joint would hit the crossmember, due to the amount of lift I have on it and the extreme angle.
So....I broke out the weldin machine and went to work on building a new cross member.
There is probably a better way, but this is what we ended up with......
The original crossmember
The unsuspecting stick of heavy wall 2"
Transfer case mounting plate
Figerin out how to make a close offset
Old 01-21-2010, 12:29 PM   #145
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
Old 01-21-2010, 12:31 PM   #146
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
Old 01-21-2010, 12:35 PM   #147
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
Welded out and painted
Cody gettin it installed.
Dad helpin out
Old 01-21-2010, 12:38 PM   #148
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
The installed product!
Plenty of room for the cardon joint now!
Old 01-21-2010, 12:39 PM   #149
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: k5 66
And that is where we are at today!
Old 01-21-2010, 06:03 PM   #150
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: k5 66
have yall played in the mud yet?
Gage
