03-10-2013, 02:01 PM | #126 |
Re: 72 Suburban Started
great build
03-14-2013, 01:59 PM | #127 |
Update: I have the axel and trailing arms out, cleaned and painted them last weekend and the blocks and u-bolts are in as well as the trailing arm bushing. I will install them in a couple of weeks when I get back from Las Vega. Leaving tomorrow on a company trip 1st time every going. Anyone from the area that can give any suggestions of what I need to visit while there please let me know.
04-08-2013, 02:52 PM | #128 |
Rear notch is in and painted, rearend, trailing arm, 2" blocks new u-bolts and air bags are installed, so today I order some parts today to get the Fatty Natty on the road.
1 VIAIR 480 COMPRESSOR 5 GALLON BLACK 8 PORT TANK WITH 1/2" PORTS 4 SMC 1/2” VALVES 4 SMC 3/8” VALVES AVS 7 SWITCH BOX (YOU CHOOSE COLOR) 165/200 PRESSURE SWITCH VIAIR HIGH AMP RELAY 2 DUAL NEEDLE AIRLIFT 200 PSI GAUGES 1 SINGLE NEEDLE AIRLIFT 200 PSI GAUGE 50’ OF SMC 1/2" DOT AIRLINE 50’ OF SMC 1/4" DOT AIRLINE 1/2 type K copper 3/8 type K copper Brass fittings Both front fenders Front bumper Battery box Complete SS fuel line Complete SS brake lines Carrier Bearing 3- drive staft u-joints Complete Steel (in frame) gas tank Core support with Hardware I will be 2nd 5 gallon air tank and compressor as soon as I get it driveable. More Photos coming soon. |
04-08-2013, 03:41 PM | #129 |
low n' slo
nice parts list!
whar are you using for the rear floor and tubs? Posted via Mobile Device
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
04-08-2013, 03:49 PM | #130 |
Not sure, we are going to build a new floor .. raised if necessary .. the intent is to hide everything under it but still make it accessible.
04-08-2013, 03:51 PM | #131 |
Here's the latest picture (with the old sheetmetal)
04-08-2013, 04:27 PM | #132 |
low n' slo
looks good laid out!! what are you going to do with the stock rear fuel line to the gas tank? im trying to address some issues with all the stock hosing and stuff back there before i take it around the block.
you can see in post 120 pic #2, it ends up going to the middle of the axle. is it going to stay like that, or are you going to bend it around the notch? trying to figure out some ideas because im working on that now...
04-09-2013, 03:00 PM | #133 |
I ordered the 2 piece SS fuel lines kit but I will have to cut it off and use A.N fitting and ss braided fuel line to the tank not real sure untill I reach that point, I am thinking about building the floor from 3/4 angle with raised floor and 1/2 hard wood flooring for the rear floor but 100% sure yet. I have a lot of ideas but no fixed plan...
04-09-2013, 05:14 PM | #134 |
guys, there is a show at the montgomery riverfront on saturday...it's the 1st annual show so not sure how big it will be.
http://www.montgomerystreetrods.com/ and you probably know about these. http://www.montgomerystreetrods.com/...ing_events.php .
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
04-09-2013, 09:15 PM | #135 |
low n' slo
too far from texas made2drag..
i just ordered that same brake kit but in oem..i think i will leave it going across the axle like this, then mount it to a tab i will weld to the stock brake tab on the axle...not pretty by any means but it should be functional and covered up by the floor.
04-09-2013, 09:53 PM | #136 |
low n' slo
Scratch that...im gonna bend it along the notch and attach another bent up line around the rest of the notch and connect the 2 with a very small hose...then connect the hose from the tank to end of the line. Dumb idea above....lol
04-10-2013, 11:54 AM | #137 | |
04-11-2013, 03:50 PM | #138 | |
04-12-2013, 03:57 PM | #139 |
I will post some photos of the show.
04-12-2013, 11:29 PM | #140 |
Nice work man. Looking good.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
04-15-2013, 12:27 PM | #141 |
Riverfront was a good show about 100 cars / trucks attended, this was the 1st show the City of Montgomery has put on the Camaro won top 25. Ran into another member (Madetodrag) at the show and Bcubed will need to post photos of the event.
04-16-2013, 01:26 PM | #142 |
05-02-2013, 07:44 PM | #143 |
ya'll going to the monthly gold star show on sunday? we started a little club and plan to be there around 2p...
05-22-2013, 05:20 PM | #144 |
05-23-2013, 10:23 PM | #145 |
looking good
05-23-2013, 10:40 PM | #146 |
low n' slo
I like!
05-29-2013, 11:41 AM | #147 |
love the grill...that thing is looking mean!
06-03-2013, 06:33 PM | #148 |
looking good man
Jim |
08-20-2013, 09:38 AM | #149 |
What are you going to do one the drivers side where the rust is in front of the rear wheel?
10-29-2013, 03:46 PM | #150 |
Inter structure is not too bad, just going to cut out the cancer and I have a truck panel that I am going to cut up and use. It is not the same but I will make the needed changes to make it work. I have been ordering parts and next month I will get back started on the build.
