#126 |
![]() Join Date: Nov 2007
Re: Header Solution
I guess not. Too bad, they looked promising.
#127 |
Active Member
![]() Join Date: Aug 2008
Re: Header Solution
Sorry for the delay. I just got back into town. I will check on them tomorrow and let you know asap.
#128 |
Re: Header Solution
Thanks.
#129 |
Re: Header Solution
#130 |
Re: Header Solution
Have you gotten the Big Block ones complete in Stainless Steel?
What is the specifications? Tube Diameter? Collector size and type? What motor mount are you using? I'm interested in ordering a set, but need to find out what is available?
Dan 67 Chevy LWB, Small Window - In the process of being rebuilt. Small Block is coming out & I'm gathering parts to switch to a Big Block 496. |
#131 |
Re: Header Solution
x2
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
#132 |
Active Member
Re: Header Solution
The BBC headers will not be ready until mid October. They are 2" primaries with 3" ball and socket or 3.5 " flanged collectors. I will keep you guys updated as I get them. Thanks
#133 |
Re: Header Solution
October 1st bump. What's the progress?
#134 |
Active Member
Re: Header Solution
We have got the tooling for 3.5" collector and the fixtures are almost done should hopefully be finished this weekend.
#135 |
Re: Header Solution
I'm interested as well, for the big block headers. Need to know the details on the type of motor mounts used, etc like the other guy.
#136 |
Re: Header Solution
Are the BBC ones ready yet?
#137 |
Active Member
Re: Header Solution
They are real close to being done. I will post some pics and update progress soon as they are done.
#138 |
Re: Header Solution
Any update?
#139 |
Active Member
Re: Header Solution
I get back in town on thursday. If my flight is on time I will stop by on my way home. If not I will go there first thing in the morning friday.
#140 |
Re: Header Solution
Is there any way we can get the name of the shop doing these so we can contact them directly? I'm not feeling good about this and may just go with an off-the-shelf set.
#141 |
Re: Header Solution
That's what i ended up doing. I couldn't keep waiting for these...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
#142 |
Active Member
Re: Header Solution
PM sent
#143 |
![]() Join Date: Feb 2008
Re: Header Solution
Can the SBC version be built with LT1 D-port flanges? Do you know if they'll clear everything using '72 OEM SBC towers & pads for the LT1 & 6spd Manual using a hydraulic clutch?
Thanks for putting this together & even doing the BBC version - might be getting a set of those for a 72 BB Burb myself. Both versions look SWEET.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
#144 |
Active Member
Re: Header Solution
Yes they can be made with lt-1 d port flanges. As far as fitting that setup I would not know. You can pm me some measurements and photos and I'll do my best to find out if they will fit. I don't think we will be able to find a local truck with that same setup.
PS one side of the BB headers are done. Working on the other side then one last test fit. Last edited by Jokers69; 11-24-2009 at 02:22 AM. |
#145 |
![]() Join Date: Oct 2009
Re: Header Solution
Jokers69, I'm interested in a set of your coated headers with the D-ports and 3" ball/socket collector. I'm currently doing a frame-off on a 71 SWB C10 and will be installing a 95 LT1 with 700R4 trans. Can you provide contact info, pricing and delivery time?
Thanks, Justin |
#146 |
Active Member
Re: Header Solution
Pm sent
#147 |
![]() Join Date: Apr 2005
Re: Header Solution
Can you post a price list for the different variations?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#148 |
Active Member
Re: Header Solution
The BB headers are $575.00 bare and around 925.00coated 2" primaries and 3.5" collectors. This is a pic of first production one with the prototype. We will be test fitiing them later today or monday. Thanks
#149 |
Re: Header Solution
absolutley interested. shoot some pics of them installed on monday, if they are above the frame rails you got atleast me sold on them. any chance of getting them with ball and socket type flanges?
#150 | |
Re: Header Solution
