05-11-2012, 05:07 PM | #126 |
Re: 74 K/5 Screamin Green
Do you know what the paint code for the blazer is? It looks like the same color as my 76 which is medium lime or spring green.
05-11-2012, 08:33 PM | #127 |
its 568 .. special to 74 the color on 75 / 6 is brighter.. dont let the color on the front fenders fool ya its the wrong shade....
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
05-11-2012, 08:35 PM | #128 |
walkerb "hahaha.... How do I pm? And yes Im serious"
. click on my handle it should drop down to send a PM...
05-11-2012, 08:37 PM | #129 |
the best thing i discovered today is.... i will most likely have to redo the drivers quarter install and re do the rocker..... i messed it up somehow.... after looking over the pass side and seeing how it all fits i screwed something up so the front of the rear quarter is out about 5/8 inch too far.....
05-13-2012, 09:10 AM | #130 |
I picked up a section of floor from a donor K5 on Friday, so I can repair the rear floor above the hinges. . I did MAJOR surgery yesterday..... removed the quarter.... discovered some hidden cancer. Busy busy busy. whats nice it even after removing the quarter. the door still shuts perfect even with only the door frame on the truck.
05-13-2012, 08:33 PM | #131 |
well I got at the back of the K5 today...removed the wheel house and gas tank.. trimmed back the floor to expose the rotted rear /tailgate cross member. fabricated a new section for the top welded it in and POR 15'ed it...
05-13-2012, 08:36 PM | #132 |
more pics...
Also i received my carpet samples for the interior... I have them set on the dash with the seat in the background.... i think the darker olive is the best match ( the one on the right)
05-15-2012, 09:22 PM | #133 |
repaired the rear wheel tub with new steel patches and square nuts... glad i practiced on the front tub...
05-16-2012, 06:45 AM | #134 |
Dash pad looks really good and dark olive matches well. Is that por 15 your using to coat everything?
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
05-16-2012, 10:44 AM | #135 |
yeah it is good stuff.... it makes a real mess if you dont use gloves and old clothes...but it sticks/ wears like iron... Ill send you a PM so u can get in touch
05-18-2012, 10:40 AM | #136 |
got the rear quarter mounting areas all reconstructed and POR'ed read to re mount the wheel tub and begin to test fit the new quarter.
i didnt realize the corrugations of the floor were not uniform. it seems the outside ribs are wider. i have enough of the OE floor material to make one side... but have to cut and weld the material to achieve the proper spacing... see last pic
05-18-2012, 12:02 PM | #137 |
nice
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
05-18-2012, 09:53 PM | #138 |
well the passenger side is basically complete the panel lined up but i had to alter the after market rocker due to the rocker being slightly (3/16ths inch) narrower than the truck needed to have the "B" pillar parallel all the way down... and fabbed up a lower splash shield between the rocker and the rear support....
I sliced and filled the gap with the welder and a scrap, I encountered the same issue when doing the drivers side... among other fitment issues that I will tackle once i have the fuel tank back in the truck and can turn it around.... but here ya go.... it looks like a truck again... the factory QP went on very smooth...
05-18-2012, 09:59 PM | #139 |
before and after shots.
05-19-2012, 01:10 AM | #140 |
Nice job wish I had the pashents to do that much rust repair
1977 k20 frame with 85 cab and hopefully 6.5 diesel. 1981 c20 long box 250 3 on the tree daily driver. 1982 k25 with 86 cab tired 350 4speed trans 37in military tires.(project Frankenstein). 8. 1984 c30 crew cab dually 6.2diesel next project only 18 and finshed 5 projects started when i was |
05-24-2012, 09:38 PM | #141 |
dropped the tank then proceeded to wire wheel the underside of the floor and the frame.. then POR it.... its flat black
05-24-2012, 09:40 PM | #142 |
the last couple days I wire wheeled the tank and double coated it with POR 15 silver..... then I hung it today.....
05-24-2012, 09:58 PM | #143 |
nice work!
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
05-25-2012, 10:57 AM | #144 |
i hate rust... and **** fallin in my eyes when im under the truck
05-31-2012, 09:42 AM | #145 |
removed the left read quarter yesterday and adjusted the B post and such since i was not happy with the function and fit of the drivers door and the fit of the quarter...
after a few hours carefully removing key areas..i got the door to fit and function great.... today I will repair the tailgate cross brace top as i did on the pass side then place the quarter. PICS to come
06-01-2012, 12:18 AM | #146 |
pics as promised... repaired the drivers side rear cross beam and installed some of the floor over it did some misc repairs to the B pillar and POR'ed where i wire brushed off the old seam sealer.. should be ready to re install (correctly) the drivers side rear quarter... again...lol and a fleet picture...lol
06-01-2012, 07:05 AM | #147 |
Looks good man. Now you can get a good nights sleep knowing that rear quarter is correct!
Keep me updated on that 77
06-01-2012, 11:41 AM | #148 |
LOL yeah I can... because not only will in look better the door fits better which means the seals will work better....
now if i could only get the 72 to stop leaking...lol the windshield has one small drip. yeah i was gonna look into the 77 soon, I was down your way last night pickin up a 700R4 for the 73 Grimey but 160 bux... wanna help me replace my bad one this weekend?
06-05-2012, 03:37 PM | #149 |
the re-install of the DS quarter is done..the back edge of the bed is done....and the missing tailgate is on it and all functions great. remaining work... tack the front edge of the passenger quarter lay out the cheyenne trim and make holes for emblems... start pullin the dings and dents and skim with bondo prime and paint...
08-29-2012, 04:44 PM | #150 |
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
What ?
Where is the end of this story? I can't find it |
