#127 |
Re: Here is a "Not Your Typical" 4wd Blazer build
The other thing you must be careful about on your front end setup is that, yes it does act as a sway bar, and yes it limits articulation. But the problem spot is the axle, it is possible that if you round a turn hard enough you will spin the tubes to the pumpkin. If you are running this setup I'd recommend putting a full seam weld around your tube to pumpkin. We thought of this when we were building my CJ8
![]() ![]() ![]() Passanger side: ![]() Driver's side: ![]() |
#128 |
.....I am working on it.....
It will be fully welded around the tubes. It will also have a small truss that will help strengthen the axle. Thanks for the info.
#129 |
Sandking - my neighbor....
This build is amazing. Let me know if you ever need a hand. I would be glad to help. I have to check your build out in person one of these days. Im off Green River, by the way. Travis |
#130 |
Cool, your close, I am off Ontario and Lincoln. Feel free to let me know when you would like to check it out. Thanks for the props. Joey
#131 |
Got a donor for the heart transplant, it's an LMG 5.3 from a 2007 Suburban. It should be at least 400hp by the time I am done with it.......
#132 |
This thing is turning out sweat! What trans are you going to run?
#134 |
will be a nice set up and awesome job on the cage and suspension work!
#136 |
I just read the entire thread and have a question. What type tubing are you using, EMT, IMC or RMC?
#137 |
![]() I am using 1.75 x .120 wall DOM tubing. The frame will be plated in the areas that the cage attaches to. Then on the inside of the frame. it will have rectangle 2x4 tubing from top to bottom. That should do the trick. |
#138 |
blazer glass fenders
I know a guy making these!! Last edited by drbyrdman; 09-07-2009 at 11:51 AM. |
#139 |
1967 C10 SWB
WOW! This thing is way over the top!!
I Love It!!! Keep up the good work bro, you make us proud!! I will follow along from here on out. Vex ![]()
http://67-72chevytrucks.com/vboard/s....php?p=3867053 |
#140 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#141 |
very cool
I wish i had access to rot free trucks to build... VT does this make you drool? I know it makes me get a lil Chubby
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
#142 |
I hope this guy knows how valuable these will be. Nice!
#144 |
![]() Join Date: Nov 2006
Just checking in to see if there has been any updates.
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris |
#145 |
Wow sweet build. I have always wondered what a blazer would look like done up prerunner style. I am eventually going to do a similar build to me Bronco. That is a sexy cage!
#146 |
Sorry, no updates as of right now. Feel free to send money to the "Not Your Typical Blazer Build Foundation"..............
![]() Thanks for the compliment. |
#147 |
VA72C10
![]() Join Date: Mar 2008
Great work...will be watching...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#148 |
#149 |
#150 |
Great work looking forward to more juicy pics!
