Old 04-12-2013, 02:47 PM   #126
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: 3200 Napco 1/2 ton Conversion
Originally Posted by bajabob View Post
Hey 85, thanks for stopping by... not much new... I was in the middle of bending brake lines when I got side tracked by this...
Its a 24ft Campbell DayCruiser....
I discovered it had busted bulkheads which mushroomed into rebuilding the entire interior, and changing the color.... Hope to get back on the truck soon.
Bro where have you been? Kabwe and I were talking about you a few weeks ago. Hows everything going for you and the family.
VDOG is offline   Reply With Quote
Old 04-12-2013, 03:38 PM   #127
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Time for headers! We're going to put some in my friends 20ish footer cabin cruiser, the bulkheads are split on his also. Then we have to do the floor and interrior and probably paint the top deck while we're at it.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-12-2013, 04:51 PM   #128
bajabob
bajabob's Avatar
Vdog
Thanks for cool thoughts. Everyone is great. Mama is a little unhappy that the truck has not progressed more (gotta love her!!) But the boat thing kinda of got out of hand and sidetracked me. I just need to find the right guy/shop to rebuild the truck motor and then I will be back in bis.
I promise to get back on it soon.!!!
I did make some changes to the shop so should be able to pull her out and get back to work !!!
bajabob is offline   Reply With Quote
Old 04-12-2013, 04:54 PM   #129
bajabob
bajabob's Avatar
85
Playin with boats and trucks is addicting... Work is getting in the way!!! Currently plumping an oil cooling system and replacing all the fuel and water lines!!! Rebuilt every piece of furniture in her and some cool new stuff for mama !!!!
Old 10-30-2013, 10:50 PM   #130
bajabob
bajabob's Avatar
I got totally side tracked on this but my goal is to finish it by spring and then get back on the truck. I think I will be ready for something else by then. Been on this nights and weekends since the first part of this year. Ready to enjoy it and work less !!!!!
Old 11-29-2014, 02:00 PM   #131
bajabob
bajabob's Avatar
Ok so I am back on this deal after a short break !!! The block is at the machine shop and I drug the frame and cab home. My question is does the cab need a coat of undercoating before it goes back onto the frame ??? I like the idea of it being clean under there but wonder if the undercoating dampens the road noise ???
Old 11-29-2014, 06:21 PM   #132
apache200
apache200's Avatar
Bajabob cab looks great! What color blue is it if you dont mind me asking
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 11-30-2014, 03:56 PM   #133
OrrieG
OrrieG's Avatar
I undercoated mine because it will be used off road in all weather, also did the insides of the fenders and fleetside bed sides. When I got it it had been undercoated and it helped reduce the rust. Should help with sound and heat from exhaust, etc. but I noticed the biggest way to reduce it was with radiant barrier on inside floor. First time around I just used some 1/2" rigid fiberglass, this time will use some of the metallic bubble stuff from big box home store.
OrrieG is offline   Reply With Quote
Old 11-30-2014, 04:43 PM   #134
bajabob
bajabob's Avatar
Apache
It was a stock chevy truck blue that I had them mix up from an original color chart. I was looking for a color that i had not seen yet (really wanted red !!!). Its been awhile since it was painted, I can try and get the exact color name.
bb
Old 11-30-2014, 04:46 PM   #135
bajabob
bajabob's Avatar
OrrieG
Thanks for response. I went out and looked at the bottom side again and I thought they had primered and painted the underside but not the case. Wednesday I will pick up some POR15 and get after it!!!! Once it gets mounted up, the insides will get the Dyanamat treatment.
Old 11-30-2014, 04:49 PM   #136
bajabob
bajabob's Avatar
I think I have most of the hardware to bolt this thing together, just need to get after it !!!!
Old 11-30-2014, 06:29 PM   #137
VDOG
Grand PooBaa Member
VDOG's Avatar
Looks like your missing 1 bolt from the second bag. LOL
Hows it going my friend.
Old 11-30-2014, 07:05 PM   #138
Purcell69
Cab looks great! I really like that shade of blue.
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917
Purcell69 is offline   Reply With Quote
Old 11-30-2014, 07:06 PM   #139
Purcell69
Duplicate
Old 11-30-2014, 10:51 PM   #140
bajabob
bajabob's Avatar
LOL !! Vdog, good to see some old friends still around Hope to hook up with you guys this summer!!!!
Old 12-01-2014, 03:33 PM   #141
OrrieG
OrrieG's Avatar
I just used rattle can rubberized undercoating from the paint supply house. Sticks to everything but remains somewhat flexible so it doesn't crack. I think its a SEM or 3M product?? I am going to use a roll on bed liner from NAPA on the inside of the bed, it can be tinted to match the truck color. I used por-15 on a portion of the frame, springs and cab floor that had surface rust with oil based primer and rustoleum over that. The frame and springs then got Chassis Black single stage, three coats.
Old 12-03-2014, 12:23 AM   #142
bajabob
bajabob's Avatar
Ok now I am really confused..... Talked to a hot rodder friend and he said he uses POR 15 under his ride, talked to another guy today who said he uses a 3M product "underseal"??? on the underside of his body and inner fenderwells ???? Decisions decisions !!!
Old 12-10-2014, 01:06 AM   #143
bajabob
bajabob's Avatar
So I couldn't make up my mind which way to go with the bottom of the cab so I did both. POR15 on the metal followed by the underseal spray. Will most likely do the inside of the fender wells as well. Although its a truck, it doesn't really need to sound like riding in a tin can down to the beach to check the surf !!!!
Old 12-10-2014, 02:58 PM   #144
VDOG
Grand PooBaa Member
VDOG's Avatar
That looks great, hope you dont mind if I borrow that idea.
Old 12-13-2014, 05:19 PM   #145
OrrieG
OrrieG's Avatar
Looks good but how come the center under floor brace is missing? I have always thought that was critical to keep the floor from buckling over time which could affect cab and door alignment.
Old 12-14-2014, 03:17 AM   #146
bajabob
bajabob's Avatar
OrrieG
You almost had me for a minute, started wondering if it was April or not ??? Lol, I wasn't really sure what you were saying because it was possible that they did not return piece that maybe should have been there ????
Check out this build
http://67-72chevytrucks.com/vboard/a...4&d=1413569672
His cab looks suspiciously similar to mine ??? The only thing I can imagine is that the support is in the opposite side where the seat mounts to the floor ???? Thanks for scaring the crap out of me...
Old 12-14-2014, 03:52 PM   #147
OrrieG
OrrieG's Avatar
OK, I went out and crawled under mine, no brace on the bottom either. The discoloration in the before shot got my interest. Sorry for the aggravation! Top brace provides the tension tie.
Old 12-15-2014, 12:27 AM   #148
bajabob
bajabob's Avatar
OrrieG
You can slide on this as you have banked lots of good credit....lol I piddled around today but really got very little done... I guess its baby steps right ???
Old 12-15-2014, 12:36 AM   #149
bajabob
bajabob's Avatar
Got the cab mounted up the other day, now onto bigger things....
Old 12-15-2014, 01:22 PM   #150
VDOG
Grand PooBaa Member
VDOG's Avatar
Your almost there.
