10-11-2012, 11:37 PM | #126 | |
Re: 73-91 8-lug 19.5 22.5 24.5 Pics
Are there other options for dually wheel adapters? |
10-12-2012, 09:24 AM | #127 |
heres the 19.5s im putting on my rig. I plan on getting some 22s for my other truck but i need to know which ones to buy cause i want to keep my wheels under the dually fenders. And do you run 6 22s or Keep inside rears as 16s?
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
12-17-2012, 08:41 AM | #128 |
Just a follow up on this... Trevor and I couldn't reach an agreement on shipping for the wheels. He also stated to ship just the adapters to me would be around 250-300 dollars. I HIGHLY doubt that is the case and I think he may have been overinflating the cost to discourage me from making a purchase. (Just so he wouldn't have to find actual shipping costs). I am now working with another vendor on getting a set of adapters shipped to me, and picking up a set of new 22.5's locally.
02-08-2013, 02:33 AM | #129 |
Another update,
Why does it seem that all the vendors I contact regarding dually adapters seem so shady? Of the three places I have contacted I got inflated shipping costs, the vendor lost communication then forgot the conversation we had via email (even when the communication is clearly below the newest email) or I just get a bad feeling when speaking with them. Does anyone know a trustworthy vendor I could place an order with? |
02-08-2013, 07:23 AM | #130 |
Those adapters are very heavy, they are 1/2" thick steel that's why you are seeing high shipping prices.
1949 Five Window, 1973 Step Side, 2000 Z71 |
02-08-2013, 12:24 PM | #131 |
try to find some second hand ... maibe on www.duallyscene.com seen one on there :
Here is my set of 6 wheels that I ran for the past year, I'm going a different direction with the truck, so these are going. There are 2 standard polished front wheels, 2 rear inner Alcoa wheels, and 2 special offset rear wheels (known as townasty wheels) The special offset allows them to sit flush in the wheel wheels in the rear, with no modification. Also included are 4 adaptors to fit any standard 8 bolt truck pattern from Ford, Chevy or Dodge Dually, lug nuts, stainless caps, and low profile domes. Everything is included. Tires have approx 1000 miles on them, and look like new. Tires are Sumitomo HTR sport 263-35-22. $3900 Take a look at cost on this setup, this is a great deal.
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
02-09-2013, 10:28 PM | #132 |
Thanks for the reply fellas, I'd like to pick up a set of 22.5's since I don't feel like lowering the truck. In most circumstances a 1 ton sitting on 22's with a low profile tire just looks odd to me.
02-10-2013, 11:29 AM | #133 |
i wanna see more pictures on this truck!!!!!
'82 c10 shortbed drag truck '82 GMC 3500 Dually DD scrap truck '55 Chevy 210 4 door sled '65 VW Bug Rat Rod |
02-10-2013, 11:33 AM | #134 |
im curious to see the rear dually fender lights? i like the front ones that are half clear and half amber!
04-01-2013, 04:46 PM | #135 |
they look like half clear half amber. i know that they are the same as the 73-80 front lights
04-10-2013, 05:28 PM | #136 |
can someone give me the pros and cons to doing 22s on a lowered dually? i have been looking at doing some on a 92-2000 dually. will i still be able to pull my 24ft enclosed trailer do they ride good? so on?
04-10-2013, 05:48 PM | #137 |
are you going to put low profile tires on them ?
if so you might scratch the front rims on the sidewalk should you get to close to it , sooner so than with single wheel type rims as they stick out about 1.5 to 3 inch outside the tires steering geometry is going to be slightly off as the front rim put the tires in more the rear fenders need to be widened unless you dont raise the truck good thing is that the tires stick out ore making the truck more stable unless you buy brentz rims that are 8 bolt you need adapters if you put normal trucktires on them they last about forever again you might need to raise the truck to get them to fit whent to look for a pic of the brentz stuff and found this i hope it helps http://www.sporttruck.com/techarticl..._1_ton_dually/
04-10-2013, 05:55 PM | #138 |
I'm going to most likely go with tnwheelandtire townasty 4 wheel package. Except go with like a 285 40 22 which will carry 2601lbs then run a inside tire to match which would be close to a 235 85 16 at 2800lbs
04-10-2013, 09:51 PM | #139 |
know the guy unfortunately if you buy from him pick it up youreself and only pay after you get everything hes not verry good at aftersales , allso his garage adres isnt the adres on the website thats the adres of some restaurant there (i whent on holliday from europe to pick my stuff up and he never mentioned it even after i gave him the heads up that i was on my way)
he does have the correct adapters though heavy steel ones and the townasties will help some with the rear fenders , you might still need a different (chassis cab or breadtruck ) rearaxle to bring the wheels in even further
04-11-2013, 08:04 AM | #140 | |
Charlie Daniels w/ a Tq Wrench
I think the smallest E rated 22" tire you can get is a 285/50R22, and not many companies sell that size. I know Nitto makes a terra grappler in this size. That is, if you actually plan on using it, otherwise put what you want on there.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
04-11-2013, 08:16 AM | #141 |
you can find a lot of related info on www.duallyscene.com
04-11-2013, 08:18 AM | #142 |
I really want to be able to haul my 24ft enclosed trailer with It. With a car in it I'd estimated is weighs 6500-7500lbs
04-11-2013, 11:39 AM | #143 |
should be doable as long as the loadrating of the tires can take it
04-26-2014, 08:04 PM | #144 |
Squarebody guy
Anymore trucks out there? I hope to pickup an 88 dually tomorrow.
04-29-2014, 04:34 PM | #145 |
19.5's all arround
08 cc silverado dropped on 24's 82 1 ton c30 Dually |
04-29-2014, 10:26 PM | #146 |
those look real nice , i seen 24's under the same year truck and there just too massive , these fill the wheelwells nicely and the tires have the correct loadrating
both the tires and the rims be more available across america too incase of a blowout (most of the lower class non commercial licence motorhomes are running 19,5 " rims )
05-01-2014, 12:44 PM | #147 |
19.5s
05-28-2014, 09:00 PM | #148 |
07-02-2014, 06:30 PM | #149 |
got my alcoas today
07-03-2014, 01:06 AM | #150 | |
Long live SLIM ------------------ At least try to buy American |
