Old 03-29-2009, 09:57 PM   #126
19723DR
19723DR's Avatar
Re: 1971 Cheyenne "One For the Road"
I pulled out the blazer gas tank I bought a while back. The place I got it from has a policy of punching holes to drain the gas. That sucks, but not that hard to fix. I used a wire wheel to clean up the rust, and scaped the goo from the small leak from a previous patch. I pulled the metal from around the hole the best I could, then used gas resistant epoxy to patch the small holes. I am going to use a tank sealent inside the tank.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 04-07-2009, 11:31 PM   #127
19723DR
19723DR's Avatar
This weekend I've been working on getting the rust and the holes taken care of. I cut two sections of the small support out behind the wheels. I welded in two patch pieces that I cut from the long bed section I removed earlier. I also notched the rear support for the gas tank.
Drivers side
97 Z71 3 Door
Old 04-07-2009, 11:40 PM   #128
19723DR
19723DR's Avatar
Passenger side
I also cut the corner of the tire well and welded a piece on. Three out of the four need replacing.
97 Z71 3 Door
Old 04-07-2009, 11:48 PM   #129
19723DR
19723DR's Avatar
Here's the gas tank notch, I also cut out the two side pieces and welded in some new ones.
This next weekend, I'm going to try and get the supports back in and get it all cleaned up for paint. See ya next week.
97 Z71 3 Door
Old 04-08-2009, 02:08 PM   #130
ChvyLvr83
You're fast! Your truck is looking very nice so far. After seeing you're pics I feel lucky living in Cali where we don't get too much rust. I'll be checking in periodically to see the progress. Love restoring trucks!!
ChvyLvr83 is offline   Reply With Quote
Old 04-08-2009, 11:29 PM   #131
19723DR
19723DR's Avatar
Thanks. It's been almost a year now, and it's come along way for sure. It's hard for me to believe its the same truck. Utah is known for bad rust from the salting of the roads in the winter.
97 Z71 3 Door
Old 04-30-2009, 12:22 AM   #132
19723DR
19723DR's Avatar
Man I am such a slacker, but I did get some work done. Got the support welded back on the bed and got the entire thing undercoated. I also cleaned my gas tank and sealed it with KBS Gold standard. It's been so humid here I took two days for the inside of the tank dry. In four days it should be dry enough to fill. Which should give me time enough to mount the tank.
97 Z71 3 Door
Old 04-30-2009, 01:39 AM   #133
VA72C10
VA72C10
VA72C10's Avatar
Nice work...you're not a slacker
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-02-2009, 12:33 AM   #134
19723DR
19723DR's Avatar
[QUOTE=VA72C10;3285681]Nice work...you're not a slacker [/QUOTE
Thanks. I guess if had some money to spend I would have a lot more motivation.
In the last two days I have filled my gas filler in the cab and mounted the gas tank. I guess your right.
97 Z71 3 Door
Old 05-03-2009, 12:49 AM   #135
19723DR
19723DR's Avatar
This is how I mounted my gas tank.
I took some L-metal I got from work and made a rectangular support that simply bolts right to the frame sandwiching the tank to the frame. I was also able to run my fuel lines for the tank.
97 Z71 3 Door
Old 05-03-2009, 01:10 AM   #136
19723DR
19723DR's Avatar
Here are some pics of the fuel filler. I concaved the piece by hammering it on the cement. It's crude but it works.
I picked up my paint today and was surprised it only came to $160. One gallon of medium blue, quart of white with reducer. I still have some clear left over from the 'burb I need to use up.
97 Z71 3 Door
Old 05-04-2009, 11:44 AM   #137
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
you mentioned that you still had manual brakes....
go to the junkyard, pull the booster off a power brake truck, , undo the rod that hooks to the brake pedel, go home take your mc off, install booster where it would normally go, and put brake pedal rod on, adjust brakelite (pita) and hook up vacum lines, and bam power brakes...leme find the faq on it...
John
1999 Toyota Tacoma 4x4
Old 05-04-2009, 01:19 PM   #138
barthmonster
Hey I could use that booster tip too. !
Truck is looking a lot better. I'm glad to see people save trucks that have a lot of rust like that. Awesome !
barthmonster is offline   Reply With Quote
Old 05-04-2009, 11:34 PM   #139
19723DR
19723DR's Avatar
It's on my to do list. The last time I went to the scrap yard, I found zip in good shape. I've looked in the faq section and there are a few good posts on power brake swaps, I'll probably go with a '73 and up booster because they are so common...you just have lengthen the rod a bit. I guess it's about time I made a trip back to the scrap yard.
Thanks. I'm getting excited to get it on the road.
I wouldn't say this truck has a hard time stopping. It stops fine, it just takes a lot of pressure on the peddle to stop.
97 Z71 3 Door
Old 05-04-2009, 11:58 PM   #140
19723DR
19723DR's Avatar
Sunday I dusted off the old paint gun and shot the inside of the cab. Here are some pics.
Basecoat
Clearcoat
Today I put the dash back together put some gas in the tank and fired it up for a minute. Next week I'll paint the top so I can install the windshield and back window.
97 Z71 3 Door
Old 05-05-2009, 12:16 AM   #141
VA72C10
VA72C10
VA72C10's Avatar
Looking good....I love blue and white two tone...
Old 05-11-2009, 12:09 AM   #142
19723DR
19723DR's Avatar
Well here is some blue and white two-tone for you.
This weekend, I painted the cab including the firewall. I can see why most guys paint one solid color, it's so much more time masking everything off. I think it's worth all the extra work.
I know ya'll like pics!
[img]http://warp.scl.utah.edu/19723dr/Mader-350.jpg[/ing]
97 Z71 3 Door
Old 05-11-2009, 12:21 AM   #143
19723DR
19723DR's Avatar
I added some silver metal flake to the clear. Here it is in the sun:chevy
Today, I tinted and re-installed the back window. Using a small rope, I pulled the seal into place starting at the bottom and working my way up to the top. My wife pulled the rope while I held the window in, it was much easier on my hands and only took 15 minutes.
97 Z71 3 Door
Old 05-11-2009, 12:49 PM   #144
kyull67
kyull67's Avatar
looks good!
kyull67 is offline   Reply With Quote
Old 05-11-2009, 07:27 PM   #145
sson20s
sson20s's Avatar
the truck looks awesome motivated me today andi went out to the junk yard and found my seats thx
2 many ,want to finish 1
sson20s is offline   Reply With Quote
Old 05-12-2009, 12:03 AM   #146
19723DR
19723DR's Avatar
Originally Posted by kyull67 View Post
looks good!
Thanks. Congrats on getting your truck in a video.
That's awesome! I hope you found some good seats. I am often motivated by other builds I find on this site. Good luck with your truck.
97 Z71 3 Door
Old 05-12-2009, 12:09 AM   #147
19723DR
19723DR's Avatar
I've got good news and bad news.
The bad news is my server is down, so no pictures.
The good news is I got my windshield in without breaking it.
The windshield took me about an hour, I used the old rope trick. It worked like a charm and saved my fingers. I only needed help lifting the windshield in place, but once there I was able to do everything else myself.
97 Z71 3 Door
Old 05-12-2009, 08:27 AM   #148
nuke1
nuke1's Avatar
I would say it looks great, but that darn invisible trick is happening again, how do you make your truck invisible.........
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 05-12-2009, 09:06 PM   #149
19723DR
19723DR's Avatar
It's not invisible, we had a freak snow storm and a polar bear just happened to walk in front of the camera.
Whenever I post some good pictures my server goes down, Go figure.
Take a look now.
97 Z71 3 Door
Old 05-13-2009, 11:12 PM   #150
19723DR
19723DR's Avatar
This week I got a lot done on the truck. Back window, windshield, and some body work on the fenders.
Here is my rear-sway bar. It's from a 90's suburban. The end links are from my brother's MR2. I drove it around the block and it handles like a dream.
97 Z71 3 Door
