07-23-2009, 09:26 PM | #126 |
Re: Glock's new project: "Fred"
right on congrats buddy!! no stopping you now!
btw... what alls on that parts list of yours? you already have me beat as far as research and making lists AND finding the best deals! i think you have at least 2 trucks on me already!!.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
07-23-2009, 10:06 PM | #127 |
Next project: 1970 K10
I've got a good list of parts going at work, now I need to get on the ball and start finding price deals. I'm going to make my own mounts, so that saves a little. I budgeted having Jesse at Wait4me do the harness, but I may do that too. That would save about $300. I'll probably do my own exhaust again. I was going to get a used tranny from C.A.R., but I talked to a buddy of mine today and he's going to build me a tranny for the same price, with a 3 year/70,000 mile warranty. Plus I'm noting little things too as the pop in my head, like hose, hose clamps, fluids, etc.
I'll get my list updated and post it here in the next few days.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-23-2009, 10:54 PM | #128 |
right on... pm sent
07-24-2009, 08:23 AM | #129 |
I don't think it's right that you guys are just rubbing it in like that!
Bob I think you should build another dash like that for Fred. It should be easier this time around because you have done it before! The new bezel looks awesome. When I get to the interior I may have to give Cheyenne a call, and run over there and pick one up. |
07-24-2009, 09:19 AM | #130 | |
Custom dash for Fred?? !!!! Maybe waaaaaaay down the road, but I promised myself I wouldn't get carried away with this one. The dash thingy is a pretty good deal for the price. As long as the plastic is in good shape, this makes it look new again.
07-24-2009, 09:54 AM | #131 |
OK Dennis, I know there is more than this, but this is what I have so far:
Engine Transmission Engine mounts Oil pan Harness and PCM tune Exhaust system A/C (1) Cooling system (2) Frame modifications (3) Transmission x-member mods Fuel system (4) Driveshaft modifications Plugs Plug wires Vacuum line Hoses Clamps Thermostat Antifreeze P/S fluid Brake fluid Transmission fluid Rear differential fluid MAF sensor, used New O2 sensors (1) Vacuum, leak test and charge. Manifold, hoses (2) Radiator (?), electric fans, shroud (3) Notching and boxing for A/C and/or Oil pan is necessary (4) Pump, filter/reg, lines, fittings
07-24-2009, 01:48 PM | #132 |
thanks Bob!
i was just thinking if we run duel tanks w/ the return line from the vette filter does the return go back through the switching valve and then back to which ever tank were on?
07-24-2009, 01:57 PM | #133 |
Yes, I believe that from the valve it then returns to the particular tank that is selected.
07-24-2009, 03:23 PM | #134 |
My motorcycle just left the parking lot, so I'm off to the bank to deposit the
Then, it's: "Hello, Certified Auto Recycling? Yes, about that 5.3 Vortec we have been discussing........"
07-24-2009, 03:43 PM | #135 |
SWEET!
07-24-2009, 04:40 PM | #136 |
Bob, on your list you mention spark plugs... go w/ the stock ac delco plugs. last summer we tested the ngk's and a number of others and the ac's pulled more h.p. on back to back dyno pulls in the goat's ls2. also the exhaust... (flows sound awesome and its what im going to run in the truck) but on the ls2 actually lost h.p. compared to magnaflo, slp, ect. and yes i know theres lots of variables but everything that could be controlled was. there is a few locked threads over on ls2gto.com about this but i just thought i'd mention it now rather than later. knowledge is power! Dennis
07-24-2009, 05:01 PM | #137 | |
I hear ya! ACDelco has always had my back! I only put them on my list because I want all the critical stuff like that to be new, so I'm not chasing around weird demons if there are issues.
I'm with you on the exhaust too. Flows are what I'll be using too, I just flat-out like the sound. In my case, and for Fred's use for the next couple of years, a few lost ponies won't matter. Quote:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-24-2009 at 05:02 PM. |
07-25-2009, 09:51 AM | #138 |
Again Glock, you are the man. I can't wait to see your 5.3l install thread.
Inspirational |
07-26-2009, 11:36 AM | #139 |
Slots go on anything!
I have always liked Flows also, but I used Zoomer's exhaust on my CTS-V. It is hands down the best sounding exhaust I have ever had on a car. The Cadillacs use 2.5" duals with a big resonator right behind the trans, and two large mufflers right at the end. The Zoomers exhaust uses a baffled chamber on each pipe in place of the resonator and also in place of the mufflers. Had to be less restrictive than stock. Maybe you could use something similar to that. It has a little pop on deceleration (mostly because of the heavy stock flywheel, I think), but I really don't pick up any drone on the highway. Either way, I am sure it will sound good.
07-27-2009, 10:35 AM | #140 |
I got all the fuel system parts ordered this morning.
Now I'm getting ready to call a yard in Cali that Dennis turned me on to. Trying to get a deal on an engine and trans combo now instead of just the engine.
07-27-2009, 10:38 AM | #141 |
good luck! just hope the shipping is reasonable...
07-27-2009, 10:45 AM | #142 |
I just got off the phone with a guy named Roger, Scott didn't answer. Shipping is good @ $200, but he quoted me $2500 for a complete low mile combo. I told him that was out of my budget and that I need to look at some things and I would call him back. I really don't need all the things that they offer to send, so I think I can get him down lower.
07-27-2009, 10:46 AM | #143 |
Sweet keep us updated.
07-27-2009, 11:07 AM | #144 |
Here are some Egay listings that may or may not help. Worth a look though...right?
http://cgi.ebay.com/ebaymotors/05-06...Q5fAccessories This place has a lot of really inexpensive listings, and may be able to accomodate your needs. Might be worth a call. |
07-27-2009, 11:08 AM | #145 | |
i have the vin # of the tahoe it was coming out of too. worst comes to worst (if they keep stiffing you) i'll fax this quote to ya! 5 hun is 5 hun. try asking for that kid octavian. he's is the one that turned around and asked how much and scott said $2000 from radiator to fuel tank... btw $200 for shipping seems like a hell of a deal. i expected a lot more... how much(if you dont mind) did the fuel system end up being?
07-27-2009, 11:11 AM | #146 |
Oh heck yeah, I'd take a fax of that! That would definitely help me negotiate that down. I'll PM my fax number to you!
Edit - Forgot to add, fuel system total so far is $292.23. That's the filter/regulator with fittings, 2 fuel pumps and the high psi switch valve. Still need hose and SS clamps. I got free shipping through JCWhitney (saved ($15.95) and 5% off at Rock Auto.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-27-2009 at 11:12 AM. |
07-27-2009, 04:36 PM | #148 |
Engine and trans are on the way!! Well, once they get them yanked out of the truck they will be. 58k miles, and everything INCLUDING the kitchen sink will be sent.
07-27-2009, 04:44 PM | #150 | |
I'm pretty happy with what I found. They will unbolt the engine and trans mounts, and unplug and include every harness on the truck related to the powertrain and pull it as one unit. Radiator and shroud, fuel system components, trans yoke, head pipes, fuse block...... everything. I will probably be able to sell a lot of it and recoup a little bit of money.
