#126 |
Re: High School Build 72 Chevy LWB
cool!!! keep it up,nice job
#127 |
Grandpa in the rustmobile...
So its roadworthy? Need to get some nice cheap lumber for the bed!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#128 | |
![]() She's looking good.
Eric ![]() ![]() ![]() ![]() 1995 Ford F-250 4x4 Powerstroke, 342k "Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known." -Ronald Reagan |
#129 |
Learning As I Go
almost need to deal with the dmv and the exhaust popping for some reason
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again) |
#130 |
Learning As I Go
oh my it has sure been a long time since i got on here since i got my lil toyota pickup the truck just sat and im now apart of toyotaminis.com and its easier to work on my toyota and stuff actually happens to it i am converting my toyota to 4x4 soon so i could lay frame with this if really want to
#131 |
nooooo
toyotas are good lil trucks though, what is it?
#132 |
Learning As I Go
78 toyota pickup my buddy bought for me
#133 |
least it has aweesome slots lol
#134 |
Learning As I Go
yeah it sure does whip donuts though
#135 |
Learning As I Go
well long time of no action in this thread but the toyota got blown up replaced the motor and 4x4'ed it and drove it and the block was cracked so it was on its way to get a new motor and it gave up and it just sat and sat and chopped it up and sold the parts but now i finally got the chevy registered and got to drive it on the last day of school no tail lights or brakelights runs great drives great had a major oil leak but fixed it now i'm attempting to find out why i have no tailights,backup lights, brakelights, running lights or dash lights no power to the fuse box my friends dad told me its a fusible link thats made to melt and hes almost 100% sure thats what it is but heres a more recent picture
#136 |
Im not one to judge on safety, but you REALLY shouldnt be driving very far without brakelights...
Ive done stupid stuff too.. ![]() Nice to see ya workin on it again, mines parked for awhile now as well
#137 |
starting to be a good lookin truck
#138 |
Learning As I Go
thanks its getting there and yeah i don't drive it much without brake lights.
#139 |
Learning As I Go
all the lights work now just no reverse lights drives great did a 2-1 exhaust to a 40series flow and it sounds great
#140 |
much better than the yota! keep chippin away little by little
Posted via Mobile Device |
#141 |
Learning As I Go
well for now its going to be used as a work truck i have already got a new toolbox and loaded a 2x6 20ft by 20ft deck in the back of it then later on down the road its gonna get bagged and left 8 lug and lay it on the ground as much as i can with some goodies me and a friend were thinking of doing..
#142 |
Learning As I Go
So heres a 4th of july picture and I plan on getting some body filler and alot of sand paper and borrowing my friends welder to start doing body work i plan to do all the body work i can while working around the rust spots i need to replace and painting it OD green that will look like my friends blazer i can at least get it in primer for now so i will be updating more often hopefully...
#143 |
I like the Green idea
are you going to do something about the grille i think something other than black would look cool
#144 |
Learning As I Go
do give ideas now looking at the pictures it does look like too much black but i do think a green/white truck with little parts black might look good but what do you think i should do? I just put my new fuel sending unit in and hopefully it works it reads a half a tank and the guage doesnt tank anymore when you turn the key off. I also painted the cab gloss white it looks so good that it makes the black look like crapola pictures in a bit. Just for ****s and giggles heres what my little toyota above looked like when i took it apart
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again) Last edited by 72chevyfleet; 07-13-2012 at 04:48 PM. |
#145 |
Learning As I Go
took the tool box out and finished the bed floor situation tell i get a new bed cause this one is broken in many spots in the front causing bed flex so tomorrow is paint the floor, wheel wells, inside of bed and the back of the cab and throw the box back in
#146 |
Learning As I Go
well got a new hitch with the little light adapter that plugs into the back harness painted the inside of the bed and the bed floor with a texture coating we did on our 8ft trailer to and i have been driving it every day working on taking trash from my grandparents house haulin the trailer back and forth and hauled my dads boat yesterday and one problem though its leaking oil from the around the valve covers but i just changed the gaskets hoping that would fix it. Cause it hits the headers and smokes.. any ideas?
#147 |
Learning As I Go
Well for those who are still following the slow build of the truck. i figured out where the oil was coming from i believe the rockers or valve springs were rubbing against the covers and they wore holes through them so i got new valve covers and put them on. Question #1 is that because my valves need to be adjusted or whatever. Ive got some pictures of what happened and the roof is now dent free and primered. For some reason i have really been looking into a 5.3 vortec swap for reliability and mileage and plus it would be nice to push the pedal to the floor and fog the tires then hooks and takes off. Ideas? From the research i can get a ready to run 5.3 for $1995.00 just drop it in with the 4 wire hookup and run the fuel line to a pump and boom you got a 20mpg beast.. just need Motor mounts and tranny mounts driveshaft,exhaust etc... it would be a little while till that but I'm just throwing out ideas here. oh and i put in a new master cylinder because my cap and gasket were wasted plus there was a bunch of sludge in the old one so i just put a new one on. heres the most recent pictures i've taken
#148 |
Learning As I Go
Well this coming friday theres a local guy thats going to tune the carb/adjust timing/get the choke right just so i know its right and don't have to worry about it its becoming more primered then black but im going to work out all the dents and imperfections of the drivers door/cab/drivers fender and probably drivers door. The passenger fender has good rot at the bottom front corner and the bed is wasted. The hood just has this dime dent at the front i can't really fix (can't get to the back of the dent) So far the roof looks dent free and drivers door too. Fender is almost minus the trim holes i do not want to reuse heres a couple more pictures
#149 |
sweet glad to see your doing something with it!!!!!!!!!!
#150 | |
![]() Join Date: Aug 2012
